Elero USB Transmitter
Adapter to control Elero devices.
Current Release
1.0.5
Marc
elero-usb-transmitter adapter for ioBroker
Adapter to control Elero devices with the Elero USB Transmitter Stick. You need the usb transmitter stick and have to connect the existing roller shutter motors to the stick. The adapter automatically detects the active channels and adds the devices. In the settings you can set the names for the devices and the interval for the update.
Configuration
  1. USB Stick Device Path: Path to your USB transmitter stick (e.g., /dev/ttyUSB0 or COM3).
  2. Refresh Interval: Time in minutes to refresh the device status.
  3. Device Configs: You can map channel numbers to custom names in the adapter settings.
Usage
The adapter creates a device for each active channel found on the stick. Each device contains the following states:
StateRoleDescription
channeltextThe channel number of the device.
infotextCurrent status information returned by the stick.
openswitchMain control. Set to true to OPEN (UP), false to CLOSE (DOWN).
controlCommandstateSend specific commands directly.
Control Commands
You can write the following values to the controlCommand state:
  • 16: STOP
  • 32: UP
  • 36: Ventilation/Tilt
  • 64: DOWN
  • 68: Intermediate Position
Easy Commands
  • 74: EASY_CHECK
  • 75: EASY_CONFIRM
  • 76: EASY_SEND
  • 77: EASY_ACK
  • 78: EASY_INFO
Status Values
The info state displays the current status of the device. Common values include:
ValueDescription
INFO_UNKNOWNUnknown status (-1).
INFO_NO_INFORMATIONNo information available (0).
INFO_TOP_POSITION_STOPStopped at top position (1).
INFO_BOTTOM_POSITION_STOPStopped at bottom position (2).
INFO_INTERMEDIATE_POSITION_STOPStopped at intermediate position (3).
INFO_TILT_VENTILATION_POS_STOPStopped at tilt/ventilation position (4).
INFO_BLOCKINGBlocking detected (5).
INFO_OVERHEATEDMotor overheaded (6).
INFO_TIMEOUTTimeout (7).
INFO_START_TO_MOVE_UPStarting to move up (8).
INFO_START_TO_MOVE_DOWNStarting to move down (9).
INFO_MOVING_UPMoving up (10).
INFO_MOVING_DOWNMoving down (11).
INFO_STOPPED_IN_UNDEFINED_POSITIONStopped in undefined position (13).
INFO_TOP_POS_STOP_WICH_TILT_POSTop position stop with tilt position (14).
INFO_BOTTOM_POS_STOP_WICH_INT_POSBottom position stop with intermediate position (15).
INFO_SWITCHING_DEVICE_SWITCHED_OFFSwitching device off (16).
INFO_SWITCHING_DEVICE_SWITCHED_ONSwitching device on (17).
Examples
Javascript / Blockly
To open a shutter (Channel 1):
setState('elero-usb-transmitter.0.channel_1.open', true); // Moves UP
To stop a moving shutter:
setState('elero-usb-transmitter.0.channel_1.controlCommand', 16); // STOP command
1.0.7 (2026-07-25)
  • (ioBroker-Bot) Adapter requires js-controller >= 6.0.11 now.
1.0.6 (2026-05-24)
  • Serialize USB access (runExclusive) for getInfo and control commands
  • Retry control commands and reconnect the stick on failure; update info.connection
  • Adjust burst polling after commands (10s interval, 6 runs)
  • Update dependencies
origin/main
1.0.5 (2025-12-31)
  • Fixed reliability issue with fast polling (burst mode)
1.0.4 (2025-12-30)
  • Adjusted release configuration
  • Implemented fast polling after command execution
1.0.3 (2025-12-30)
  • Release script configuration improved (added missing plugins)
  • Bug fix: Status update handling (async + validation)
  • Improvement: Connection retry logic implemented
  • Improvement: All tests converted to TypeScript
Older changelogs can be found there## License
Copyright (c) 2025-2026 marc marc@lammers.dev
