danfoss-ally cloud
Connects ioBroker to the Danfoss Ally Cloud API.
Current Release
0.2.20
Stefan Koch
Cloud adapter for Danfoss Ally™ — using OAuth2 (Client Credentials).
Reads temperature, humidity, valve position, and battery data for all devices in your Ally account,
and allows targeted single writes without forced mode changes or chained sequences.
Features
  • Direct connection to the Danfoss Ally Cloud API
  • Automatic OAuth2 token refresh
  • Discovers all registered devices
  • Reads all available sensor and control data (temperature, humidity, battery, valve position, etc.)
  • Converts raw Danfoss values (×0.1) into real units (°C, %)
  • Fully automatic polling with configurable interval
  • Supports single, isolated write commands from ioBroker to the cloud
Highlights
  • Single Writes — each state is sent independently (no automatic mode switching)
  • Smooth Sync Logic
    • Anti-Race (5s): skip one poll right after a local write
    • Hold Window (1min): protect recent local values from overwrite
    • Lag Suppress (15s): ignore temporarily outdated cloud data
    • Soft Refresh (~1.5s): re-fetch only affected states after each write
  • Quiet Logging — info-level for clean operation, debug-level for diagnostics
  • Auto Scaling — temperatures/humidity auto-converted to °C / %
Note: Cloud updates from the Danfoss Ally app may appear in ioBroker with a short delay (1–2min).
Supported Devices
  • Danfoss Ally™ TRV (Radiator thermostats)
  • Danfoss Icon2 RT (Room thermostats)
  • Danfoss Icon2 Controller
  • Danfoss Ally™ Boiler Relay
  • Danfoss Ally™ Gateway
    (other Danfoss devices auto-discovered)
Configuration
Go to Instances → danfoss-ally → Settings
FieldDescription
API Key / SecretYour Danfoss Developer App credentials
Token URLOAuth2 token endpoint (e.g. https://api.danfoss.com/oauth2/token)
API Base URLe.g. https://api.danfoss.com/ally
ScopeOptional OAuth2 scope (e.g. read write)
Polling IntervalDefault 300s
Shorter intervals update faster but create more API traffic. 30–60s is a good balance.
API Key:      your-client-id
API Secret:   your-client-secret
Token URL:    https://api.danfoss.com/oauth2/token
API Base URL: https://api.danfoss.com/ally
Polling:      300
States
Each discovered device creates a device tree: danfoss-ally.0.<device_id>.*
Status vs Control States
The adapter separates read-only status values from writeable control values.
Status channel
danfoss-ally.0.<deviceId>.status.*
These states mirror values received from the Danfoss Cloud API.
Properties:
  • read: true
  • write: false
Do not write to these states from scripts.
Examples:
  • status.temp_current
  • status.temp_set
  • status.mode
  • status.humidity_value
  • status.battery_percentage
Control channel
danfoss-ally.0.<deviceId>.control.*
These states are intended for user interaction and can be written from scripts or Blockly.
Properties:
  • read: true
  • write: true
Examples:
  • control.temp_set
  • control.manual_mode_fast
  • control.mode
  • control.child_lock
The adapter automatically sends commands to the Danfoss Cloud and updates the corresponding status values.
Reading examples
StateDescriptionUnit
status.temp_currentCurrent temperature°C
status.humidity_valueRelative humidity%
status.battery_percentageBattery level%
status.modeCurrent mode (auto, manual, at_home, …)
status.work_state, status.output_status, status.faultStatus or error
status.upper_temp / status.lower_tempTemperature limits°C
All numeric values are scaled from ×0.1 → °C/% automatically.
Writing
The adapter supports targeted writes to each controllable state without automatic mode changes.
This gives you full control in Blockly, JavaScript, or custom logic scripts.
Writable stateExpected value / behavior
control.temp_setTarget temperature (°C, 0.5steps; sent ×10)
control.manual_mode_fastFast manual setpoint command / fallback for Ally TRVs
control.at_home_setting, control.leaving_home_setting, control.pause_setting, control.holiday_settingPreset temperatures
control.modemanual, at_home, leaving_home, pause, holiday, auto
control.child_locktrue / false
control.SetpointChangeSourceExternally or schedule
Adapter does not auto-switch modes when writing setpoints — you decide in your logic.
Example (Blockly / Script)
// Manual mode
setState("danfoss-ally.0.<id>.control.mode", "manual");
setState("danfoss-ally.0.<id>.control.temp_set", 21.5);
// At home
setState("danfoss-ally.0.<id>.control.mode", "at_home");
setState("danfoss-ally.0.<id>.control.at_home_setting", 21.0);
// Leaving home
setState("danfoss-ally.0.<id>.control.mode", "leaving_home");
setState("danfoss-ally.0.<id>.control.leaving_home_setting", 19.0);
// Pause
setState("danfoss-ally.0.<id>.control.mode", "pause");
setState("danfoss-ally.0.<id>.control.pause_setting", 5.0);
// Holiday
setState("danfoss-ally.0.<id>.control.mode", "holiday");
setState("danfoss-ally.0.<id>.control.holiday_setting", 10.0);
// Child lock
setState("danfoss-ally.0.<id>.control.child_lock", true);
// Explicit source (usually not needed)
setState("danfoss-ally.0.<id>.control.SetpointChangeSource", "Externally"); // or 'schedule'
Write commands must target the control.* states.
The status.* states are read-only mirrors from the Danfoss Cloud.
Synchronization Logic
MechanismDurationPurpose
Anti-Race5sSkip one poll after local write
Hold1minPrevent cloud overwrite of local writes
Lag Suppress15sIgnore stale cloud data
Soft Refresh~1.5sRe-fetch only affected states
These mechanisms ensure smooth synchronization between ioBroker and the Danfoss Cloud without flickering or value loops.
Logging
The adapter provides detailed debug-level information for diagnostics but remains quiet during normal operation.
  • ack=true updates are ignored silently
  • HOLD, MATCH, SUPPRESS → debug-level, harmless diagnostics
  • After the initial inventory run, poll debug logs only list real value changes
  • API errors (HTTP 400/401) retried automatically (logged at debug)
  • Clean debug-level summary after every poll:
Poll Summary Example
CHANGES bf0a...: temp_set: 25 -> 30, manual_mode_fast: 25 -> 30
Updated 13 devices. Mode=poll, Changed=2, Skipped=253, Held=0, AckFixed=0
Skipping poll (anti-race pause 5000ms)
Example Log Output
🔄 Starting Danfoss Ally adapter...
🔑 Refreshing OAuth2 token...
✅ Token acquired. Expires in ~3599 s
📡 Found 13 devices, updating states...
✅ Updated 13 devices from Danfoss Ally Cloud.
⏱ Polling interval set to 300 s
Token Handling
  • Uses OAuth2 Client Credentials Flow
  • Token auto-request on startup, refresh before expiry
  • On 401 Unauthorized: refresh + retry once
  • Tokens kept in memory, never stored
  • Optional scope / audience supported
  • All token events visible in debug log
API Endpoints
The adapter communicates with the Danfoss Ally Cloud API (base URL configurable).
MethodEndpointPurpose
POST/oauth2/tokenRequest access token
GET/devicesDiscover devices
GET/devices/{id}/statusRead device telemetry
GET/devices/{id}Fallback for missing status
POST/devices/{id}/commandsSend single write command
Headers:
Authorization: Bearer <token>
Content-Type: application/json
Optional: X-App-Key, X-Tenant-Id, etc.
Error Handling:
  • 400: invalid header/value → logged
  • 401: token refresh + retry
  • 5xx: retried next poll
  • Temperature writes auto-scaled ×10 (e.g. 21.5 → 215)
Polling
  • Default: 300s (configurable)
  • Updates only changed values
  • Includes all anti-race / hold / lag / soft-refresh logic above
  • Info summary after each poll shows changed, skipped, and held states
Writes
  • temp_set first tries a combined SetpointChangeSource + temp_set command
  • Ally TRVs also get manual_mode_fast when the datapoint exists, because some devices report the manual setpoint there
  • Polling updates status.* only; control.* remains a pure write channel to avoid feedback loops
  • Mode + temperature must be written separately
  • Values are clamped to allowed limits, scaled ×10
  • child_lock: tries 0/1, retries true/false on 400 error
  • SetpointChangeSource: optional; temp_set attempts "Externally" for Ally TRVs
  • If the cloud later reports the old setpoint again, the adapter logs a warning instead of silently accepting it
All send, retry, and confirm logs appear at debug level.
0.2.20
  • Reduced debug log noise after startup: repeated polls now log only real value changes
  • Removed repeated per-device debug inventory lines after the first poll
  • Avoided object-valued status writes from fallback responses
  • Added Boiler Relay fallback objects when the Danfoss API lists the relay but returns no status entries
  • Resolved ioBroker repository checker warnings for Prettier config, ESLint devDependency, translated news entries, workflow concurrency, and tracked ignored tool files
  • Updated GitHub Actions workflow dependencies from the open Dependabot PRs
0.2.19
  • Stopped polling from writing cloud values back into control.* states to avoid feedback loops with Loxone/scripts
  • Added state.from to debug write logs so external write sources can be identified
  • Added direct status fallback for devices that are listed without status values, improving Boiler Relay datapoints
  • Reduced poll debug noise: the initial run still logs all SET lines, later polls summarize changed values per device
0.2.18
  • Improved Ally TRV setpoint writes by additionally sending manual_mode_fast when available
  • Added explicit warnings when the Danfoss Cloud does not confirm the requested setpoint
  • Improved device naming/detection for relay-like devices so the Boiler Relay is easier to identify
0.2.17
  • Improved Ally TRV temp_set writes by trying SetpointChangeSource=Externally and temp_set as one combined command first
  • Falls back to temp_set only if Danfoss rejects the combined command
  • Fixed control.switch subscriptions for Icon2 / Boiler Relay writes
  • Added alias handling for Occupied_Setpoint
  • Fixed jsonConfig header validation warning
0.2.16
  • Fixed temp_set for Ally TRVs (SetpointChangeSource=Externally auto-sent)
  • Fixed wrong path for lower_temp/upper_temp clamp
  • Fixed OccupiedSetpoint scaling (÷100 instead of ÷10)
  • Added type hints for 16 new data points (MeasuredValue, pi_heating_demand, window_state, etc.)
  • Icon2 switch state is now writable
  • Fixed jsonConfig admin validation warning (missing size property)
  • Added Boiler Relay to supported devices
Development
npm i
node main.js
or install via ioBroker development tooling.
Copyright (c) 2025-2026 Author Stefan8485@me.com
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
