ico adapter for ioBroker
ICO Pool sensor (by ondilo) allows to monitor the state and temperature of the water in your pool and recommend actions to take.
The adapter connects to the Ondilo cloud service and retrieves all measurements.
Configuration
You can define the poll interval in the settings (in minutes). It is necessary to start the login process in the settings, too.
Attribution
This adapter is not developed or owned by Ondilo but the ioBroker community.
Icon and name of ICO and Ondilo are property of Ondilo.
2.0.3 (2025-05-12)
- (Garfonso) add json state for recommendations
2.0.2 (2025-05-12)
- (Garfonso) ignore done recommendations
2.0.1 (2025-05-12)
- (Garfonso) added support for recommendations
- (Garfonso) store refreshed token properly, might solve issues with missed measurements.
- (Garfonso) improved responsiveness of config UI
2.0.0 (2025-05-08)
- (Garfonso) rewrote config UI
- (Garfonso) login works again
- (Garfonso) breaking: needs node 20 or higher now.
1.1.0 (2023-06-20)
- (Garfonso) changed adapter logic, so that known pools are updated even if the pool list update fails.
1.0.0 (2022-07-01)
- (Garfonso) changed adapter to be schedule adapter.
0.0.7 (2022-07-01)
- (Garfonso) more dependencies & administrative stuff.
0.0.6 (2022-07-01)
- (Garfonso) dependencies & updates
0.0.5 (2021-07-30)
- (Garfonso) add necessary admin dependency.
- (Garfonso) Do not use unknown roles.
0.0.4 (2021-07-22)
- (Garfonso) change default poll interval to one hour, because it seems no more measurements are done.
- (Garfonso) fixed issue in polling
0.0.3 (2021-07-20)
- (Garfonso) Rename to ico-cloud
0.0.2 (2021-07-20)
- (Garfonso) initial release
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2025 Garfonso garfonso@mobo.info
