EPSON EcoTank ET-2750 adapter for ioBroker
This adapter read tank level and other information from EPSON EcoTank ET-2750 and store in ioBroker.
EPSON EcoTank ET-4750 is also supported (tested by Homoran)
EPSON EcoTank ET-3750 is also supported (tested by christofkac)
EPSON EcoTank ET-2721 is also supported (tested by mikepiko)
EPSON WORKFORCE WF-3620DWF is also supported (tested by HReimann)
Credits
This adapter would not have been possible without the great work of @o0Shojo0o (https://github.com/o0Shojo0o), who developed former releases of this adapter.
How to report issues and feature requests
Ideally, please use GitHub issues for this, with the best method achieved by setting the adapter to Debug log mode (Instances -> Expert mode -> Column Log level). Then retrieve the logfile from disk via the 'log' ioBroker subdirectory, not from Admin, which will cut lines.
Configuration
- Create a new instance of the adapter
- Fill the URL/IP and port of the EPSON EcoTank ET-2750
- Configur ther Synctime (default 10 minutes)
- Save the settings
1.1.0 (2026-03-06)
- (iobroker-bot) Adapter requires node.js >= 20 now.
- (copilot) Adapter requires js-controller >= 6.0.11 now
- (copilot) CI/CD: Migrated to ESLint 9 with @iobroker/eslint-config
1.0.1 (2024-10-26)
- (simatec) Admin-UI has been adapted for small displays.
- (mcm1957) Dependencies have been updated.
1.0.0 (2024-10-19)
- (mcm1957) Adapter has been moved to iobroker-community-adapter organisation.
- (mcm1957) Adapter requires js-controller 5, admin 6 and node.js 20 now.
0.0.12 (2022-06-09)
- (o0Shojo0o) fix ETIMEDOUT error
0.0.11 (2021-08-24)
- (o0Shojo0o) fix name for Workforce 3620
- (o0Shojo0o) fix firmware for Workforce 3620
The MIT License (MIT)
Copyright (c) 2024-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2023 Dennis Rathjen dennis.rathjen@outlook.de
*Dank an pix und rr0v1 für die Vorlage
