This adapter can discover devices followed hass mqtt discover protocol
Current Release
0.0.7
SchumyHao
ioBroker.hass-mqtt
hass-mqtt adapter for ioBroker
This adapter can discover devices followed hass mqtt discover protocol.
Supported Homeassistant domain
  • switch
  • sensor
adapter configuration
You need create another MQTT instance works with this adapter. This MQTT instance can working as Client or Broker.
  • bind mqtt instance ID: select created MQTT instance ID.
  • homeassistant prefix : The prefix defined in homeassistant MQTT protocol, default value is homeassitant.
mqtt instance configuration
Use as Client
In this situation, mqtt instance work as mqtt client. You need install mqtt broker manually.
Configuration like this
Use as Broker
In this situation, mqtt instance work as mqtt broker. Make sure you have stopped other mqtt broker running on same host on same port.
Confinguration like this
Hass-MQTT适配器
此适配器可以发现并接入局域网内符合Homeassistant规定的MQTT协议规范的设备。
已支持的Hass domain
  • switch
  • sensor
适配器配置
此适配器需要另行创建一个MQTT实例配合使用。MQTT实例可以是客户端或者服务器模式。
  • 绑定MQTT实例ID: 选择另行创建的MQTT实例ID
  • homeassistant前缀:homeassistant规定的MQTT协议的前缀,默认为homeassitant。
MQTT实例的配置
工作为客户端模式
如果局域网内已经有MQTT服务器,可以创建一个mqtt客户端实力并绑定到此适配器。
配置方式如下图
工作为服务器模式
如果局域网内没有MQTT服务器,需要在当前主机上创建MQTT服务器。 需要注意配置的MQTT端口不可以被当前主机上的其他程序占用。
配置方式如下图
0.0.7 (2019-06-16)
  • Fix multi map issue
0.0.6 (2019-06-13)
  • fix event storm issue
0.0.5 (2019-05-18)
  • update npm
0.0.4 (2019-05-18)
  • select mqtt instance, not type it name
0.0.3
  • (SchumyHao) Update admin page
0.0.2
  • (SchumyHao) Add switch device support
0.0.1
  • (SchumyHao) initial release
Copyright (c) 2019 SchumyHao
