Blustream AV Switcher
Control Blustream AMF/MFP/WMF series AV switchers via RS232 or IP
Current Release
0.5.3
Alan Paris
Blustream AV Switcher adapter for ioBroker
Control Blustream AMF/MFP/WMF series AV presentation switchers via RS232 serial or IP/Telnet connection.
Supported Devices
ModelDescriptionConnection
AMF42AU4x2 Advanced Multi-Format SwitcherIP (Telnet)
MFP626x2 4K Multi-Format Presentation SwitcherIP (Telnet)
MFP724x2 Multi-Format Presentation SwitcherRS232 / IP
MFP1125x2 Multi-Format Presentation Switcher with HDBaseTIP (Telnet)
WMF51Wireless Media PresenterIP (Telnet)
WMF72Wireless Media Presenter with Dual DisplayIP (Telnet)
C66 / C886x6 / 8x8 Contractor HDBaseT MatrixRS232 / IP
Expanded range (v0.5.3) — routing, output enable, PoC and presets:
FamilyModelsType
Contractor C (CSC)C44-KIT, C44CS-KIT, C66CS, C88CSHDBaseT matrix
HMXLHMXL42ARC, HMXL44CS, HMXL44ARC, HMXL66ARC, HMXL88ARC, HMXL88-V2HDBaseT matrix
HMX 18GHMX44-18G-KIT, HMX88-18GHDBaseT 3.0 matrix
Platinum (PLA)PLA88CS, PLA88ARC-V2, PLA88L-V2HDBaseT matrix
Pro / Custom-ProPRO48HBT70(CS), PRO88HBT70CS, PRO88HDMI-V2, PRO16HBT70CS, CUSTOMPRO-HUB, CUSTOMPRO-HUB16HDBaseT matrix (up to 16x16 / modular)
CMX (HDMI)CMX42CS, CMX44CS-V2, CMX44AB, CMX88CS, CMX88ABHDMI matrix
MX (HDMI)MX22AB-8K, MX44AB-V2HDMI matrix
SW switchersSW41HDBT, SW41AB-V2, SW41AB-8K, SW42DA, SW21AB-V2, SW21AB-V3HDMI / HDBaseT switch
Video wall / Multi-viewMX44VW, MX44AVW, MV41mode/routing/bezel/MV-audio + HDMI/VGA input select
USB / KVMMX44KVMUSB host↔device routing + presets
These families also gain EDID management (all matrices), CEC control (HMX-18G, SW41HDBT) and audio (HMX-18G audio matrix; Pro-Matrix audio embed/mute). CMX/MX audio follows the video output (no separate control). STATUS feedback (read-back) is parsed for every fixed-width family — routing, output enable, PoC, CEC, EDID, audio matrix, network, video-wall mode and SW42DA Dante master audio — grounded against real device captures. The MX44KVM has its own reply format, of which host routing, GPIO modes and USB cascade are read back (its network table is not). The only exception is MV41, whose STATUS headers have no column separators. Not yet supported: AMF41W (distinct Linux-CLI API), MFP31 and SW12USB (docs not sourced); MX44AVW advanced PIP/rotation and MV41 are provisional. See MODEL-EXPANSION-PLAN.md.
For more information about Blustream products, visit Blustream.
Installation
Install the adapter from the ioBroker admin interface (Adapters → search for "blustream").
Configuration
Connection Settings
The adapter supports two connection types:
IP Connection (Telnet)
  • IP Address: The IP address of your Blustream device
  • Port: TCP port (default: 23 for Telnet)
  • Telnet IAC Negotiation: Enable if your device uses Telnet protocol negotiation
RS232 Serial Connection
  • Serial Port: Path to serial device (e.g., /dev/ttyUSB0 on Linux, COM3 on Windows)
  • Baud Rate: Serial communication speed (typically 57600 for MFP series)
Device Model
Select your specific Blustream device model from the dropdown. The adapter will automatically configure the available states and controls based on the selected model's capabilities.
Polling
  • Polling Interval: How often to query the device for status updates (in milliseconds, default: 30000)
  • Reconnect Interval: Time between reconnection attempts if connection is lost (in milliseconds, default: 10000)
States and Controls
The adapter creates states dynamically based on the selected device model. Common states include:
Information (info.*)
  • info.connection - Device connection status
  • info.model - Device model identifier
Commands (commands.*)
  • commands.raw - Send raw commands to the device
  • commands.getStatus - Request current device status
Output Control (output.*)
  • output.X.source - Select input source for output X
  • output.X.enabled - Enable/disable output X
  • output.X.videoMute - Blank the video on output X
Audio (audio.*)
  • audio.volume - Master volume level
  • audio.mute - Master mute
System Control (system.*)
  • system.power - Power on/off
  • system.beep - Enable/disable button beep
  • And more depending on device model...
Network Settings (network.*)
  • network.dhcp - DHCP enable/disable
  • network.ip - Device IP address
  • network.gateway - Gateway address
  • network.subnet - Subnet mask
Features by Model
FeatureAMF42AUMFP62MFP72MFP112WMF51WMF72C66C88
Network ControlYesYes-YesYesYesYesYes
RS232 Control--Yes---YesYes
Matrix Routing------YesYes
CEC ControlYes-------
MicrophoneYesYes------
PresetsYes-----YesYes
Picture ControlYes-------
WiFi Control----YesYes--
Multiview----YesYes--
HDBaseT---Yes--YesYes
PoC (per output)------YesYes
Troubleshooting
Connection Issues
  1. IP Connection fails: Verify the IP address and port. Ensure no firewall is blocking the connection. Try disabling Telnet IAC negotiation if your device doesn't support it.
  2. RS232 Connection fails: Check the serial port path and baud rate. Ensure you have permissions to access the serial port (on Linux, add your user to the dialout group).
  3. Commands not working: Some devices require a brief delay between commands. The adapter handles this automatically with a command queue.
Debug Mode
Enable debug logging in the ioBroker admin to see detailed communication with the device:
  1. Go to Instances
  2. Click the adapter instance
  3. Set log level to "debug"
0.5.3 (2026-08-03)
  • (Alan Paris) Added support for 39 further Blustream models, taking the total to 47: the HDBaseT matrices (C-series and C-CS, HMXL, HMX-18G, PLA/Platinum, Pro and Custom-Pro, up to 16x16), the HDMI matrices (CMX/MX), the SW-series HDMI and HDBaseT switchers, the video-wall and multi-view processors (MX44VW, MX44AVW, MV41) and the MX44KVM USB/KVM matrix
  • (Alan Paris) Routing, output enable, PoC and preset recall now follow each model's own command form, so the differing firmware families (spaced OUT 01 FR 04 versus OUT01FR04, the three PoC verbs, single-output switches without an output index) are each addressed correctly
  • (Alan Paris) Added per-input EDID management on all matrices, CEC actions on the HMX-18G and SW41HDBT, the HMX-18G audio matrix, Pro-Matrix audio embedding, video-wall mode and bezel compensation, and USB routing on the MX44KVM
  • (Alan Paris) Device status read-back is now parsed per model family from the fixed-width STATUS/INSTA/OUTSTA/CTRLSTA/AUDSTA tables, matching columns by header name so power, routing, output enable, PoC, CEC, EDID, audio, network and video-wall values are reflected in the states. Unrecognised tables are ignored rather than guessed at
  • (Alan Paris) Added the device command references and the captured status replies used to build the parser under protocols/, plus unit tests that replay every capture
  • (Alan Paris) Pre-release review fixes: EDID commands now use each model's own spacing (the CMX/MX matrices document only the unspaced form); command confirmations naming an output the model does not have no longer create a stray state; status replies whose divider is prefixed by the device prompt (MX44VW/MX44AVW) no longer stall the command queue or grow the captured-response buffer without limit; a status column reported as N/A now leaves its state untouched instead of writing "off"; and stopping the instance no longer schedules a reconnect after shutdown
0.5.2 (2026-08-03)
  • (Alan Paris) Fixed the state tree keeping the previous model's controls after the device model was changed: the internal model-change check compared the model against a value the adapter had just overwritten, so the cleanup never ran. An MFP112 configured after the default MFP72, for example, was left without the HDBaseT input on output.N.source
  • (Alan Paris) Existing instances repair themselves on first start after the update: a new info.stateSchema state records the layout version of the state tree, and the tree is rebuilt once when it is out of date. State values are repopulated by the next device poll. Note that the rebuild recreates the objects, so any per-state history/logging settings on the adapter's states have to be reapplied
  • (Alan Paris) The WiFi password is no longer stored in clear text in info.lastSent or written to the debug log when it is set
  • (Alan Paris) Device responses reporting an output number the configured model does not have (including an echo of the route-all command) no longer create a stray output state
  • (Alan Paris) Corrected the documented state list and the per-model feature table in the README, and added the missing system parent object
0.5.1 (2026-07-16)
  • (Alan Paris) Every state object now defines a default (def) value, so states have a defined initial value before the first device poll
  • (Alan Paris) Admin config: all device-model descriptions and option labels are now translatable and provided in all 11 ioBroker languages
0.5.0 (2026-07-16)
  • (Alan Paris) Added support for the Blustream C66 (6x6) and C88 (8x8) Contractor HDBaseT matrices: crosspoint routing across up to 8 outputs, route-all (output.allSource), per-output enable, per-output PoC, and 9 presets
  • (Alan Paris) Added a dedicated parser for the C66/C88 fixed-width STATUS/OUTSTA tables and the [SUCCESS]/[FAIL] command confirmations, so routing, enable, PoC and network states reflect the device
  • (Alan Paris) Scaler, resolution and audio states are no longer created for the C66/C88 crosspoint matrices (they have no scaler/audio path), so the object tree only exposes controls the device actually implements
  • (Alan Paris) Added protocols/c66.txt documenting the C66/C88 RS-232 / Telnet command set (verified against FW V1.0.1d)
0.4.2 (2026-07-04)
  • (Alan Paris) WiFi password state is now write-only (read: false) so the value cannot be read back from the object tree once set
  • (Alan Paris) Removed the accidentally committed npm pack artifact (.tgz) from the repository
Copyright (c) 2026 Alan Paris alan.paris@scottish.rugby
