IO Broker Adapter that supports all haus-bus.de components.
For a documentation about the supported hardware and IO Broker integration please check
www.haus-bus.de/iobroker
Installation
This adapter is available as stable release in the official ioBroker catalog.
It's recommended to install it directly from the catalog within ioBroker.
If you need a newer version than available in the official ioBroker catalog you can also directly install this version here from github.
If you are facing any problems or bugs please contact info@haus-bus.de
Setup
The HausBus.de adapter is ready to use without further configurations. It is automatically searching for haus-bus.de components using UDP broadcast requests. Its mandatory to have at least one haus-bus.de component with a network interface (for example any relay module) that is connected to the same network like io broker. Any further components can be connected by RS485 to the module with ethernet gateway.
1.7.0 (2026-08-03)
- Support for wiegand RFID readers
1.6.14 (2026-05-03)
- fixed faulty detection of GIRA multi buttons
1.6.12 (2026-03-28)
- support for new 4 channel relay module and 2 channel shutter module
1.5.2 (2025-12-23)
- support for WLAN socket
1.4.11 (2024-10-01)
- removed js-controller as dependency
Copyright (c) 2026 Hermann Hoeschen info@haus-bus.de
