Air conditioners Gree and C&H
Adapter for Gree and C&H conditioners
Current Release
4.0.0
Serhiy Krasovskyy
Supported devices
All devices which can be controlled via EWPE Smart app should be supported, including:
  • Gree Smart series
  • Cooper&Hunter: Supreme, Vip Inverter, ICY II, Arctic, Alpha, Alpha NG, Veritas, Veritas NG series
  • EcoAir X series
  • ProKlima
Please note that new air conditioners, and possibly old ones, will not work without internet access. They simply stop responding to adapter requests.
4.0.0 (2026-08-28)
  • Migrated the admin tab from jQuery/Materialize to React (MUI 6 / @iobroker/adapter-react-v5)
  • The admin tab is now translated into all 11 adapter languages
  • Errors reported by the adapter are shown in the tab instead of only in the browser console
  • The admin tab now detects the running adapter instance instead of always using instance 0
  • The admin tab now follows the light/dark theme of the admin UI
3.0.3 (2026-06-01)
  • Fixed adapter runtime dependencies and updated CI workflow
3.0.2 (2026-05-28)
  • Filtered network-related errors from Sentry reporting
3.0.1 (2026-05-28)
  • Fixed i18n translation files
3.0.0 (2026-05-25)
  • Migrated adapter source code to TypeScript
  • Updated build pipeline to use build-adapter ts (esbuild + tsc)
  • Updated CI/CD workflow to run on all branches with explicit build steps
2.0.9 (2026-05-21)
  • Adapter requires node.js >= 22 now
  • Fixed connection status indicator incorrectly showing connected when no devices are bound
  • Fixed fan speed cycling button skipping the maximum speed level
  • Fixed memory leak: UDP event listener not removed on request timeout
  • Fixed maintain-room-temperature (StHt) state never being polled from the device
  • Fixed potential null reference errors when reading adapter states
  • Closed UDP sockets on adapter shutdown
Acknowledgments
  • tomikaa87 for reverse-engineering the Gree protocol
  • stas-demydiuk for code of DeviceManager
  • Sizenko Alexander for Digital-7 fonts
  • [cont1nuity] for adding AES-GCM encryption
Copyright (c) 2025-2026 Serhiy Krasovskyy xhunter74@gmail.com
