🔌 Matching hardware — the Feeder-Relais timer board
Building a feeder and would rather drop in a ready-made timer board than wire up your own relay? Take a look at the Feeder-Relais (Timer-Ersatzplatine) — a self-build ESP32 timer board that pairs perfectly with this adapter (online overview).
It is a separate, standalone project — independent of the adapter. The board and this adapter correspond with each other, but the two are completely independent of one another: the adapter works fully without the board, and the board works without the adapter.
automatic-feeder adapter for ioBroker
This adapter turns any existing ioBroker switch (a smart plug, a relay, a GPIO output …) into a scheduled automatic feeder. It switches the output on for a defined number of seconds at the times you configure, and can take temperature and the day/night cycle into account so it never feeds at the wrong moment.
This document is a complete manual. If you have never used the adapter before, read it from top to bottom – the Quick start gets you to your first feeding in a few minutes, the rest explains every option in detail.
🇩🇪 Deutsche Anleitung: doc/de/README.md · other languages: see Documentation at the bottom.
Table of contents
- What the adapter does
- Requirements
- Installation
- Quick start
- The settings page in detail
- Objects / data points
- Examples / recipes
- Telegram notifications
- Troubleshooting & FAQ
- Logging & debugging
- Dynamic feeding — background & sources
1. What the adapter does
A "feeding" is simply: switch an output ON → wait a configurable number of seconds → switch it OFF again. For a converted feeder the running motor during those seconds dispenses the food.
The adapter can manage up to 5 switches, each completely independent and each with its own configuration tab named after the switch. Per switch you decide:
- when it feeds – either at fixed times (e.g. 08:00 and 18:00) or in an interval inside a time window (e.g. every 60 minutes between 08:00 and 18:00);
- how long the output stays on (feeding duration in seconds);
- whether to block feeding when the water or air temperature is too low/high;
- whether to restrict feeding to the astronomical day window (sunrise/sunset with per-switch offsets, from a system, shared or per-switch location);
- whether to supervise the switch (check that it really turned on and off) and optionally send a Telegram message about the result;
- whether to reduce or pause feeding during a recurring winter season – optionally with Telegram reminders before it starts and ends;
- whether to adapt the interval and the portion to the water/air temperature automatically (dynamic feeding, Q10 model);
- whether to block feeding when the dissolved oxygen (O₂) is too low;
- up to 3 one-off feeding pauses (absolute date-time periods, e.g. a quarantine after restocking) with a Telegram message at the start and end of each;
- a master pause switch (Suspend feeding now) that instantly suspends all feeding for a switch until you turn it off again, with a Telegram message on each toggle.
You can also trigger a feeding manually at any time – from the adapter's settings page (button with a freely selectable duration) or from a data point (e.g. a button in a VIS view).
Optionally, the adapter integrates the Automatic-Feeder relay board (an ESP32 with three timer buttons and its own web interface). You decide per switch whether it uses such a board; when you enable it for a switch in the general settings, that switch gains a Relay tab where you set the board's network address, test the connection and configure its three button feeding times (S1–S3) directly from the adapter.
Important: the adapter never creates the switch itself. It controls an object that already exists in your ioBroker system. You select that object in the configuration.
2. Requirements
| You need | Details |
| ioBroker with admin ≥ 7.8.23, js-controller ≥ 6.0.11 and Node.js ≥ 22 | Required minimum versions. The configuration page is built with React 19. |
| A switch object | Any writable ioBroker state that turns your feeder on/off – e.g. a smart plug (shelly.0.…, sonoff.0.…, zigbee.0.…), a relay, a script variable. |
| (optional) Geo-coordinates | Used to calculate sunrise/sunset for the per-switch astronomical window. Only needed if a switch uses that window; taken from the ioBroker system settings, one shared position, or configured per switch. |
| (optional) Temperature objects | Existing states with air and/or water temperature, for temperature blocking or dynamic feeding. Assigned per switch on the switch tab. |
| (optional) Oxygen (O₂) objects | Existing states with the dissolved oxygen, to block feeding when it drops too low. Assigned per switch. |
| (optional) A Telegram instance | The official telegram adapter, configured and running, if you want push notifications. |
| Internet access on the ioBroker host | Only for the address search / map in the configuration. Normal operation works offline. |
3. Installation
- In the ioBroker admin, open the Adapters tab.
- Find automatic-feeder in the list and click Install.
- Create an instance of the adapter.
- Open the instance settings (the gear icon) – you should see the configuration page with the General settings tab. If it stays blank, see Troubleshooting.
4. Quick start – your first feeding
The goal: make one switch feed for 5 seconds, right now, to prove everything works.
- Open the settings of the automatic-feeder instance.
- On the General settings tab:
- Under Location, leave Use system settings for all switches selected (only relevant if you later enable the astronomical window). You can also pick a shared location or configure it per switch.
- Scroll down to Switches and click Add switch.
- Give it a Name (e.g.
Koi pond). This name becomes the title of its own tab. - Click the list icon next to Switch object and choose the state that switches your feeder (e.g. your smart plug). Make sure the switch is Active (checkbox on the left).
- Save (the disk/checkmark at the bottom). A new tab named after your switch appears.
- Open that switch tab. At the top under Manual feeding, set a duration (e.g.
5seconds) and click Feed now. The output should turn on for 5 seconds and off again. - Still on the switch tab, set up the real schedule under Feeding schedule (e.g. fixed times 08:00 and 18:00) and the Feeding duration under Feeding action, then Save.
That's it – the adapter will now feed automatically. Everything below explains the options in depth.
5. The settings page in detail
The configuration has a General settings tab plus one tab per switch (created automatically once a switch has a name). If a page does not scroll, drag the window larger or use the scrollbar on the right – all sections are reachable.
5.1 General settings tab
Location (for the astronomical window)
The location is used to calculate sunrise/sunset for the astronomical feeding window that can be enabled per switch (see Restrictions on the switch tab). It is only needed if at least one switch uses that window. Three options:
- Use system settings for all switches – takes latitude/longitude from the ioBroker system configuration (recommended if those are already set). The current values are shown.
- One shared location for all switches – set a single position that all switches use:
- Type an address and press Search. The adapter resolves it (via OpenStreetMap / Nominatim) and places a marker.
- Or click on the map / drag the marker to the exact spot.
- Latitude/longitude can also be typed directly; the map follows.
- Configure the location individually per switch – each switch defines its own location on its own tab (useful when feeding stations, e.g. ponds, are at different places).
The address search runs in the adapter backend, so the instance must be running for it. The map tiles and the search need internet access.
The sunrise/sunset offsets are configured per switch (under Restrictions), and the
calculated times are published per switch as status.sunrise / status.sunset, recalculated
automatically every night.
Switches
The list of feeders (up to 5). For each entry:
- Active (checkbox) – only active switches are scheduled.
- Name – free text; becomes the switch's tab title and the channel name in the object tree.
- Switch object – the existing ioBroker state to control. Use the list icon to browse, or the cross to clear.
Use Add switch to create another (max. 5) and the trash icon to remove one. Removing a switch also deletes its data points.
- This switch uses the Automatic-Feeder relay board (per-switch toggle) – turn this on only for a switch whose feeding station uses the optional Automatic-Feeder relay board (ESP32). When on, that switch gets an additional Relay tab (see 5.4).
5.2 Feed list tab
A central, user-maintained list of your food types, shared by all switches. For each feed you enter:
- Feed name and vendor / dealer,
- pellet size (mm),
- the four standard nutritional values from the manufacturer's analytical constituents — crude protein / fat / fibre / ash (%),
- an optional offer / purchase link (a hidden field, revealed with the link button) for re-ordering online.
Add as many feeds as you like with Add feed and remove them with the bin icon. The list is stored
centrally and is also published as JSON in info.feeds for VIS/widgets. In each switch tab you then
pick, under Currently loaded feed, which of these feeds is currently filled into that feeder — its
name, size and nutrition are exposed as status.activeFeed* and can be switched from the VIS widget too.
5.3 Switch tabs
Each configured switch gets its own tab, titled with its name. It contains the following sections.
Manual feeding
- Manual feeding duration (seconds) – the duration used by the button.
- Feed now – triggers a feeding immediately with that duration. Useful for testing or an extra portion. (Whether it ignores blocks depends on Manual trigger ignores all blocks in Restrictions.)
- The instance must be running and the configuration saved for the button to work.
Feeding schedule
Choose one mode:
- Fixed times – a list of clock times (
HH:mm). Add as many as you like; the feeder runs at each of them every day. Example:08:00and18:00. - Interval within a time window – feed repeatedly inside a window:
- Window start / Window end – e.g. 08:00 to 18:00.
- Interval (minutes) – e.g. 60 → feed at 08:00, 09:00, …, up to the end of the window, every day.
If the astronomical window is enabled (see Restrictions), the fixed window start/end are
replaced by the sunrise/sunset window and are hidden; the interval then runs between sunrise and
sunset. The next planned time is always visible in the status.nextFeeding data point.
Feeding action
- Feeding duration (seconds) – how long the output stays ON during a scheduled feeding.
- On value / Off value – the values written to the switch object. Defaults are
trueandfalse, which fit most smart plugs/relays. If your device expects numbers or text, enter e.g.1/0orON/OFFhere.
Temperature & oxygen sources
Each switch (feeding station) has its own sensors – different ponds/tanks can use different objects:
- Air temperature – tick the box and pick the state that holds this station's air temperature.
- Water temperature – tick the box and pick the state that holds this station's water temperature. This is the primary feeding-zone sensor (place it where the fish actually feed, not at the surface).
- Water temperature (deep) – optional second water sensor (e.g. near the bottom). Only shown once the primary water sensor is enabled. With two sensors you choose a combine mode for dynamic feeding: Feeding zone (shallow only) [default], Average of both, Coldest layer, or Seasonal (uses the shallow sensor while it is at or above a threshold, otherwise the deep sensor). The temperature block always uses the coldest of the two layers. A second sensor only helps in deep, unmixed ponds (a running pump mixes the water and removes any stratification) — see Dynamic feeding — background & sources.
- Oxygen (O₂) – tick the box and pick the state that holds the dissolved oxygen.
Only number states make sense. The current values are mirrored to this switch's status.airTemperature,
status.waterTemperature, status.waterTemperatureDeep, status.oxygen (and status.waterStratification
= shallow − deep) data points. The thresholds are set below (Temperature blocking), and the temperatures
also drive Dynamic feeding.
Only shown for the temperature sources you enabled above (Temperature & oxygen sources). Per switch you can:
- Block by water temperature – set Block if below and/or Block if above (°C).
- Block by air temperature – same, for air.
If the current temperature is outside the allowed range, the feeding is skipped and the reason
is written to status.blockReason. (If a temperature value is unknown, that source does not block.)
Water quality (ammonia / nitrite)
Optionally the switch watches the ammonia (NH₃/NH₄) and/or nitrite (NO₂) of the water – "if these values rise, feed less" (from the feeder manual). Assign an existing state for each and enable Block/reduce feeding on poor water quality. For each substance you set two thresholds:
- Reduce above – when the value is at or above this warn threshold, the daily amount is reduced to a configurable percentage (Reduce daily amount to (%)). This only takes effect in the feeding-amount control mode (there is no amount to reduce in the fixed/dynamic modes).
- Block above – when the value is above this maximum, feeding is blocked entirely in
every mode (like the temperature/oxygen blocks); the reason is written to
status.blockReason.
Leave a threshold empty to switch that tier off. The live values are mirrored in status.ammonia
and status.nitrite. There are no universal safe limits (they depend on pH and temperature) – as a
guide, keep ammonia and nitrite close to zero and set the thresholds from your own test kit.
Restrictions
- Restrict feeding to the astronomical day window (sunrise/sunset + offsets) – when on,
feeding is limited to the daytime window computed from this switch's location. For Interval
and Dynamic feeding this window replaces the fixed window start/end; for Fixed times it
acts as a day/night guard (times outside the window are skipped). When enabled you can set:
- Minutes after sunrise – start this many minutes after sunrise (default 0).
- Minutes before sunset – stop this many minutes before sunset (default 0).
- Location for this switch – only shown when the general Location is set to individual:
pick Use system settings or Define specific location (address search + map) for this
switch. The computed times appear in
status.sunrise/status.sunset.
- Manual trigger ignores all blocks – when on, the manual button and the
feedNow/feedFordata points feed even if a temperature/window block is active.
Dynamic feeding
Optional: adapt the feeding interval and duration to temperature using the Q10 model (metabolism roughly doubles per +10 °C). Requires an active temperature source; fixed times are then replaced by an interval within the window.
- Enable / source – turn it on and pick water or air temperature. When a second (deep) water sensor is configured, the water temperature used here is combined from both layers per the chosen combine mode (see Temperature & oxygen sources).
- Reference / Q10 – the base interval and duration apply at the reference temperature (e.g. 20 °C); Q10 is typically 2–2.5 (metabolism roughly doubles per +10 °C — see Dynamic feeding — background & sources).
- Interval / duration (base, min, max) – bounds for the computed interval (minutes) and duration (seconds). The base interval and the max interval must be greater than 0, otherwise no feeding can be planned.
- Averaging window / hysteresis – a moving average (e.g. 24 h) smooths spikes; hysteresis avoids re-planning on tiny changes.
The current values are exposed in status.dynamicAvgTemperature, status.dynamicRate, status.dynamicIntervalMin and status.dynamicDurationSec. An optional oxygen (O₂) source can block feeding when the dissolved oxygen drops below a threshold. The winter pause takes precedence over dynamic feeding.
If dynamic feeding is enabled but no valid interval can be computed (base or max interval is 0, or an invalid time window), nothing is scheduled:
status.nextFeedingstays empty andstatus.blockReasonshows a hint. Set a base interval and a max interval greater than 0.
Feeding-amount model (advisory)
Optionally the adapter estimates the recommended daily food amount for a switch from the fish
stock and the water temperature, following the original feeder manual:
daily amount [g] = total fish weight × percentage(water temperature). You only enter the number
of fish per size class (15/20/30/40/50/60 cm) in a small table with a fish icon per size; the
weight per size is a fixed estimate from the manual (60/125/350/1000/2000/4000 g). You also set
the feeding percentage per temperature band (defaults 0 % below 15 °C, 1 % at 15–18 °C, 1.5 % at
18–21 °C, 2 % at 21–23 °C, 3 % at 23–28 °C, then throttled again in the heat: 1.5 % at 28–30 °C
and 0.5 % above 30 °C – the temperature response peaks around 24–26 °C and falls off above it). It
needs a water-temperature source for the switch.
By itself this is a calculator – it computes and shows the recommendation. The results are
published in status.fishTotalWeight (g), status.feedPercentToday (%) and
status.feedTargetGramsToday (g); the switch tab additionally shows the estimated total weight and
an example.
Optionally you can let this amount control feeding: enable Control feeding with this amount
and the recommended daily grams are converted into motor run-time and split across the day's
feedings. For that you calibrate the dispense rate (g/s) — a small helper runs the motor for a
few seconds so you can weigh the dispensed food and let the adapter compute the rate — and may set
an optional daily maximum (g) as an overfeeding safeguard. This mode is mutually exclusive
with dynamic (Q10) feeding; the "when" (fixed times / interval / astronomical window) and all
blocks (night, temperature, O₂, pauses, winter) stay unchanged and keep priority. The resulting
run-time is published in status.feedTargetSecondsToday (s per day) and
status.feedEffectiveDurationSec (s per feeding); the per-feeding duration is capped for safety.
The feed currently filled into the feeder is chosen per switch under Currently loaded feed,
from the central Feed list (see 5.2). Its name, pellet size and nutrition are
published in status.activeFeed* and it can also be switched from the VIS widget via the writable
settings.activeFeed state (the feed's id). The dispense rate (g/s) is calibrated per switch
(it depends on the feeder's mechanics), independent of which feed is loaded.
Winter pause
Per switch you can define a recurring winter pause (seasonal, given as MM-DD dates that repeat every year and may wrap around New Year).
- Enable winter pause – turn the pause on.
- Winter start / Winter end – pick the day and month from a calendar (shown as dd.mm), e.g. 01.11 to 15.03.
- Mode – during the pause either suspend feeding, feed with a reduced own interval, or once daily at a set time; a separate winter feeding duration applies.
- Reminders (Telegram) – a daily reminder is sent in the days before the start and before the end (last on the day itself), at the configured hour. Needs a Telegram instance (see below).
The current state is shown in the status.winterActive data point. Feeding resumes automatically when the pause ends.
Feeding pauses
Suspend feeding now (master switch). At the top of this section a single on/off switch lets you suspend all feeding for the switch immediately and indefinitely — it overrides the time-based pauses below and every feeding mode (fixed times, interval, dynamic feeding, winter pause). Turn it off again and feeding resumes exactly as configured before; nothing else has to be changed. Toggling it sends a Telegram message (on / off). Typical use: a spontaneous interruption (medication, maintenance, water treatment) without touching any schedule. It is editable from the settings page and from VIS/scripts via settings.pauseNow, and its live state is shown in status.pauseManual.
Below the master switch, up to 3 one-off feeding pauses per switch let you plan absolute date-time periods in which feeding is completely suspended (higher priority than every feeding mode). Typical use: a quarantine after restocking, when new fish should not be fed for a while.
- Pause 1 / 2 / 3 – tick to enable, then pick a Start and End (date + time, shown as
DD.MM.YYYY HH:mm), e.g.15.07.2026 08:00to22.07.2026 18:00. - Feeding stops while now is within an enabled pause and resumes automatically at its end.
- A Telegram message is sent exactly at the start and end of each pause (needs a Telegram instance, see below). If the adapter starts while a pause is already active, only the end message is sent.
- Editable from the settings page and from VIS/scripts via the
settings.*states (e.g.settings.pause1Start).
The current state is shown in status.pauseActive and status.pauseActiveUntil (the master switch also drives status.pauseActive).
Switching supervision
After switching, the adapter can verify that the switch actually reached the on and off state, and report one of three results per feeding:
| Result | Meaning | Message |
| ✅ success | switch turned on and off as expected | "Feeding triggered for x s." |
| ❌ on failed | the switch never confirmed the ON state | "Feeding could not be performed. Check the switch!" |
| ❌ off failed | it turned on, but did not turn off again | "Fault: the feeder did not switch off!" |
The message is sent in the configured ioBroker system language (English by default).
- Verify that the switch actually turns on and off – enables the supervision.
- Verification timeout (seconds) – how long to wait for the confirmation.
- Verification attempts – how many staggered re-checks to perform before reporting a fault (default 3). Each attempt also reads the current state back, so delayed status feedback (e.g. Homematic radio) no longer triggers a false fault.
Important: supervision works only if the switch reports its real state back, i.e. the target object is updated with
ack=true(typical for smart plugs/relays with status feedback). A plain helper boolean that nobody acknowledges would always report a fault – in that case turn supervision off for this switch.
The result is also stored in the status.lastResult (text) and status.error (boolean) data points, so you
can react to it (e.g. trigger a notification of your own).
Send the supervision messages to Telegram – configured per switch:
- Message language – the language of all outgoing texts for this switch (Telegram, Sayit and the feeding announcement): System language (the ioBroker system language) or a specific language. The status data points are not affected.
- Telegram instance – pick one of the installed
telegram.*instances (or None to disable Telegram for this switch). If none is installed, the field tells you so. - Telegram recipient (optional) – a specific user/chat name as configured in the telegram adapter; leave empty to send to all configured recipients.
- Checkboxes – choose which messages to send: successful feeding, could-not-feed, and/or switch-off fault.
The winter-pause reminders (if enabled, see Winter pause) are sent to the same Telegram instance, independently of these supervision checkboxes.
See Telegram notifications for the full setup.
Sayit notifications
Speak the same supervision messages through a Sayit (text-to-speech) instance – configured per switch, independently of Telegram (both can be active at the same time):
- Sayit instance – pick one of the installed
sayit.*instances (or None to disable Sayit for this switch). If none is installed, the field tells you so. - Volume (0–100, optional) – the speaking volume for this switch; leave it empty to use the Sayit instance's own default.
- Test announcement – next to the instance selection: speaks a short test text through the selected instance so you can check the audio output right away, without waiting for a feeding.
- Checkboxes – choose which messages to speak: successful feeding, could-not-feed, and/or switch-off fault (the same three as Telegram, but selected separately here).
The spoken text uses the Message language selected in the Telegram section above.
Feeding announcement
Announce an upcoming feeding a configurable time in advance, via Telegram and/or Sayit:
- Announce feeding in advance – turns the announcement on.
- Lead time (minutes) – how long before the feeding the announcement is sent (e.g.
5). - Announce via Telegram / Announce via Sayit – the channel(s) used for the announcement (each needs its instance configured above).
The announcement is planned together with each feeding. If, at the announcement time, the feeding
would be blocked or paused (night, temperature, oxygen or a feeding pause), the announcement
is skipped, so it never promises a feeding that will not happen. Manual feedings (the Feed now
button / feedFor) have no lead time and are not announced.
5.4 Relay board tab (optional)
This tab only appears when the switch's This switch uses the Automatic-Feeder relay board toggle is enabled in the general settings (see 5.1). One relay board belongs to one switch (feeding station). The board is an ESP32 with three timer buttons (S1–S3) and its own web interface, reached over your network on port 80. The adapter configures the board, shows its status and – by default – triggers the feeding through the board (see Feed primarily through the relay board below), so the board runs its own countdown, shows it on its display and switches its relay off again itself.
Note: The Automatic-Feeder relay board is developed in parallel as a separate project. The adapter works fully without it – the board is an optional, convenient add-on. Because it evolves independently, some of its details may change independently of the adapter.
- Board address (IP or mDNS host) – e.g.
192.168.1.50orfeeder.local. A fixed IP is the most reliable; mDNS (.local) only works if your host system can resolve it. A:portsuffix is allowed but usually not needed (default80). - Feed primarily through the relay board (fallback: Shelly directly) – on by default. When on,
a feeding is triggered through the board's web interface (
POST /api/trigger) for exactly the computed duration, so the board itself runs the countdown, shows it on its OLED and switches its relay off again. Only when the board cannot be reached does the adapter fall back to switching the target (Shelly) object directly – the same way non-board switches work. This way the board's display and log always reflect the real feeding. Turn it off to always switch the Shelly directly (the old behaviour). The path actually used is written torelay.lastTriggerPath(board/direct), added to the success message and the log. Both the board and the target are checked before a feeding counts as done, and a safety back-stop forces the board off should it ever fail to switch off on its own. - Test connection & fetch times – contacts the board once. A green Connected chip and the board's host/IP/firmware confirm a working connection; the three button feeding times are then read from the board into the fields below. A red Not connected chip shows the error. This also runs automatically when you open the tab (if an address is configured), so the status, system overview and button times load without a click.
- Button feeding times (seconds) – the feeding time of each button S1, S2 and S3 (1–600 s). Because these are also editable on the board's own web interface, always fetch them first, then adjust them.
- Save times to board – writes the three values to the board.
- Restart board – restarts the ESP32 via its API (
POST /api/reboot). After a confirmation prompt the board reboots and is offline for a few seconds, then comes back automatically.
At the bottom of the tab, a System overview shows the board's live system data after a successful connection test (the Test connection & fetch times button): firmware version and build, host name, IP address, Wi-Fi network, signal strength (dBm), MAC address, uptime, free memory and the last reset reason (shown in plain words, e.g. “Software”).
The connection is also mirrored into the object tree and refreshed every 60 s – see the
relay.* data points in section 6.
6. Objects / data points
Note: All timestamp data points are shown in the system's local timezone (format
DD.MM.YYYY HH:MM:SS, e.g.01.07.2026 16:20:00). For VIS and scripts every timestamp additionally has a numeric twin ending in…Ts(Unix time in milliseconds,0= none) — ideal for countdowns and time bars without any string parsing, and independent of the display format.
The adapter creates the following states under its namespace
(automatic-feeder.<instance>.).
Global
| Data point | Type | Meaning |
info.connection | boolean (ro) | Adapter is running and the configuration is valid. |
info.feeds | string (ro) | The central feed list as JSON (each food type with name, vendor, pellet size, nutrition and offer link) — for VIS/widgets to render the list without reading the instance config. |
Per switch, under switches.<id>. (<id> is an internal id like sw-0)
Directly under the switch there is the manual trigger and two sub-channels:
status(switches.<id>.status.*) – the read-only status data points listed below.settings(switches.<id>.settings.*) – an editable mirror of this switch's configuration. Writing a new value there (from VIS or a script) changes the configuration and restarts the instance so the change takes effect. A few derived fields are read-only (e.g.winterWindow).relay(switches.<id>.relay.*) – present only when this switch uses a relay board; the read-only relay-board status data points listed at the end of the table.
feedNow | boolean (rw) | Write true to trigger a manual feeding. |
feedFor | number (rw) | Write a duration in seconds to trigger one feeding with exactly that duration — no configuration change, no restart. Resets to 0 after execution. |
status.feedingActive | boolean (ro) | A feeding is running right now. |
status.feedingEndsTs | number (ro) | End of the running feeding as Unix time in ms (0 = not feeding) — for a live runtime countdown (e.g. 15 → 0 s) in VIS. |
status.feedingDurationSec | number (ro) | Total duration of the running feeding in seconds (0 = not feeding) — lets a VIS widget draw an exact progress ring next to the countdown. |
status.lastFeeding | string (ro) | Timestamp of the last feeding. |
status.lastFeedingTs | number (ro) | Last feeding as Unix time in ms (0 = none yet). |
status.nextFeeding | string (ro) | Timestamp of the next planned feeding. |
status.nextFeedingTs | number (ro) | Next planned feeding as Unix time in ms (0 = nothing planned). |
status.blocked | boolean (ro) | The last attempt was blocked. |
status.blockReason | string (ro) | Why it was blocked (night / temperature / oxygen), in the system language. |
status.blockReasonCode | string (ro) | The block reason as a stable machine-readable code (e.g. blockNight, blockWaterBelow, blockPauseManual; empty = not blocked) — for icon/colour logic in VIS, independent of the language. |
status.lastResult | string (ro) | Result text of the last feeding attempt. |
status.error | boolean (ro) | The last attempt had a switching fault. |
status.winterActive | boolean (ro) | The winter pause is currently active. |
status.winterLastStartReminder | string (ro) | Date of the last sent "winter starts" reminder. |
status.winterLastEndReminder | string (ro) | Date of the last sent "winter ends" reminder. |
status.pauseManual | boolean (ro) | The manual master pause (Suspend feeding now / settings.pauseNow) is on. |
status.pauseActive | boolean (ro) | A one-off feeding pause is currently active. |
status.pauseActiveUntil | string (ro) | End of the currently active feeding pause (empty if none). |
status.pauseActiveUntilTs | number (ro) | End of the active feeding pause as Unix time in ms (0 = none). |
status.dynamicAvgTemperature | number (ro) | Averaged temperature used by dynamic feeding. |
status.dynamicRate | number (ro) | Q10 rate factor currently applied by dynamic feeding. |
status.dynamicIntervalMin | number (ro) | Currently computed dynamic interval (minutes). |
status.dynamicDurationSec | number (ro) | Currently computed dynamic duration (seconds). |
status.airTemperature | number (ro) | This switch's own air-temperature source value. |
status.waterTemperature | number (ro) | This switch's own water-temperature source value (feeding-zone / shallow sensor). |
status.waterTemperatureDeep | number (ro) | This switch's optional deep water-temperature sensor value. |
status.waterStratification | number (ro) | Temperature difference shallow − deep (only with two water sensors). |
status.oxygen | number (ro) | This switch's own dissolved-oxygen source value. |
status.ammonia | number (ro) | This switch's own ammonia (NH₃/NH₄) source value. |
status.nitrite | number (ro) | This switch's own nitrite (NO₂) source value. |
status.fishTotalWeight | number (ro) | Feeding-amount model: estimated total fish weight (g). |
status.feedPercentToday | number (ro) | Feeding-amount model: feeding percentage for the current water temperature (%). |
status.feedTargetGramsToday | number (ro) | Feeding-amount model: recommended food amount per day (g). |
status.feedingsPerDayToday | number (ro) | Feeding-amount model: number of feedings planned for today. |
status.feedTargetPortionGrams | number (ro) | Feeding-amount model: recommended amount per single feeding (g) = daily amount ÷ feedings (after cap / water-quality reduction). |
status.feedTargetSecondsToday | number (ro) | Feeding-amount model (control mode): total motor run-time per day (s) to dispense the amount. 0 when control is off. |
status.feedEffectiveDurationSec | number (ro) | Feeding-amount model (control mode): duration per feeding it currently drives (s). 0 when control is off. |
status.dispenseRate | number (ro) | Feeding-amount model: this switch's calibrated dispense rate (g/s). |
status.activeFeedName | string (ro) | Currently loaded feed: name (empty when none selected). |
status.activeFeedVendor | string (ro) | Currently loaded feed: vendor / dealer. |
status.activeFeedSize | number (ro) | Currently loaded feed: pellet size (mm). |
status.activeFeedProtein | number (ro) | Currently loaded feed: crude protein (%). |
status.activeFeedFat | number (ro) | Currently loaded feed: crude fat (%). |
status.activeFeedFibre | number (ro) | Currently loaded feed: crude fibre (%). |
status.activeFeedAsh | number (ro) | Currently loaded feed: crude ash (%). |
status.activeFeedUrl | string (ro) | Currently loaded feed: offer / purchase link (optional). |
status.sunrise / status.sunset | string (ro) | Calculated sunrise/sunset for this switch's location (astronomical window). |
status.sunriseTs / status.sunsetTs | number (ro) | Sunrise/sunset as Unix time in ms — e.g. for a day-progress bar in VIS. |
relay.connected | boolean (ro) | The relay board configured for this switch is reachable (only when this switch uses a relay board). |
relay.info | string (ro) | Relay board identity (host / IP / firmware) from the last successful poll. |
relay.active | boolean (ro) | The relay board's timer is currently running. |
relay.remaining | number (ro) | Seconds remaining on the relay board's running timer. |
relay.lastTriggerPath | string (ro) | How the last feeding was triggered for this switch: board (through the relay board) or direct (Shelly switched directly, e.g. board unreachable). |
You can use these in VIS, scripts or other adapters – for example show status.nextFeeding on a
dashboard, or react on status.error = true to send your own alarm.
7. Examples / recipes
Koi pond, twice a day, only when warm enough
- Mode Fixed times →
08:00,18:00; duration6s. - On the switch tab, under Temperature & oxygen sources, enable Water temperature and pick
the sensor; then Block by water temperature → Block if below
8°C (no feeding when cold). - Under Restrictions, enable Restrict feeding to the astronomical day window so nothing is fed after dark.
Aviary, only during daylight (astronomical window)
- Mode Interval within a time window → interval
90min; duration3s. - Under Restrictions, enable the astronomical window with offsets
30/30min → feeding runs from 30 min after sunrise to 30 min before sunset, following the seasons automatically.
Koi pond, temperature-adaptive (dynamic feeding)
- On the switch tab, under Temperature & oxygen sources, enable Water temperature and pick the sensor.
- Then open Dynamic feeding, enable it, source Water temperature.
- Reference
20°C, Q102.2, base interval60min (min30, max480), base duration5s (min2, max15). It then feeds more often and a little more when warm, and less when cold.
Winter break for the pond
- On the switch tab open Winter pause, enable it, set Winter start
01.11and Winter end15.03, mode Suspend feeding. - Optionally tick the reminders so you get a Telegram note a few days before start/end.
Quarantine after restocking (feeding pause)
- On the switch tab open Feeding pauses, tick Pause 1 and set Start
15.07.2026 08:00, End22.07.2026 18:00→ no feeding at all in that window, then it resumes automatically. - With a Telegram instance configured you get a message at the start and the end of the pause.
Suspend feeding right now (master switch)
- On the switch tab open Feeding pauses and turn on Suspend feeding now – or write
truetoautomatic-feeder.0.switches.sw-0.settings.pauseNowfrom a VIS switch. - All feeding stops immediately (overriding every mode) until you turn it off again; each toggle
sends a Telegram message.
status.pauseManualshows the live state.
Manual extra portion from a VIS button
- Put a button in VIS that writes
truetoautomatic-feeder.0.switches.sw-0.feedNow. - Or use a slider/number field that writes the seconds to
automatic-feeder.0.switches.sw-0.feedFor→ feeds once with exactly that duration (no configuration change, no restart; the state resets to0afterwards). - Optionally set Manual trigger ignores all blocks so it always feeds.
8. Telegram notifications
- Install and configure the telegram adapter (create a bot with @BotFather, enter the token, start a chat with your bot). Make sure the telegram instance is running.
- In a automatic-feeder switch tab, open Telegram notifications:
- Select your Telegram instance from the dropdown (e.g.
telegram.0). - Optionally enter a recipient (the user/chat name shown in the telegram adapter); leave empty to notify everyone.
- Tick the messages you want: successful feeding, could-not-feed, switch-off fault.
- Save. From now on the chosen supervision results are pushed to Telegram (prefixed with the switch name). This requires Switching supervision to be enabled for that switch.
- The winter-pause reminders use the same Telegram instance and recipient. They are controlled in the Winter pause section (days before start/end and the reminder hour) and do not require supervision to be enabled.
9. Troubleshooting & FAQ
The settings page is blank / white. Reload the browser with Ctrl+Shift+R (the admin may have cached an old page). If it persists, restart the instance and reopen the settings.
The new icon / a change does not show up. Browser cache – hard-reload with Ctrl+Shift+R.
Nothing gets fed.
Check, in order: the switch is Active; a switch object is selected; the schedule is
valid (status.nextFeeding shows a time); it is not blocked (look at status.blocked / status.blockReason);
the astronomical window is not excluding the time; set the instance log level to debug
and watch the log.
It never feeds at night although I want it to. Disable Restrict feeding to the astronomical day window for that switch, or adjust its sunrise/ sunset offsets. If the astronomical window is enabled but the switch has no valid coordinates, its window guard stays inactive and a warning is logged.
Supervision always reports a fault.
Your switch object probably does not report its real state back (ack=true). Either use a
switch with status feedback, or disable Switching supervision for that switch.
Dynamic feeding does not change anything.
Make sure the selected temperature source (water or air) is enabled on the switch tab
(Temperature & oxygen sources) and delivers values. Right after a restart the moving average is still filling up, so it starts from
the base values. Watch status.dynamicAvgTemperature and status.dynamicIntervalMin.
Dynamic feeding is enabled but nothing is ever fed (status.nextFeeding is empty).
The base interval or the max interval is 0 (or the time window is invalid), so no interval can be computed – status.blockReason then shows a hint. Set a base interval and a max interval greater than 0 (and a valid window). Note: leaving both the min and max interval at 0 also forces the result to 0.
Nothing is fed although it is not winter (or it feeds although it should pause).
Check the Winter pause dates (Winter start / Winter end, format dd.mm) and the mode. The
status.winterActive data point shows whether the pause is currently active.
The address search says the instance must be running. Start the automatic-feeder instance – the geocoding runs in the backend.
Telegram messages do not arrive. Is a Telegram instance selected on the switch tab? Is the telegram adapter configured and running? Is at least one message type ticked, and is Switching supervision enabled?
10. Logging & debugging
The adapter logs on the standard ioBroker levels. To see detailed messages, raise the instance log level (Instances → automatic-feeder.x → log level) to debug or silly:
- error – failures that need attention (e.g. a write to the switch failed).
- warn – misconfiguration (no coordinates, invalid schedule …).
- info – milestones (startup, a feeding executed or blocked, manual trigger).
- debug – detailed flow (scheduling decisions, temperature updates, geocoding, on/off values, verification confirmed/timeout).
- silly – very verbose tracing (every timer, every block check, every state change).
11. Dynamic feeding — background & sources
Fish (koi, goldfish, pond carp) are poikilothermic (ectothermic): their metabolism follows the water temperature. As a rule of thumb the metabolic rate roughly doubles for every +10 °C, which is exactly the Q10 coefficient (typically 2–3) this adapter uses — so feeding more often and a little more when it is warm, and less when it is cold, is physiologically justified.
Practical temperature guidance (koi/pond fish):
- below ~4–5 °C – do not feed (use the Winter pause).
- ~4–10 °C – barely active; feed rarely if at all, easily digestible (wheat-germ) food.
- ~10–15 °C – reduced feeding; the immune system is still weak (~12 °C).
- ~15–25 °C – optimal growth range, full feeding.
- above ~28 °C – dissolved oxygen becomes the limiting factor → the O₂ block is useful here.
Where to measure, and why a second sensor: the temperature that matters is the water the fish
actually occupy (the feeding zone), not the surface (which can be several degrees off). In a
pond that is mixed by a running pump, or a shallow pond, one well-placed sensor is enough. Only in a
deep, unmixed pond does the water stratify: above 4 °C the warm water sits on top (colder below);
below 4 °C it inverts, leaving a ~4 °C refuge near the bottom. There a second (deep) sensor adds
value — for safety (feed by the coldest layer), for a seasonal shallow/deep switch, and to make the
stratification visible (status.waterStratification). For most ponds it is optional.
Sources / further reading:
- Volkoff H. & Rønnestad I. (2020): Effects of temperature on feeding and digestive processes in fish. Temperature 7(4):307–320. https://pubmed.ncbi.nlm.nih.gov/33251280/
- K.O.I. – Water Temperature and Koi. https://koiorganisationinternational.org/koi-articles/water-temperature-and-koi
- K.O.I. – The Science behind Cold Water in Koi Ponds. https://koiorganisationinternational.org/koi-articles/science-behind-cold-water-koi-ponds
- Pond Informer – Koi feeding guide. https://pondinformer.com/koi-feeding-guide/
These figures are general guidance for koi/pond fish, not a substitute for observing your own animals. Adjust the reference temperature, Q10, limits and thresholds to your species and setup.
1.18.4 (2026-09-12)
- (ssbingo) Maintenance: added Node.js 26 to the CI test matrix (issue #31; recommended
[22.x, 24.x, 26.x]) and updated the@iobroker/testingdevDependency to 6.x (repository checker S0064). No functional changes; minimum Node.js stays 22
1.18.3 (2026-09-06)
- (ssbingo) Maintenance: updated
@iobroker/adapter-coreto 3.4.3 (repository checker W0034). No functional changes
1.18.2 (2026-09-06)
- (ssbingo) Maintenance: dependency updates merged via Dependabot —
@iobroker/adapter-react-v58.3.3,@tsconfig/node2222.0.6 anddayjs1.11.23 (MUI stays 6 asadapter-react-v5still requires it); the admin UI was rebuilt. No functional changes
1.18.1 (2026-09-03)
- (ssbingo) Fix – Sayit announcement. The pre-feeding announcement via Sayit now reliably speaks the current text: it uses Sayit's documented
saymessage command (sendTo) instead of writing thetts.text/tts.volumestates, which could re-play a stale/old announcement (e.g. a previous test message) and raced the separate volume write. Telegram announcements were never affected
1.18.0 (2026-09-01)
- (ssbingo) Central feed list with its own Feed list tab (issue #26). Maintain your food types centrally — name, vendor/dealer, pellet size (mm) and the four standard nutritional values (crude protein / fat / fibre / ash %), plus an optional offer/purchase link. In each switch tab you pick, under Currently loaded feed, which feed is currently filled into that feeder
- (ssbingo) This replaces the per-switch feed profiles from 1.17.0 (issue #25): existing profiles are automatically merged into the central list, each switch's calibrated dispense rate stays per switch (
dispenseGramsPerSec), and itsactiveFeednow references a feed by id - (ssbingo) New states:
info.feeds(the list as JSON, for VIS/widgets) and per switchstatus.activeFeedName/activeFeedVendor/activeFeedSize/activeFeedProtein/activeFeedFat/activeFeedFibre/activeFeedAsh/activeFeedUrl. The active feed is selectable from VIS via the writablesettings.activeFeed(feed id) - (ssbingo) Documentation updated in all 11 languages and in the German PDF handbook
1.17.0 (2026-09-01)
- (ssbingo) Feed profiles for the feeding-amount model. Instead of a single rate you can define several named feed types per switch, each with its own calibrated dispense rate (g/s) (e.g. a 3 mm all-round and a 6 mm summer pellet); the active profile's rate drives Phase B. Manage the list in the admin (the calibration helper fills the active profile), switch the active feed from the VIS widget via the writable
settings.activeFeedstate - (ssbingo) New states
status.dispenseRate(effective g/s) andstatus.activeFeedName. Backward compatible — with no profile defined, the single dispense rate is used - (ssbingo) Documentation updated in all 11 languages and in the German PDF handbook
1.16.0 (2026-08-31)
- (ssbingo) Feeding-amount model – high-temperature throttling (issue #23). The percentage table no longer stays at 3 % above 23 °C: the top band now ends at 28 °C and two new editable bands throttle the amount in the heat – 1.5 % at 28–30 °C and 0.5 % above 30 °C (the temperature response peaks around 24–26 °C and falls off above it). Behaviour up to 28 °C is unchanged; existing switches get the new bands with sensible defaults
- (ssbingo) Feeding-amount settings are now editable from VIS/scripts (issue #24): the model's config (
amountModelEnabled, fish counts, temperature percentages,amountControlEnabled,dispenseGramsPerSec,feedDailyMaxGrams) is mirrored as writableswitches.<id>.settings.*states, so a VIS widget can edit them - (ssbingo) New states
status.feedingsPerDayTodayandstatus.feedTargetPortionGrams(recommended grams per single feeding = daily amount ÷ feedings, after cap / water-quality reduction) - (ssbingo) Documentation updated in all 11 languages and in the German PDF handbook
1.15.1 (2026-08-31)
- (ssbingo) Fix (relay board): a false "did not switch off" fault could be reported for a board-fed switch even though it fed and switched off correctly. The target object (e.g. the Shelly) is now authoritative for the off check — a fault (and the Telegram/Sayit notification) is only raised when the target is genuinely still on. If the target is off but the board's
/api/statuscannot confirm its relay off in time (a brief hiccup, or its countdown ending a moment later), the adapter now logs a warning instead of a fault; the safety back-stop still forces the board off
1.15.0 (2026-08-31)
- (ssbingo) Water-quality limits (Phase C). New optional per-switch ammonia (NH₃/NH₄) and nitrite (NO₂) sources – "if these values rise, feed less" (from the feeder manual). Each has a warn threshold that reduces the daily amount (only in the feeding-amount control mode) and a max threshold that blocks feeding entirely in every mode
status.ammoniaandstatus.nitritemirror the source values; when a max threshold is exceeded the block reason (blockAmmoniaHigh/blockNitriteHigh) appears instatus.blockReason. There are no universal safe limits – set the thresholds from your own test kit - (ssbingo) Documentation updated in all 11 languages and in the German PDF handbook
1.14.2 (2026-08-31)
- (ssbingo) Fix (admin UI, dark mode): the configuration page is now wrapped in the theme the admin has already resolved, so the tab labels are visible immediately in dark mode. Previously they rendered as dark text on a dark background (only revealed on hover or after opening a tab), because the tabs inherited the outer theme that is fixed at page-load time. Applies on first open and when you toggle the theme
Documentation
- 🇩🇪 Deutsche Dokumentation
- 🇷🇺 Документация на русском
- 🇳🇱 Nederlandse documentatie
- 🇫🇷 Documentation française
- 🇮🇹 Documentazione italiana
- 🇪🇸 Documentación en español
- 🇵🇱 Dokumentacja polska
- 🇵🇹 Documentação portuguesa
- 🇺🇦 Документація українською
- 🇨🇳 简体中文文档
Copyright (c) 2026 ssbingo s.sternitzke@online.de
