Energiefluss - erweitert
This adapter provides a dynamic and animated visualization of energy flows for all connected elements in your smart home. It supports sources like photovoltaics, storage systems (batteries), household consumption, grid import/export, electric vehicle charging, and other energy-consuming or generating devices. Each flow is represented with clear bi-directional lines, animation dots and real-time values, allowing you to easily monitor and analyze energy distribution. You can customize icons, colors, and layout, and even use formulas to calculate derived values, giving you a flexible and fully interactive energy management dashboard.
Current Release
0.8.3
SKB
energiefluss-erweitert adapter for ioBroker
Documentation
0.8.3 (2026-08-07)
  • Added: Animation duration for 'Power-saving'-mode editable. Defaults to 1200ms.
  • Added: Rectangels can now be rotated and have 4 more connection points in the corner, which appear when the element is rotated >0°
  • Added: Faster and more accurate line-rendering
  • FIX: Some small fixes and improvements
0.8.2 (2026-03-25)
  • FIX: Adapter was appearing on welcome screen overview (should only be used for pro) (#429)
  • FIX: Menubar has loading animation, when opening the workspace the first time while tour is displayed
  • FIX: When using Animation dependency 'Dots' or 'Duration' the animation was to heavy - regulated to smoother blend
  • FIX: Animation dependency 'Dots' once power is on the line, minimal one dot is displayed. The threshold can be used, to manage the appearance of the first dot.
  • FIX: Fading out Context-menu on live view, if touch-move is detected
  • Added: Improved 'Power-saving'-mode to not use static times instead of calculating possible animation Frames
  • Added: Context-Menu on live view is now disabled by default - to enable it again, change it in settings area
0.8.1 (2025-10-21)
  • FIX: Dialog for line animation overrides was not opening
  • Added: VIS and VIS-2 widget added. Just drag the widget to VIS and set the adapter instance
0.8.0 (2025-10-21)
  • FIX: Editing a datasource was not accepting the new choosen state (#374)
  • FIX: When using Animation dependency 'Dots' or 'Duration' the animation could "jump" during recalculation (now the 'jump' is smoothly animated)
  • FIX: 'Manual value change' of click actions now better detect the value type of the destination source
  • FIX: Line was not hidden when 2 directions and display dependency are enabled
  • Added: A new property 'Distance between the dot blocks' inside 'animation'-tab is available. This setting can be used, to define the distance between dot-blocks
  • Added: Some more error handling for overrides. Now they are checked, if they have the correct format and/or syntax
  • Added: 2 new override properties are available: "addClass" and "removeClass" which allow the user, to add or remove own defined CSS classes
  • Added: The workspace will be centered itself to the current selected element
  • Added: Better support for touch-devices including different modes for moving the workspace and editing elements
  • Added: Few language and design corrections, code optimization
  • Added: Right Clicking or long press on liveview opens a context menu, to easily switch between instances or display the configuration
0.7.8 (2025-06-18)
  • Added: Convert a text element to a datasource element
  • Added: Now supports Web-Adapter with socket.io adapter configured (#333)
Copyright (c) 2025-2026 SKB info@skb-web.de
