Assistant Satellite
Voice satellite for ioBroker.assistant: wake word + microphone streaming + spoken reply, running on this host.
Current Release
0.1.3
ioBroker.assistant
ioBroker.assistant-satellite
An ioBroker adapter that turns the host it runs on into a voice satellite for ioBroker.assistant: it detects the wake word, streams the microphone to the assistant's voice server and plays the spoken reply.
It is a thin wrapper around the standalone @iobroker/assistant-satellite package — use this adapter when the satellite device already runs ioBroker (config + status via the admin UI). On a bare Pi without ioBroker, use the standalone package directly (npx @iobroker/assistant-satellite).
Requirements
  • A mic + speaker on the host
  • Audio backend (auto-selected, or force it under Audio backend):
    • Linuxalsa-utils: arecord records, aplay plays (sudo apt install alsa-utils)
    • Windows / macOSffmpeg: ffmpeg records and ffplay plays — you need both binaries, reachable via the PATH (see below). Minimal builds that ship ffmpeg.exe only are not enough.
  • A running ioBroker.assistant instance (the satellite talks to it over the ioBroker message bus by default)
ffmpeg / ffplay in the PATH (Windows, macOS)
The adapter starts ffmpeg and ffplay by name, so the folder holding them must be in the PATH of the account ioBroker runs under — not just in your own terminal:
  • Windows — grab a full build (e.g. gyan.dev or BtbN), unpack it to e.g. C:\FFMPEG, then add the folder that contains ffmpeg.exe and ffplay.exe to the system Path (System Properties → Advanced → Environment Variables → System variables → Path). Verify in a new shell: where ffmpeg and where ffplay.
  • macOSbrew install ffmpeg (installs both into the Homebrew bin dir); verify with which ffmpeg ffplay.
A process only ever sees the PATH it inherited when it started, so restart ioBroker (service or host) after changing it — otherwise the instance log keeps showing ffmpeg failed: spawn ffmpeg ENOENT — is it installed? (install ffmpeg).
Setup
Install the adapter, add an instance, then configure it. The settings are grouped:
ioBroker.assistant server
  • Assistant instance — pick the running ioBroker.assistant instance this satellite talks to
  • TransportioBroker (audio over the message bus, no UDP port, central STT/TTS — recommended) or UDP (Hannah-style audio stream, ESP-compatible). With UDP, set the Local listen port (default 7776) and, if the wrong interface is auto-picked, a Host IP override.
Identity
  • Room — assign the satellite to a room
Audio
  • Audio backendAuto / ALSA / ffmpeg
  • Microphone / Speaker device — e.g. plughw:2,0 on a Pi (ALSA) or a dshow name / avfoundation index (ffmpeg); default = system default. The device lists are read from this host (instance must be running). On Windows / macOS only capture devices can be enumerated, and ffplay always plays to the system's default output device — pick the speaker in the OS sound settings, not here.
  • ALSA mixer control — optional; only used by the volume/mute states (see below). Empty = auto-detect on the speaker's card; set a name (e.g. PCM, Master, Speaker) if the wrong one is picked. ALSA only.
Wake word
  • Wake word model — built-in hey_jarvis (default), alexa, hey_mycroft, hey_rhasspy, or a URL / local .onnx path. You can configure up to three wake words — the satellite triggers on any of them.
  • Threshold — 0–1, lower = more sensitive.
  • Upload a custom wake-word model — upload a single self-contained .onnx (external-data .onnx + .onnx.data is not supported), then pick it in a wake-word field above. Use the built-in wake-word test to check detection live (the test.* states report score / peak / mic level while it runs).
  • Follow-up conversation — after an answer, keep the mic open for a short follow-up window so you can continue ("…and the kitchen too") or answer a clarifying question without saying the wake word again.
Recording (advanced) — silence detection and record-length tuning: silence RMS threshold, silence (ms), min / max record (ms) and pre-buffer chunks.
On first start the OpenWakeWord models download into the instance data dir. Then say the wake word → speak → the answer is played back. The status state shows idle / listening / processing / speaking, and info.connection reflects whether the satellite is registered with the assistant.
Volume, mute, Do-Not-Disturb
These writable states apply to answers, announcements and the beep alike:
  • volume — 0–100 %
  • mute — silence the speaker
  • dnd — Do-Not-Disturb: announcements are suppressed (replies to your own questions still play)
volume and mute drive the host's mixer. On start it works the other way round: the adapter reads the host's current setting into the two states, so bringing an instance up never changes how loud the machine is playing. Every write to the states after that is applied to the mixer:
  • Linux (ALSA) — the mixer of the speaker's card. The control is auto-detected, or set it under ALSA mixer control if the wrong one is picked.
  • Windows — master volume / mute of the default playback device (Core Audio, driven through the built-in PowerShell — nothing extra to install). That is where ffplay plays, i.e. the same slider as in the Windows sound settings, so it applies system-wide, not only to the satellite.
  • macOS — not wired up: dnd works, volume / mute do not.
Priority announcements: if the announcement text (sent via the assistant's tts.text / satellites.<id>.tts) starts with !, the ! is stripped and it plays even when DND is on — e.g. !Water leak in the basement.
0.1.3 (2026-08-19)
  • (@GermanBluefox) volume / mute now work on Windows too (default playback device via Core Audio)
  • (@GermanBluefox) On start the current host volume/mute is adopted into the states instead of being overwritten
  • (@GermanBluefox) Documented the ffmpeg / ffplay PATH requirement for Windows and macOS
0.1.2 (2026-08-03)
  • (@GermanBluefox) Updated packages
0.1.0 (2026-07-12)
  • (@GermanBluefox) Support of multiple wake-words
  • (@GermanBluefox) Added test of wake-words
  • (@GermanBluefox) Connect to the assistant by instance selection with a choice of transport (ioBroker message bus or UDP)
  • (@GermanBluefox) Added selectable audio backend (auto / ALSA / ffmpeg) and room assignment
  • (@GermanBluefox) Added follow-up conversation mode (continue without repeating the wake word)
  • Added volume / mute / dnd states (ALSA mixer); announcements starting with ! bypass Do-Not-Disturb
0.0.2 (2026-07-05)
  • (@GermanBluefox) Initial commit
Copyright (c) 2026 Denis Haev dogafox@gmail.com
