This special adapter was developed for the KISSHome defender project. It is not intended for general use.
To use this adapter, you must first register on the KISSHome defender website and get the confirmation email.
To run this adapter, you need:
- More than 3 smart home devices
- Fritz!Box Router. Without
Fritz!Box, the adapter will not work. - iobroker must run on debian/raspbian (or at least on linux, where the following commands are available:
which,rsync) - Docker must be installed and enabled for the user
iobrokerto run the IDS container
Enable Docker for user iobroker
By older Linux systems to install docker, you must do the following steps
By new systems (Debian 12, Ubuntu 22.04 and newer) you can install docker by the following commands:
sudo apt update
sudo apt install -y docker-ce
sudo systemctl start docker
sudo systemctl enable docker
sudo usermod -aG docker iobroker
Add command docker to the sudoers file:
sudo visudo /etc/sudoers.d/iobroker
Add the following line:
iobroker ALL=(ALL) NOPASSWD: /usr/bin/docker
3.0.1 (2026-08-08)
- (@GermanBluefox) Updated some GUIs to React 19
- (@GermanBluefox) Minimal supported Node.js version is 22
1.3.3 (2025-12-17)
- (@GermanBluefox) Stop any cloud communication after 21.12.2025
1.1.13 (2025-11-25)
- (@GermanBluefox) Allowed editing of the description for automatically found devices
1.1.12 (2025-11-12)
- (@GermanBluefox) Changed german name of adapter
- (@GermanBluefox) Sync names of PCAP files
1.1.10 (2025-11-09)
- (@GermanBluefox) Showed progress devices that have only IP address
1.1.9 (2025-11-06)
- (@GermanBluefox) Try to handle 127.0.0.1 as no bind given
- (@GermanBluefox) Recreate IDS container on error if self-hosted
- (@GermanBluefox) Limit minimal interval for sending PCAPs to 10 minutes
1.1.8 (2025-11-05)
- (@GermanBluefox) Allowed only selection IPv4 addresses and not loopback for communication with docker
1.1.7 (2025-11-05)
- (@GermanBluefox) Corrected error if device is offline
- (@GermanBluefox) Show error codes 400-499 as warning and not as error
1.1.6 (2025-11-04)
- (@GermanBluefox) Showed error message if IDS has an error
1.1.5 (2025-11-04)
- (@GermanBluefox) Destroy docker container on adapter stop
- (@GermanBluefox) Required admin 7.7.19 as dependency
1.1.3 (2025-11-01)
- (@GermanBluefox) Disabled by default self-hosted docker option
- (@GermanBluefox) Changed default threshold value
1.1.1 (2025-10-31)
- (@GermanBluefox) Changed the calculation of the first occurrence time
- (@GermanBluefox) Added link to FAQ in email
1.1.0 (2025-10-30)
- (@GermanBluefox) Corrected JSON config
1.0.20 (2025-10-29)
- (@GermanBluefox) Do not send empty error log
- (@GermanBluefox) Do not send config too often
- (@GermanBluefox) Changed wording
1.0.16 (2025-10-28)
- (@GermanBluefox) Added error log proxying
1.0.15 (2025-10-27)
- (@GermanBluefox) Reset the file upload state if IDS restarting
- (@GermanBluefox) Hide some control elements if instance is offline
- (@GermanBluefox) Added countdown to the manual trigger button
- (@GermanBluefox) Send configuration to the container at start
1.0.11 (2025-10-23)
- (@GermanBluefox) Disable docker settings if not possible
1.0.10 (2025-10-21)
- (@GermanBluefox) Increased the saving data threshold
1.0.9 (2025-10-20)
- (@GermanBluefox) Show digits after comma in charts
1.0.7 (2025-10-15)
- (@GermanBluefox) Corrected the volume for docker
- (@GermanBluefox) Added min,max,step for questionnaire (number)
1.0.6 (2025-10-08)
- (@GermanBluefox) Improved selection of IP address
1.0.5 (2025-10-08)
- (@GermanBluefox) Packages were updated
- (@GermanBluefox) Corrected questionnaire
save_threshold_secondsto the container
1.0.4 (2025-09-24)
- (@GermanBluefox) Allowed setting of the port and the bind address for Docker
1.0.1 (2025-09-22)
- (@GermanBluefox) Fixing questionnaire under Firefox
1.0.0 (2025-09-19)
- (@GermanBluefox) Removed sensitivity parameter
- (@GermanBluefox) Corrected colors in the chart
0.3.2 (2025-09-11)
- (@GermanBluefox) Corrected callback URL
0.3.1 (2025-09-10)
- (@GermanBluefox) Implemented mobile view
0.3.0 (2025-09-08)
- (@GermanBluefox) Implemented the daily status report
0.2.1 (2025-09-05)
- (@GermanBluefox) Showed names of the devices in the chart legend
0.2.0 (2025-09-04)
- (@GermanBluefox) Added direct link to the alarm in the widget
0.1.9 (2025-09-03)
- (@GermanBluefox) Look for vis-(2) project with kisshome widget
0.1.8 (2025-09-03)
- (@GermanBluefox) Fixed GUI issues
- (@GermanBluefox) Send results to cloud sync folder
0.1.6 (2025-08-30)
- (@GermanBluefox) Do not show scores for later time
0.1.5 (2025-08-29)
- (@GermanBluefox) Fixing the detections in GUI
0.1.4 (2025-08-28)
- (@GermanBluefox) Corrected message sending
0.1.3 (2025-08-28)
- (@GermanBluefox) Removed test cases
0.1.1 (2025-08-27)
- (@GermanBluefox) Initial commit
The MIT License (MIT)
Copyright (c) 2025-2026 Denis Haev dogafox@gmail.com
