Bidirectional counter
Counter to separate consumption (positive changes) and deliverd (negative changes)
Current Release
2.5.15
BenAhrdt
bidirectional-counter adapter for ioBroker
With this counter, you can select every state of type number in the custom config. The adapter will creates 3 states internal. (cunsumed, delivered and total). consumed will be assigned, if a positive change of the subscribed state will be detected. delivered will be assigned, if a negative change of the subscribed state will be detected. total will be assigned in every case.
e.g. this adapte is usefull to emulate an energymeter with a given ergy value from a foreign device. for instance shelly will set energy of a channel back to zero in case of restart. The adapter will ignor zero and the counter value is saved for using in other adapters / scripts. The counter state will increase up from its saved value, when the shelly energy state increases next time.
2.5.15 (2026-04-05)
  • (BenAhrdt) building desc for id
2.5.14 (2026-04-05)
  • (BenAhrdt) building icon and color for inactive counters in dM card
2.5.13 (2026-04-05)
  • (BenAhrdt) change design of identifier and sort alphabetically
2.5.12 (2026-04-04)
  • (BenAhrdt) improve id and transform back id
2.5.11 (2026-04-04)
  • (BenAhrdt) sort display in card
2.5.10 (2026-04-04)
  • (BenAhrdt) build id removed and building sourcestates improved
2.5.9 (2026-04-04)
  • (BenAhrdt) add deviceManager
2.5.8 (2026-02-28)
  • (BenAhrdt) bugfix 2.0 dependencies
2.5.7 (2026-02-28)
  • (BenAhrdt) bugfix dependencies
2.5.6 (2026-02-28)
  • (BenAhrdt) update dependencies
2.5.5 (2026-02-10)
  • (BenAhrdt) implements max difference value
2.5.4 (2025-11-10)
  • (BenAhrdt) set raw common.writable = false
2.5.3 (2025-11-10)
  • (BenAhrdt) adding raw value for every counted value
2.5.2 (2025-11-06)
  • (BenAhrdt) logging fallback optional as warning
2.5.1 (2025-11-05)
  • (BenAhrdt) New Calculation in case of fallback to zero and go back to some value. Remember the last Value for counting the difference
2.5.0 (2025-10-19)
  • (BenAhrdt) update Authentication NPM
  • (BenAhrdt) update lint to 2.1.0
  • (BenAhrdt) update testing removeing defDependencies
  • (BenAhrdt) update dependencie core
  • (BenAhrdt) update dependencie to node >= 20
  • (BenAhrdt) update testing to 24.x
2.4.0 (2025-02-22)
  • (BenAhrdt) update admin and js-controller dependencies
2.3.0 (2024-12-05)
  • (BenAhrdt) update eslint
2.2.1 (2024-11-26)
  • (BenAhrdt) changed schema and responsive tags
2.2.0 (2024-08-13)
  • (BenAhrdt) Update Dependencies: "js-controller": ">=5.0.19" Check your System before installing new Version
2.1.4 (2024-08-09)
  • (BenAhrdt) changes for check and service Bot
2.1.3 (2023-11-14)
  • (BenAhrdt) debuglogging for changed values added
2.1.2 (2023-11-12)
  • (BenAhrdt) translation for uk added
  • (BenAhrdt) insert check vor node version >= 16
2.1.1 (2023-11-02)
  • (BenAhrdt) correction in jsonconfig schema
2.1.0 (2023-04-06)
  • (BenAhrdt) updated to new releasescript
Copyright (c) 2025-2026 BenAhrdt bsahrdt@gmail.com
