electrolux-aeg adapter for ioBroker
Adapter for Electrolux and AEG
Supported appliances are managed through the official Electrolux and AEG connected appliance services.
Control
electrolux-aeg.0.XXXX.remote
Settings
electrolux-aeg.0.XXXX.control
Every writable capability the appliance reports becomes a state in this channel: dropdowns for capabilities with a fixed list of values, switches for ON/OFF capabilities, numbers with their allowed range, and buttons for write-only triggers. Capabilities nested in a container are named container_capability, for example userSelections_analogTemperature. Writing a state sends the change to the appliance and the value is mirrored back from the appliance on the next update.
Most appliances only accept commands, including remote.START, after remote start was armed on the appliance itself. The adapter cannot switch that on; it logs a warning when the appliance reports remote control as switched off.
Some settings are rejected by the cloud for some models. The write is then logged as a warning and the state falls back to the reported value; use remote.CustomCommand to send a raw payload in that case.
Status
electrolux-aeg.0.XXXX.status
Live Events
electrolux-aeg.0.XXXX.events
Derived states
The adapter computes a few convenience states from the raw payload, so scripts do not have to. They live next to the raw values under electrolux-aeg.0.XXXX.status:
| State | Meaning |
running | A program is in progress. PAUSED and DELAYED_START count as running. |
finishTime | Estimated end of the running program, in milliseconds since the epoch. Empty when no program is running. Only rewritten when the estimate moves by more than a minute. |
cycleFinished | true for the single update in which a program finished. Trigger on the change to true. |
1.0.0 (2026-09-04)
- Breaking: WebSocket updates no longer create a second object tree. Values from
<appliance>.properties.*now live under<appliance>.status.*, and the old tree is deleted on the first start. Update scripts, aliases, VIS and history settings. - Breaking:
status.finishTimeis a number in milliseconds since the epoch instead of an ISO 8601 string, andstatus.timeToEndMinutesis gone -status.properties.reported.timeToEndcarries the remaining time in seconds with a role and a unit. - Breaking: removed the
status.properties.metadatatree and the emptydesired/metadataDesiredhalves of the cloud shadow. The metadata timestamps froze after the first poll; instead every start now stamps the reported values with the moment the appliance changed them. - Breaking: the enums of the capability document are one JSON list state instead of an empty channel per value, 140 objects on one oven. The empty channels of an older version are removed on the first start.
- Added the derived states
status.running,status.finishTimeandstatus.cycleFinished. - Added a
controlchannel with a writable state for every writable capability, so settings no longer have to be sent as a hand writtenremote.CustomCommandpayload. - Well known reported values now carry a role and a unit, so the type detector, VIS and the history adapters can use them.
- The session is kept in the instance data directory and reused after a restart, so a restart no longer needs a new login. The file holds the tokens only, with owner only permissions.
- WebSocket pushes now update the status tree with every derived and control state, not only the
eventschannel, and an upgrade the cloud rejects with a 403 refreshes the access token instead of retrying with the dead one. Connect, close and reconnect moved todebug, the cloud drops an idle connection every ten minutes. - Buttons below
remoteare released after the press,Refreshin particular stayed pressed for good. Control states the appliance does not report, such astargetFoodProbeTemperatureCwithout a probe, are initialized as empty. - The network interface commands never become control states - one of them unregisters the appliance from the account - and a command is logged with a warning when the appliance reports remote control as switched off.
- Failures no longer take credentials or the instance with them: a failed request logs neither the Authorization header nor the password, an answer that does not carry what the next step reads is reported instead of ending in a TypeError, the update interval and the appliance brand are validated, and an error while a WebSocket message or a state change is processed is logged instead of ending the adapter process.
- (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
0.0.14 (2026-08-06)
- Button states (
remote.Refresh,remote.START,remote.STOPRESET) are now write-only (read: false) as required by the ioBroker state role specification. - Sanitize remote command names coming from the cloud API before using them as object IDs; the raw command name is still sent to the API.
- Redact WebSocket debug logs instead of logging the raw payload.
- Await the logout request during unload and give it a shorter timeout than regular requests.
- Update axios to 1.19.0.
0.0.13 (2026-07-04)
- Trim old
common.newsentries for repository review.
0.0.12 (2026-07-04)
- Exclude
CHANGELOG_OLD.mdand test files from npm publishing. - Tighten object ID sanitization to replace commas.
- Remove stale commented-out logout code and document raw/sanitized appliance ID mapping.
0.0.11 (2026-07-03)
- Republish the latest repository review fixes with npm provenance.
- Remove obsolete ESLint and Prettier dependencies after migrating to
@iobroker/eslint-config.
Older changes are documented in CHANGELOG_OLD.md.
Copyright (c) 2023-2026 TA2k tombox2020@gmail.com
