Control Blackmagic ATEM video mixers from ioBroker — supports all 21+ ATEM models from Mini to Constellation 4K+.
Description
This adapter controls Blackmagic Design ATEM video mixers over the network. It uses the reverse-engineered ATEM UDP protocol via the atem-connection library, and supports 21+ model variants — from ATEM Mini through Television Studio to Constellation 4K+ — with capability-based state creation that adapts to the connected device.
Features
- Program/Preview switching — change program and preview inputs
- Transitions — Cut, Auto, manual T-bar; Mix / Dip / Wipe / DVE / Sting styles with per-style rates
- Fade to Black — toggle and configure FTB rate
- Upstream Keyers (up to 4 per M/E) — on air, type, fill/key source, mask, fly
- Downstream Keyers (up to 4) — on air, tie, auto, rate, fill/key source
- Aux outputs (up to 48) — source routing
- Audio Mixer — master gain/balance, monitor, per-input gain/balance/mix (Classic + Fairlight)
- Color Generators — hue/saturation/luminance
- Streaming — start/stop, status, cache used (supported models)
- Recording — start/stop, switch disk, duration, remaining space (supported models)
- Media Players — source type, still/clip index, playback control
- Tally — program/preview tally state
- Macros — run, stop, continue, loop, named slots (up to 100)
- Input metadata — short/long names, port type
- Auto model detection — capabilities discovered from the connected device
Requirements
- js-controller >= 6.0.11
- ioBroker Admin >= 7.6.20
- Node.js >= 22
- Blackmagic ATEM switcher with network connectivity
Installation
Install via the ioBroker Admin UI: Adapters → search for blackmagic-atem → install.
Configuration
- Open the adapter instance configuration in ioBroker Admin
- Enter the IP address of your ATEM device
- Choose the model (or leave on Auto Detect)
- Adjust the reconnect interval if needed
- Save and start the adapter
State Tree
info.connection
device.{modelName, productId, videoMode, capabilities}
me[0-3].{programInput, previewInput, inTransition, transitionPosition}
me[0-3].transition.{style, mixRate, dipRate, wipeRate, dveRate, wipePattern}
me[0-3].fadeToBlack.{isFullyBlack, inTransition, rate}
me[0-3].usk[0-3].{onAir, type, fillSource, keySource, maskEnabled, flyEnabled}
commands.{cut, auto, ftb}
dsk[0-3].{onAir, tie, inTransition, rate, fillSource, keySource, auto}
aux[0-47].source
audio.master.{gain, balance, afv}
audio.monitor.{enabled, gain, mute, solo, dim}
audio.inputs.input[N].{gain, balance, mixOption}
audio.commands.resetPeaks
colorGenerator[0-1].{hue, saturation, luminance}
streaming.{status, start, stop, duration, cacheUsed}
recording.{status, start, stop, switchDisk, duration, remainingDiskSpace}
mediaPlayer[0-3].{sourceType, stillIndex, clipIndex, playing, loop, atBeginning}
tally.{programInputs, previewInputs}
macros.{run, stop, continue, isRunning, isWaiting, loop, runningIndex, recordedCount}
macros.slots[0-99].{name, isUsed, trigger}
inputs.input[N].{shortName, longName, inputId, portType}
States are created conditionally based on detected/selected model capabilities. Orphans are cleaned up when the model changes.
Example Usage
// Switch program to camera 1
setState('blackmagic-atem.0.me0.programInput', 1);
// Perform a cut
setState('blackmagic-atem.0.commands.cut', true);
// Start streaming (supported models only)
setState('blackmagic-atem.0.streaming.start', true);
// Run macro 5
setState('blackmagic-atem.0.macros.run', 5);
Input ID Reference
| ID | Source |
| 1–8 | Camera inputs |
| 0 | Black |
| 1000 | Color Bars |
| 2001–2002 | Color Generators 1, 2 |
| 3010, 3011 | Media Player 1, 2 |
| 3020, 3021 | Media Player 1, 2 Key |
| 7001–7002 | Clean Feed 1, 2 |
| 10010, 10011 | Program, Preview |
Protocol Notes
This adapter uses the reverse-engineered ATEM UDP protocol (port 9910), as documented by the open-source community:
The ATEM protocol has no authentication — keep ATEM devices on a trusted, private network.
0.2.9 (2026-07-12)
- (Alan Paris) Made macros.run write-only (it no longer retains the last-triggered index); use macros.runningIndex to read the active macro
- (Alan Paris) Renamed recording.remainingDiskSpace to "Remaining Recording Time" and documented that its value is seconds of available recording capacity, not bytes
- (Alan Paris) Stopped writing audio.master.afvCrossfade on Fairlight models, where the state does not exist
0.2.8 (2026-07-05)
- (Alan Paris) Fixed upstream-keyer mask/fly enable and downstream-key pre-multiplied controls, which were writable but ignored, so they now apply to the switcher
- (Alan Paris) Master audio gain now controls Fairlight mixers correctly (previously it sent a Classic-audio command that Fairlight models ignored)
- (Alan Paris) Hid Classic-only audio controls (master balance/AFV crossfade, monitor enable/solo/dim) on Fairlight models, where they had no effect
- (Alan Paris) Added default values to all dynamically created states
0.2.7 (2026-07-04)
- (Alan Paris) Added a link to the Blackmagic Design ATEM product page in the README
- (Alan Paris) Clamp the reconnect interval in code so out-of-range config values cannot break the timer
- (Alan Paris) Removed the unused
pollIntervalconfig option (the adapter is fully push-based) - (Alan Paris) Removed the unused
audio.master.programOutGainstate
0.2.6 (2026-07-04)
- (Alan Paris) Updated atem-connection to 3.9.0 and dev dependencies (@iobroker/types, rimraf)
- (Alan Paris) Extended tsconfig from @tsconfig/node22 for standardized type checking
- (Alan Paris) Switched Dependabot to cron schedules to distribute update load
0.2.5 (2026-07-04)
- (Alan Paris) Resolved all ESLint warnings (unawaited promises, JSDoc parameter descriptions)
0.2.4 (2026-07-04)
- (Alan Paris) Fixed state roles so writable transition, keyer and media-player selectors, macro run and input info states pass the ioBroker object checker
- (Alan Paris) Removed the legacy flat
transitionStylestate on upgrade - (Alan Paris) Use adapter-managed timers for the reconnect timeout
- (Alan Paris) Updated dependencies for repochecker compliance
0.2.3 (2026-05-21)
- (Alan Paris) Bump minimum Node.js to 22 and CI matrix to 22/24 for ioBroker community submission compliance
- (Alan Paris) Set
common.noGit: trueso the gitignoredbuild/tree does not trip the repochecker - (Alan Paris) Trim
common.newsto only versions published to npm
0.2.2 (2026-05-20)
- (Alan Paris) Switched CI publish to npm trusted publishing (OIDC)
0.2.1 (2026-05-20)
- (Alan Paris) Initial publication to npm registry
0.2.0 (2025-02-04)
- (Alan Paris) Added model selection, transition rates, auxiliary outputs, tally, audio per-input, color generators
0.1.0 (2025-01-29)
- (Alan Paris) Initial release: program/preview switching, DSK/USK, streaming and recording, media players, macros
MIT License — see LICENSE for details.
Copyright (c) 2024-2026 Alan Paris alan.paris@scottish.rugby
