G-Homa WiFi plugs
Control G-Homa WiFi plugs
Current Release
0.5.3
AlCalzone
ioBroker adapter for G-Homa Wifi plugs. Provides a local command server so the plugs don't phone home anymore. The inclusion of plugs has to be performed with the app for now, but will soon be supported over ioBroker on WiFi-enabled devices.
0.5.3 (2020-05-31)
  • (AlCalzone) Added more translations
0.5.2 (2020-05-08)
  • (AlCalzone) Don't log plug added for known plugs
0.5.1 (2019-10-10)
  • (AlCalzone) Defined missing info.connection object
0.5.0 (2019-08-09)
  • (AlCalzone) Improve detection of G-Homa devices
0.4.0 (2018-07-31)
  • (AlCalzone) Avoid overwriting the name of existing objects
0.3.2 (2018-06-28)
  • (AlCalzone) Check the existence of energy measurements instead of the plug type to determine if objects should be created.
0.3.1 (2018-06-19)
  • (AlCalzone) Reduce rewriting of state objects. This limits log spam when a history adapter is active on this adapter's states.
0.3.0 (2018-01-28)
  • (AlCalzone) Support for multiple network interfaces
0.2.0 (2018-01-11)
  • (AlCalzone) Experimental support for plugs with energy measurement
0.1.2
  • (AlCalzone) Fixed bug with inclusion in admin UI
0.1.1
  • (AlCalzone) Fixed errors on NodeJS 4.x
0.1.0
  • (AlCalzone) Added device management functions
  • (AlCalzone) Fix alive/dead detection
0.0.4
  • (AlCalzone) Fix reconnection of plugs after power loss
0.0.3
  • (Apollon77) Updated adapter testing
0.0.2
  • (AlCalzone) Improved support for older NodeJS versions
0.0.1
  • (AlCalzone) initial release
The MIT License (MIT)
Copyright (c) 2017-2020 AlCalzone d.griesel@gmx.net
