Overview
The ioBroker.hoymiles-ms adapter integrates Hoymiles MicroStorage systems (currently supporting the Hoymiles MS-A2 model) into ioBroker. This adapter enables monitoring and control of your Hoymiles MS-A2 energy storage system through the ioBroker platform.
The Hoymiles MS-A2 is a MicroStorage unit that combines solar inverter and battery storage capabilities. More information about the device can be found here.
Note: This adapter is not affiliated with Hoymiles and is an independent community project.
Features
- Real-time monitoring: Battery status, power consumption, grid interaction
- Energy tracking: Monitor energy production, consumption, and storage
- Grid monitoring: Track grid-connected and off-grid operations
- System statistics: Comprehensive overview of system performance
- Power control: Set and control power output levels
- Multiple device support: Handle multiple MS-A2 units simultaneously
- MQTT communication: Reliable communication via MQTT protocol
Prerequisites
Before setting up the adapter, ensure you have:
- ioBroker system running (Node.js >= 20)
- Hoymiles MS-A2 MicroStorage unit
- S-Miles Home App installed on your mobile device
- Network connectivity between ioBroker and MS-A2 unit
- Free TCP port for MQTT communication (default: 1881)
Adapter Setup and Configuration
Step 1: Install the Adapter
Install the adapter through the ioBroker admin interface:
- Open the ioBroker admin interface in your web browser
- Navigate to the "Adapters" tab
- Search for "hoymiles-ms" in the adapter repository
- Click the "Install" button next to the adapter
Important: Never install ioBroker adapters using npm directly. Always use the ioBroker admin interface for proper installation and dependency management.
Step 2: Configure the Adapter
- Navigate to "Adapters" and find "hoymiles-ms"
- Click on the configuration (gear) icon
- Configure the following settings:
MQTT Server Configuration
| Parameter | Description | Default Value | Notes |
| Client Mode | Enable MQTT client mode | false | Currently not implemented |
| MQTT Network | Network interface to bind to | 0.0.0.0 | Listen on all interfaces |
| MQTT Port | TCP port for MQTT server | 1881 | Avoid conflicts with other MQTT services |
Important Notes:
- The adapter currently operates only in MQTT server mode
- Authentication is not yet supported - ensure your network is secure
- Port 1881 is chosen to avoid conflicts with ioBroker.mqtt (1883) and ioBroker.shelly (1882)
Step 3: Save and Start the Adapter
- Click "Save & Close" in the configuration dialog
- Enable the adapter instance
- The adapter will start and begin listening for MQTT connections
Hoymiles MS-A2 Device Setup
To connect your MS-A2 unit to the ioBroker adapter, you need to configure it using the S-Miles Home App.
Step 1: Open S-Miles Home App
- Launch the S-Miles Home App on your mobile device
- Ensure you're connected to the same network as your MS-A2 unit
Step 2: Access MQTT Configuration
- Navigate to the Configuration page (gear icon in upper right corner)
- Scroll down to find the "MQTT-Service" section
- Enable the MQTT Service
Step 3: Configure MQTT Settings
| Setting | Value | Description |
| Server Address | <ioBroker-IP> | IP address of your ioBroker system |
| Port | 1881 | Port configured in the adapter (default: 1881) |
| Client Prefix | MSA | Optional identifier prefix (default: MSA) |
| Authentication | Disabled | Must be disabled (not yet supported) |
Example Configuration:
- Server Address:
192.168.1.100(replace with your ioBroker IP) - Port:
1881 - Client Prefix:
MSA - Username: (leave empty)
- Password: (leave empty)
Step 4: Apply Settings
- Save the MQTT configuration in the S-Miles Home App
- The MS-A2 unit will restart its MQTT service
- Check the ioBroker logs for connection confirmation
Operation and Data Flow
Data Update Intervals
The MS-A2 unit sends data at different intervals (these are defined by the Hoymiles API and cannot be configured):
- Configuration data: Sent once upon connection establishment
- Real-time data: Updated every 1 second
- System statistics: Updated every 5 minutes
Device Connection Status
- The adapter monitors device connectivity automatically
- Devices are considered offline if no data is received for 30 seconds
- Connection status is displayed in the
info.onlinestate
States Created by the Adapter
The adapter dynamically creates states based on the data received from your MS-A2 unit. States are organized in a hierarchical structure:
Device Information States
| State | Type | Unit | Role | Description |
device.manufacturer | string | - | text | Device manufacturer |
device.model | string | - | info.model | Device model |
device.name | string | - | info.name | Device name |
device.sw_version | string | - | info.firmware | Software version |
device.identifiers | array | - | list | Device identifiers |
Battery States
device.bat_i | number | A | value.current | Battery current |
device.bat_p | number | W | value.power | Battery power |
device.bat_temp | number | °C | value.temperature | Battery temperature |
device.bat_v | number | V | value.voltage | Battery voltage |
device.bat_sts | string | - | text | Battery status |
device.soc | number | % | value | State of charge |
Grid Connection States (Grid On)
device.grid_on.v | number | V | value.voltage | Grid voltage (on-grid) |
device.grid_on.i | number | A | value.current | Grid current (on-grid) |
device.grid_on.f | number | Hz | value.frequency | Grid frequency (on-grid) |
device.grid_on.p | number | W | value.power.active | Active power (on-grid) |
device.grid_on.q | number | Var | value.power.reactive | Reactive power (on-grid) |
device.grid_on.ein | number | Wh | value.energy.consumed | Energy consumed (on-grid) |
device.grid_on.eout | number | Wh | value.energy.produced | Energy produced (on-grid) |
device.grid_on.etin | number | Wh | value.energy.consumed | Total energy consumed (on-grid) |
device.grid_on.etout | number | Wh | value.energy.produced | Total energy produced (on-grid) |
Grid Connection States (Grid Off)
device.grid_off.v | number | V | value.voltage | Grid voltage (off-grid) |
device.grid_off.i | number | A | value.current | Grid current (off-grid) |
device.grid_off.f | number | Hz | value.frequency | Grid frequency (off-grid) |
device.grid_off.p | number | W | value.power.active | Active power (off-grid) |
device.grid_off.q | number | Var | value.power.reactive | Reactive power (off-grid) |
device.grid_off.ein | number | Wh | value.energy.consumed | Energy consumed (off-grid) |
device.grid_off.eout | number | Wh | value.energy.produced | Energy produced (off-grid) |
device.grid_off.etin | number | Wh | value.energy.consumed | Total energy consumed (off-grid) |
device.grid_off.etout | number | Wh | value.energy.produced | Total energy produced (off-grid) |
Inverter States
device.inv.v | number | V | value.voltage | Inverter voltage |
device.inv.i | number | A | value.current | Inverter current |
device.inv.p | number | W | value.power.active | Inverter active power |
device.inv.q | number | Var | value.power.reactive | Inverter reactive power |
device.inv.ein | number | Wh | value.energy.consumed | Inverter energy consumed |
device.inv.eout | number | Wh | value.energy.produced | Inverter energy produced |
device.inv.etin | number | Wh | value.energy.consumed | Inverter total energy consumed |
device.inv.etout | number | Wh | value.energy.produced | Inverter total energy produced |
Real-time Data States
realtime.bat_p | number | W | value.power | Real-time battery power |
realtime.bat_sts | string | - | text | Real-time battery status |
realtime.grid_on_p | number | W | value.power | Real-time grid power (on-grid) |
realtime.grid_off_p | number | W | value.power | Real-time grid power (off-grid) |
realtime.soc | number | % | value | Real-time state of charge |
realtime.sys_bat_p | number | W | value.power | Real-time system battery power |
realtime.sys_grid_p | number | W | value.power | Real-time system grid power |
realtime.sys_load_p | number | W | value.power | Real-time system load power |
realtime.sys_plug_p | number | W | value.power | Real-time system plug power |
realtime.sys_pv_p | number | W | value.power | Real-time system PV power |
realtime.sys_soc | number | % | value | Real-time system state of charge |
realtime.sys_sp_p | number | W | value.power | Real-time system setpoint power |
System Statistics States
system.bat_p | number | W | value.power | System battery power |
system.chg_e | number | Wh | value.energy.consumed | System charge energy |
system.dchg_e | number | Wh | value.energy.produced | System discharge energy |
system.grid_p | number | W | value.power | System grid power |
system.ems_mode | string | - | state | Energy management system mode |
system.plug_in_e | number | Wh | value.energy.consumed | System plug input energy |
system.plug_out_e | number | Wh | value.energy.produced | System plug output energy |
system.pv_e | number | Wh | value.energy.produced | System PV energy |
system.pv_p | number | W | value.power | System PV power |
system.soc | number | % | value | System state of charge |
system.sp_p | number | W | value.power | System setpoint power |
Power Control States
| State | Type | Unit | Role | Access | Description |
power_ctrl.min | number | W | value.power | Read | Minimum power setting |
power_ctrl.max | number | W | value.power | Read | Maximum power setting |
power_ctrl.set | number | W | level.power | Read/Write | Power setpoint (controllable) |
power_ctrl.step | number | W | value.power | Read | Power adjustment step size |
Information States
info.online | boolean | - | indicator.reachable | Device online status |
info.ip | string | - | info.ip | Device IP address |
info.timestamp | number | - | date | Last data timestamp |
device.rssi | number | db | value | Wi-Fi signal strength |
EMS Control States
| State | Type | Role | Access | Values | Description |
ems_mode.command | string | state | Read/Write | general, mqtt_ctrl | EMS mode control |
Power Control Functionality
The adapter provides power control capabilities through specific writable states:
Setting Power Output
To control the power output of your MS-A2 unit:
- Set EMS Mode: First set
ems_mode.commandtomqtt_ctrl - Set Power Level: Write desired power value to
power_ctrl.set - Valid Range: Power value must be between
power_ctrl.minandpower_ctrl.max - Step Size: Use
power_ctrl.stepfor appropriate increments
Example Power Control
// Enable MQTT control mode
setState('hoymiles-ms.0.MSA_12345.ems_mode.command', 'mqtt_ctrl');
// Set power output to 500W (example)
setState('hoymiles-ms.0.MSA_12345.power_ctrl.set', 500);
Power Control Notes
- Power control is only available when the device is in
mqtt_ctrlmode - Power settings are applied immediately by the MS-A2 unit
- Monitor the real-time states to verify power changes
- Return to
generalmode to restore automatic operation
Multiple Device Support
The adapter automatically handles multiple MS-A2 units:
- Each device is identified by its unique client ID
- States are created dynamically for each connected device
- Device objects are organized under separate folders
- Online status is tracked individually for each device
Troubleshooting
Common Issues
Device Not Connecting:
- Verify network connectivity between ioBroker and MS-A2
- Check MQTT server configuration in adapter settings
- Ensure port 1881 is not blocked by firewall
- Verify MQTT settings in S-Miles Home App
States Not Updating:
- Check device online status (
info.online) - Verify timestamp updates (
info.timestamp) - Check adapter logs for error messages
- Restart adapter if necessary
Power Control Not Working:
- Ensure EMS mode is set to
mqtt_ctrl - Verify power value is within min/max range
- Check that device is online and responding
- Monitor real-time states for changes
Log Analysis
Enable detailed logging by setting the adapter log level to "debug" or "silly":
- Info level: Connection events and basic operations
- Debug level: Detailed MQTT communication
- Silly level: All MQTT messages and state updates
Network Requirements
- Port 1881/TCP: Must be accessible from MS-A2 to ioBroker
- Firewall: Ensure MQTT traffic is allowed
- Network stability: Stable connection required for reliable operation
FAQ
Q: Can I use a different MQTT port? A: Yes, configure any free port in the adapter settings and update the MS-A2 configuration accordingly.
Q: Does the adapter support authentication? A: Not yet. Authentication support is planned for future releases.
Q: Can I monitor multiple MS-A2 units? A: Yes, each unit will appear as a separate device with its own states.
Q: How often is data updated? A: Real-time data updates every second, system statistics every 5 minutes (controlled by Hoymiles API).
Q: Can I control charge/discharge schedules? A: Currently, only power output control is supported. Advanced scheduling may be added in future versions.
Q: What happens if the network connection is lost? A: The adapter will detect offline devices and mark them accordingly. Data will resume when connection is restored.
Q: Are there any limitations? A: The adapter is currently limited to read-only monitoring and basic power control. Advanced features depend on Hoymiles API capabilities.
Support and Contributing
For issues, questions, or contributions:
- GitHub Issues: Report issues here
- ioBroker Forum: Community support and discussions
- Documentation: This document and inline code comments
If you like this adapter, please consider a donation:
This adapter is an independent community project and is not affiliated with Hoymiles.
0.2.2 (2026-01-10)
- (mcm1957) Subscription code has been fixed to allow operation with hoymiles mqtt v3.0
- (mcm1957) NOTE: TOU topics are not yet supported and raising warnings currently.
0.2.1 (2026-01-09)
- (mcm1957) ignore empty and invalid payloads. [#90]
0.2.0 (2025-08-23)
- (mcm1957) States are created dynamically now. So no states should be created if a system does not provide data for it (i.e slave micro storage).
- (mcm1957) State values are reset during startup now to prevent stale information.
- (mcm1957) Support to control power consumption and delivery has been added.
0.1.2 (2025-08-03)
- (mcm1957) Warnings raised from slave systems have been removed
0.1.1 (2025-07-27)
- (mcm1957) Handling of configuration has been corrected
- (mcm1957) Translations have been adapted
0.1.0 (2025-07-26)
- (mcm1957) initial release
Copyright (c) 2025-2026 mcm1957 mcm57@gmx.at
