This adapter integrates the HUUM sauna control device into iobroker. The specification of HUUM Devive for the sauna control can be found here. The API description you can find (github.com/horemansp/HUUM)
Parameters
- 1 + 2 User Credentials for HUUM Webpage "https://api.huum.eu/action/home/"
- 3 refresh .. Refresh to load HUUM data from the device
- 4 lightpath .. Optional Lightpath (state) for switching external light. If empty HUUM switch method is used
- 5 AstroLight .. When set the light is automatically switched on by sunset (for outdoor saunas).
Usage example
0.5.0 (2025-02-23)
- updated dependencies
- js-controller
- core
0.4.5 (2023-10-31)
- Fixed login with no sauna defined
- Steamer Error -> setting humdidity to 0, old version otherwise sauna will be switched off
0.4.4 (2023-02-12)
- adapted temp reached when sauna is stopped from the app
- added an offset for temp reached value when use the intelligent sauna mode
0.4.3 (2023-01-31)
- Fixed Switchlight when lightpath is empty
0.4.2 (2022-09-25)
- Fixes on presets, no more states for the setting
0.4.1 (2022-09-25)
- Added new Preset states for steam or dry saunamode
0.4.0 (2022-08-21)
- fixed light external state issue
0.3.9 (2022-08-20)
- added steamerError, when error occurs sauna is switched off and a warning is documented
- saftey issue, reduce targettemperatur when in steam mode
- some minor changes
0.3.8 (2022-08-04)
- Add Sauna Sleep Refresh Time as parameter, when set to 0 there is no traffic otherwise update in minutes
0.3.7 (2022-02-26)
- add Sauna Images -> adapted from icons-mfd-svg Images
- added sleepRefresh when Sauna is switched off to reduce network traffic (30 minutes)
0.3.6 (2022-02-20)
- release script
- fixes
0.3.1 (2022-02-20)
- included automated switch on light
0.3.0 (2022-02-13)
- create stable version
0.2.1 (2022-01-30)
- create npm package
0.2.0 (2022-01-30) - 2022 Release
- minor Version created
0.1.10 (2022-01-30)
- added Trigger (state targetTempReached) when sauna temperature is reached
- Minor bug fixes and code revisions
0.1.7
- starting sauna with target temperature and humidity
- switch on light in sauna (also on separat id)
- subscribe also foreign state id
- minor bugs and code revision
0.1.6
- get sauna status
0.1.0
- initial version
Copyright (c) 2025 Chris besterquester@live.at
