This adapter uses the ecovacs-deebot.js library.
⚠️ Maintenance Status: Community-Driven Project This adapter is now following a Community-Driven maintenance model. The maintainer focuses on the core engine and personally owned devices. Support for all other models depends entirely on community contributions (Pull Requests).
🗺️ Roadmap & Strategy
To ensure long-term maintainability, we are streamlining the adapter's architecture. Note: We are currently in the 1.4.x release cycle.
- Phase 1 (Planned): Final Legacy Support (Adapter v1.5.x / Library v0.9.6)
- This will be the final "safe harbor" for all legacy devices using XML protocols (XMPP/XML or MQTT/XML).
- Once released, no new legacy features will be added.
- Phase 2 (Planned): Modernization (Adapter v2.0.x / Library v1.0.0)
- Transition to a Pure MQTT/JSON stack.
- Complete removal of legacy code to improve performance and stability.
- Breaking Change: Legacy models (e.g., OZMO 930, Deebot 900) will no longer be supported in v2.x.
Models & Support Tiers
Support is divided into tiers based on device availability for the maintainer:
| Tier | Model Series (Examples) | Status |
| 🟢 Active | OZMO 920/950, T8 AIVI, X1 Turbo | Fully Supported. Devices owned by the maintainer |
| 🟡 Community | T10, T20, T30, X2, X8 etc. | Best Effort. Supported via community Pull Requests |
| 🔴 Legacy | OZMO 930, Deebot 900/901 etc. | Maintenance Only. Supported in v1.5.x only |
How to get your model supported?
If you own a modern (MQTT/JSON) model that is currently not supported:
- Check the ecovacs-deebot.js library.
- Provide a Pull Request with the necessary model definitions.
- Requests for new models without a Pull Request will be closed without further notice.
1.4.16 (alpha)
- Breaking change: Bump minimum required version of Node.js to 20.x
- Add more states for air drying timer
- Use adapter-dev module
- Some further improvements and optimizations
- Bumped ecovacs-deebot.js to 0.9.6 (latest beta)
- Bumped several other dependencies
1.4.15 (latest stable)
- Breaking change: Bump minimum required version of Node.js to 18.x
- Bumped ecovacs-deebot.js to 0.9.6 (beta)
- Add state (button) for manually requesting the cleaning log
- Separate mopping and scrubbing mode
- Add states for air drying timer
0.0.1 - 1.4.14
Installation & Prerequisites
- Node.js: >= 20.x (since v1.4.16)
- ioBroker: Stable installation
- Optional:
canvasfor map rendering (see Wiki for details).
Disclaimer
I am in no way affiliated with Ecovacs Robotics Co., Ltd. or yeedi Technology Limited. This is a private hobby project.
MIT License - Copyright (c) 2026 Sascha Hölzel
