Anker Solix
Anker Solix power systems via cloud API (based on ha-anker-solix)
Current Release
0.10.90
MatthiasUlrich1
ioBroker adapter for Anker Solix power systems (Solarbank, Smart Meter, PPS, EV charger, and more). It is based on the Home Assistant integration thomluther/ha-anker-solix and uses the same unofficial solixapi Python library.
Supported operating systems
OSStatus
LinuxPrimary production target — CI-tested (Docker, NAS, Raspberry Pi, …)
WindowsSupported and tested on ioBroker for Windows (Python 3.12+)
macOSNot supported — automatic Python/venv installation was not verified
npm / package.json catalog install: linux and win32 only. Details: Supported platforms.
A small Python bridge (persistent daemon, like HA) polls the Anker cloud and optional MQTT, then exposes values as ioBroker states. Optional entity groups (since v0.9.0) mirror HA’s scope: only Core is on by default to limit API load.
Table of contents
  1. Disclaimer & usage terms
  2. Supported platforms
  3. How this adapter works in ioBroker
  4. Requirements & installation
  5. Configuration
  6. Anker account & login cache
  7. Limitations
  8. Supported devices
  9. State structure & entity groups
  10. MQTT
  11. Special device notes
  12. Troubleshooting login / poll
  13. Services
  14. Credits & further reading
  15. Changelog
  16. Publishing
This adapter is not affiliated with Anker. Trademarks and product names belong to their respective owners.
The adapter uses an unofficial Python library to talk to the Anker Power cloud API (same as the mobile app). That API can change or break at any time. Improper settings may affect devices; the user accepts these risks when enabling the instance (Account tab). Future adapter updates may extend monitoring or controls.
Supported platforms
PlatformStatusNotes
Linux (Debian, Ubuntu, Docker, Proxmox, NAS, RPi)Primary / CI-testedRecommended for production; Python 3.12+ venv (python3-venv, python3-pip)
Windows (ioBroker for Windows)Supported & testedVerified on a real ioBroker Windows host; installer tries py -3.13, py -3.12, then Program Files paths; set pythonPath in admin if needed; installs tzdata for Europe/Berlin
macOSNot supportedSame Unix code path as Linux in theory, but automatic Python/venv bootstrap was not tested — no npm catalog support (package.json has no darwin)
Linux remains the main target for ioBroker deployments. Windows is fully supported in code and verified manually; GitHub Actions runs adapter tests on ubuntu-latest and windows-latest. macOS is excluded from support claims until Python installation is tested.
LayerRole
Node.js adapterInstance config, scheduling, ioBroker states, control queue
Python bridge (python/bridge.py)Long-lived session: API + optional MQTT (HA-style)
solixapiCloud login, sites/devices, energy stats, MQTT map
authcacheiobroker-data/<instance>/authcache/<email>.json — reused after successful API login
Poll interval should be 60–180 s (same recommendation as HA). Site list is updated every cycle; device/site details and energy data run on a slower interval (deviceDetailMultiplier, default every 10th poll).
Important: For cloud devices the Anker API is mandatory (MQTT alone is not enough for full system data). Exception: Modbus only mode uses local TCP and does not need cloud credentials. This adapter does not replace local BLE integrations — see Additional resources.
  • ioBroker js-controller >= 6, admin >= 7.6
  • Node.js >= 22
  • Python 3.12+ on the ioBroker host (recommended / upstream requirement):
    • Linux: python3-venv + python3-pip (Debian/Ubuntu) — primary production target
    • Windows: Python 3.12+ from python.org or py -3.12; adapter installer handles venv and tzdata
    • macOS: not supported (automatic Python install not verified)
    • Exception (best-effort): Linux Docker containers based on Debian 12 Bookworm (e.g. buanet/iobroker:latest-v11) may use system Python 3.11 when 3.12 is not available via apt. Bare-metal Bookworm, other distros, and non-Bookworm containers still require 3.12+. Prefer installing Python 3.12+ into a persistent path and setting pythonPath when possible.
Python dependencies install into the adapter folder (python/.venv or python/site-packages). Since v0.2.0: automatic on start (OptionsautoInstallPython) or button Install Python dependencies.
Install via ioBroker (recommended):
iobroker install anker-solix
After changing the adapter files locally, upload the instance:
iobroker upload anker-solix
Multihost: use --host "PC(SmartHome)" with quotes if the name contains special characters.
Remove legacy symlink if present: rm -f /opt/iobroker/node_modules/iobroker.AnkerSolix
Manual Python setup (if needed):
cd node_modules/iobroker.anker-solix
python3 -m venv python/.venv && python/.venv/bin/pip install -r python/requirements.txt
Home Assistant (ioBroker add-on)
The official ioBroker app on Home Assistant OS often has python3 but no pip and no python3-venv. Install or update the adapter via the ioBroker catalog / npm (iobroker install anker-solix). From 0.10.72 onward the installer detects this profile and tries:
  1. virtualenv in python/.venv (or --without-pip + pip inside venv)
  2. get-pip.py with --break-system-packages when system Python is PEP 668
  3. pip install --target python/site-packages as fallback
In the instance admin: OptionsInstall Python dependencies, or restart the instance with autoInstallPython enabled.
If logs still show No module named pip, open the ioBroker/SSH terminal on the host and run:
cd /data/iobroker/node_modules/iobroker.anker-solix
node tools/install-python.js
iobroker restart anker-solix.0
Copy authcache/<email>.json from a working Anker setup (e.g. ha-anker-solix) into iobroker-data/anker-solix.0/authcache/ to avoid captcha on first login.
Local Modbus (optional)
Newer Anker devices (Solarbank 4 / Max AC / Max, Smart Meter Gen 2, Smart Plug Gen 2, SOLIX X1 HES, V1 Smart EV Charger) can be polled locally via Modbus TCP (port 502). Register maps follow Anker’s official Modbus protocols and community-verified X1 mappings (anker-x1-ha).
  1. Enable Modbus TCP in the Anker app (Solarbank: system / Three-Party Control; X1: Professional app → Communication Settings; V1 EV Charger: Settings → Integrations).
  2. Adapter Admin → Modbus (local) → enable the channel, add each device IP.
  3. Optional: enable Modbus only (no cloud) if you do not want Anker cloud login. Then Python, credentials and usage terms are not required; the instance is green when at least one Modbus device is connected (otherwise yellow).
  4. Sensors: anker-solix.0.modbus.<name>.sensors.* (SOC, PV, grid, battery, SN, …).
  5. Controls: anker-solix.0.modbus.<name>.control.*
    • Solarbank: operating_mode, SOC limits, backup_soc_enable, battery_power_direction + battery_power_setpoint (setpoint only in third_party_control; set direction first; charge is written as negative watts).
    • Smart Plug Gen 2: power_switch.
    • Smart Meter Gen 2: read-only.
Without Modbus only, cloud login is still used for older devices and MQTT. Solarbank 3 is not in Anker’s official Modbus maps. If another Modbus client just queried the device, the first poll may get connection refused until that client’s cooldown expires; the next poll interval retries.
Docker (buanet/iobroker)
The official image ships Python 3.11. From 0.10.87 the adapter accepts that as best-effort on Debian 12 Bookworm containers — no custom image required. 3.12+ remains recommended (upstream) and is still required on bare metal and non-Bookworm hosts. Guide: docs/docker-buanet.md (optional 3.12 files under docs/docker/, PDF: docs/Anker-Solix-buanet-Docker-Anleitung.pdf).
Configuration
  1. Create instance: iobroker add anker-solix
  2. Account: Anker e-mail, password, country code (e.g. DE) — save after entering password
  3. Account: accept unofficial API usage (checkbox at bottom of tab)
  4. Options: poll interval 60–180 s, MQTT if needed, deviceDetailMultiplier (HA default: 10)
  5. Devices: Load devices, optional site ID / device SN filter
  6. Objects (v0.9.0+): enable optional groups; only Core on by default → restart adapter after changes
Do not use Clear Anker login cache unless you need a deliberate re-login (wrong account, corrupted file). Clearing forces a new cloud login and often triggers captcha on server hosts — see Troubleshooting.
After the first successful API login, the adapter stores tokens in:
iobroker-data/anker-solix.0/authcache/<your-email>.json
(Filename must match the e-mail in Account exactly.)
Since Anker app 3.10 (mid-2025), one account can often be used on multiple clients in parallel (app + ioBroker + HA). Older docs about “only one token” are less critical today, but a failed re-login from ioBroker still cannot refresh the file if Anker returns captcha.
Shared / member accounts: A family-shared account may see fewer API details than the owner account (same as HA).
More account notes: HA INFO.md – accounts.
Limitations
  • Unofficial API — no documentation; endpoints can change anytime.
  • EU vs COM cloud — wrong country in config → login works but no systems/devices. Do not switch countries after pairing devices.
  • Stale cloud data if device Wi‑Fi is offline; use cloud/MQTT connection indicators when enabled.
  • MQTT updates depend on device publish cycle; some values only with real-time trigger (high traffic if 24/7).
  • Standalone devices (PPS, charger, cooler not in a power system) have little or no API energy data — MQTT may be required (HA limitations).
  • Dynamic tariff beyond Nordpool: forecast/price entities may be wrong or read-only.
  • Captcha (100032) on direct API login from VPS/VPN/datacenter — see Troubleshooting. Copy authcache from HA or another working setup if ioBroker cannot log in once.
To help add devices: export anonymized data via HA export systems or anker-solix-api export_system.py.
Supported devices
Manufacturer: Anker SOLIX (support / downloads). Cloud coverage matches ha-anker-solix (via solixapi). In ioBroker, data appears under state IDs by device type (solarbank, smartmeter, combiner_box, system, modbus, …).
Device typeExamplesCloud / MQTTLocal Modbus
system / sitePower system from the Anker app (= API “site”)yes
solarbankE1600 (Gen1), SB2 Pro/Plus/AC, SB3 E2700, SB4 E5000 Pro, Solarbank Max / Max AC (XE)API + MQTTSB4, Max, Max AC (port 502)
combiner_boxPower Dock (multisystem) — merged controls when applicableyes
smartmeterAnker 3-phase, US meter, Shelly 3EM / 3EM Pro, Smart Meter Gen 2 (AE1X0)yesGen 2 (read-only)
inverterMI80 standalone (virtual site in API)yes
smartplugSmart Plug 2500 W, Smart Plug Gen 2yesGen 2 (power_switch)
pps / solarbank_ppsPortable power stationsmostly MQTT
ev_chargerV1 Smart EV Chargermostly MQTTModbus TCP (local)
vehicleVirtual EVs for charger accountsread-oriented
powerpanel / hesUS Power Panel, X1 HESlimited APIX1 Modbus TCP (local)
chargerPrime / charging stationsMQTT
home_backupE10, AX170very limited API
Solarbank 3 has cloud/MQTT in this adapter but is not in Anker’s official Modbus register maps.
Device hierarchy (how HA structures entities): discussion #239. Local Modbus setup: Local Modbus (optional).
Typical paths (instance anker-solix.0):
  • anker-solix.0.solarbank.<deviceId>.sensors.* — power, SOC, etc.
  • anker-solix.0.solarbank.<deviceId>.control.* — writable controls where supported
  • anker-solix.0.<device>.<id>.statistics.* — daily kWh (enable Objects → energy statistics)
  • …statistics.week.* / statistics.month.* / statistics.year.* — calendar week, month, year totals in kWh (separate entity groups; polled on detail refresh, not every cycle)
  • Combiner site: statistics only under combiner_box.<id>.statistics.* (not duplicated on system.* or each solarbank.*). Without combiner: per solarbank.* (and smartmeter.* for grid metrics). API queries remain once per site.
  • anker-solix.0.smartmeter.<deviceId>.sensors.*
  • anker-solix.0.services.* — export, schedule, refresh (button states)
  • anker-solix.0.info.connection, anker-solix.0.info.pythonReady
Entity groups (Admin → Objects): map to HA feature sets — power flows, diagnostics, PPS, EV charger, HES, site price, account info, etc. Disabled groups are excluded from API polls to reduce load.
MQTT managed devices
Enable MQTT in Options when you need live data or controls that the cloud API does not provide (many PPS/EV/charger functions).
  • Extra sensors/controls come from MQTT maps in solixapi (community-decoded per model).
  • Real-time trigger and status request behave like HA buttons — automating them 24/7 increases traffic and keeps devices awake (HA MQTT section).
  • Hybrid controls (station SOC reserve, AC limits, grid export on multisystem) need MQTT + API like HA.
  • Devices in MQTT local mode (e.g. E10 behind Power Dock) are proxied via the hub device — see HA INFO – MQTT local mode.
Decoding new models: MQTT guidelines, tool mqtt_monitor.py in anker-solix-api.
Condensed from the HA integration README; cloud/MQTT behavior is the same via solixapi. Local Modbus notes are adapter-specific.
Solarbank 4 E5000 Pro / Solarbank Max / Max AC
Cloud: same poll path as other solarbanks (API + optional MQTT). Daily kWh (statistics.daily_*) is fetched on detail polls (every deviceDetailMultiplier cycles, default ~10), not every minute — check the log for Daily kWh statistics updated. With Power Dock/combiner: values are only under combiner_box.<SN>.statistics.*, not under each solarbank.*. Restart the adapter after enabling Objects → Tagesstatistiken. Week/month/year totals run on the evening schedule (23:00 / 23:15 / 23:30 Europe/Berlin).
Local Modbus TCP (official maps): enable Modbus in the Anker app (system / Three-Party Control), then Admin → Modbus (local). Typical model codes include AE103 (SB4). States: anker-solix.0.modbus.<name>.sensors.* and .control.* (operating mode, SOC limits, battery setpoint in third_party_control). Modbus only skips cloud/Python; the instance LED is green when at least one Modbus device is connected.
If another Modbus client just queried the device, the first poll may get connection refused until that client’s cooldown expires — the next poll interval retries.
Smart Meter Gen 2 / Smart Plug Gen 2
Cloud entities as for other meters/plugs. Local Modbus: Gen 2 meter is read-only (power/voltage/current per phase). Smart Plug Gen 2 exposes power_switch. Each device needs its own IP (port 502).
Standalone inverters (MI80)
Not a full app “power system”, but cloud tracks yields. API creates a virtual site. Inverter Wi‑Fi state in API is often wrong; cloud connection state is more reliable. Do not change inverter limits permanently (hardware write cycles).
Solarbank 1 (E1600)
Cloud updates ~every 60 s while producing/discharging; ~hourly in standby. Schedule bug: a single all-day API slot can set export to 0 W — use ≥2 slots in the app if using output preset. Daily discharge statistic since mid-2024 includes bypassed PV (also wrong in app). MQTT monitoring/control from HA v3.4+/3.5+.
Solarbank 2 + smart meters
Cloud interval often ~5 minutes; control changes may take up to ~6 minutes to appear in sensors. Shared accounts historically had unavailable entities (Anker-side fix). Some output limit API paths still unknown.
Solarbank 2 AC
Time-of-use plans via controls where supported; cloud updates can stall after heavy app use (HA #211).
Combined SB2 + cascaded SB1
Totals/statistics in Anker cloud reflect SB2 only; SB1 is partly a “black box”. Enforced minimal schedule on SB1 when SB2 is manual — some ioBroker/HA controls show unavailable intentionally. For correct charge/discharge energy, sum per-device battery power, not only system NET power (HA details).
Solarbank 3
Smart mode, dynamic price, time-slot modes — often toggle only via API (configure in app first). Dynamic price VAT/fees may be cache-only customizations. Nordpool forecast most reliable.
Multisystem with Power Dock
Up to 4 SB3 units; shared station settings (usage mode, SOC reserve, grid export). Controls consolidated on combiner / Power Dock in integration logic. Cloud data can lag in early deployments. Multisystem AC output limit may not be changeable via API.
Station controls
SOC reserve, PV/AC limits, grid export often need API + MQTT (hybrid). Third-party PV / EV-enable switches are usually one-time app setup — not exposed for automation.
PPS / Solarbank PPS (F3000 + US meter)
Automation-style home backup in US; control mainly via MQTT.
EV charger (V1)
Most metrics/controls via MQTT; member accounts supported. Operational modes map to HA-style state machine — in ioBroker, check available control options before scripts. Session history statistics not implemented (use state history).
Vehicles
Virtual devices per account EV; no creation via adapter — discovered on refresh.
Power Panel & HES (X1)
Limited API power; workaround uses ~5 min averages from energy stats (~80 MB/day extra traffic per system if enabled). Disable heavy categories in Objects if needed.
Local Modbus (X1): enable Modbus TCP in the Anker Solix Professional app, then Admin → Modbus (local) → profile SOLIX X1 HES (or auto-detect). States under modbus.<name>.sensors.* and controls for work mode / battery setpoint (VPP / third-party mode). The X1 accepts only one Modbus TCP client at a time.
V1 Smart EV Charger (local Modbus)
Cloud/MQTT entities remain available when using the Anker account. For local-only control, enable Modbus TCP under Integrations in the Anker app and add profile V1 Smart EV Charger. Controls: start/stop charging, max current (6–32 A). Up to two simultaneous Modbus clients are supported on the charger.
Home Backup (E10, AX170)
Almost no cloud API for system energy; E10 often MQTT local mode via dock.
Other / standalone devices
Only in a power system for full API; otherwise MQTT + community decoding required.
No authcache/<email>.json
The file is created only after a successful API login. If every login returns captcha, copy a working file from ha-anker-solix (custom_components/anker_solix/solixapi/authcache/) into iobroker-data/anker-solix.0/authcache/, same filename as in Account.
(100032) Captcha id empty
Anker blocks some server/VPN API logins. The library cannot solve captcha.
  1. Confirm app login on same LAN; correct country; no VPN on ioBroker host.
  2. Do not clear login cache to “fix” captcha.
  3. Copy authcache from HA or re-login when cloud allows.
  4. Wait 15–30 min after many failed attempts.
  5. Use adapter ≥ 0.9.3 so a valid cache is not discarded on restart.
Log shows exact cache path from 0.9.4+.
Rate limits (26161 / 429)
Increase poll interval; reduce enabled Objects groups; adapter retries and may fall back to one-shot bridge briefly.
Services
States under anker-solix.0.services.* (set to true to trigger):
  • get_schedule, clear_schedule, export_systems, get_system_info, refresh_devices
Uses selectedDeviceId / selectedSiteId from config. See Admin Objects tab (services hint).
ResourceContent
thomluther/ha-anker-solixFull README, INFO.md (config, MQTT, export, tariffs)
thomluther/anker-solix-apiPython API, export, mqtt_monitor
HA discussionsEnergy dashboard, zero export, efficiency
SolixBLELocal BLE (not cloud)
ha-anker-solix-officialOfficial Modbus (local devices)
ioBroker.pvforecastPV forecast (optional input for curtailment avoidance)
German guides/videos linked from the HA README apply conceptually to data and limits; wiring is via ioBroker states instead of HA entities.
Curtailment avoidance (optional)
Tab Abregelungsvermeidung / Curtailment avoidance: requires the ioBroker.pvforecast adapter. (Previously based on ioBroker.solarprognose / solarprognose.de — switched because solarprognose.de is shutting down and that data source is no longer viable.) Set the plant path (e.g. pvforecast.0.plants.pv); power values are read from {path}.power.hoursToday.*. Forecast resolution (60 / 30 / 15 minutes, default 60) must match the interval configured in pvforecast. Controls only: manual mode + ac_output_limit (AC output / export). Does not change station base settings (grid export cap, allow_grid_export, home load preset, AC charge limit). Before: ac_output_limit = live PV. Active: missing_charge_wh, max_charge_w = missing_charge_wh ÷ remaining_hours, export_w = live_pv_wmax_charge_w, ac_output_limit = export_w. After: restore selected mode. States: curtailment.live_pv_w, missing_charge_wh, max_charge_w, export_w, remaining_hours.
Admin: checkbox Combiner box present — without combiner: device ID + solarbank type + battery Wh; with combiner: combiner ID + up to 4 solarbank slots (each slot can be none). Combiner: total AC limit = sum of per-unit limits (SB2 1000 W, SB3 Pro 1200 W, SB4 Pro 2500 W). Standalone: always 800 W.
VIS / VIS-2 dashboard (Energy Home)
Widget set anker-solix in the VIS/VIS-2 editor:
WidgetPurpose
Energy HomePhotoreal house background, live PV / home / grid / battery / EV (manual state bindings)
HTML DashboardAny dashboard.sites.*.html state (live, energy, settings, …)
Site Dashboard (tablet)Same as HTML Dashboard, sized for ~900×700 px
Multi-site OverviewBind to anker-solix.0.dashboard.overview.html
Important: Widgets ship with GitHub main / 0.10.100+ only. npm 0.10.90 does not include them.
From 0.10.104 the adapter copies widgets/ into VIS/VIS-2 file storage on start and triggers a VIS-2 rebuild. After install or update:
  1. Restart the anker-solix instance (or wait for the automatic sync log line).
  2. Reload the VIS/VIS-2 editor (F5).
  3. In the widget picker, open set anker-solix.
If widgets are still missing, run on the ioBroker host:
iobroker upload vis widgets
iobroker upload vis-2 widgets
iobroker restart vis
iobroker restart vis-2
Then reload the editor again. For Energy Home, assign states in widget settings: State bindings, Grid flows, Battery.
Optional VIS-2 view import: widgets/anker-solix/views/energy-home.vis2.json.
Enable Power flows and Energy statistics in adapter Objects for footer values (self-consumption, today PV).
HTML dashboards (solix4-style)
Inspired by ioBroker.solix4 by Michael Horn (@michihorn64) — thank you for the original dashboard concept! Details: CREDITS.md.
After each successful poll the adapter writes self-contained HTML (dark theme, live energy flow, settings, daily kWh, diagnosis, device list) to string states with role html:
StateContent
anker-solix.0.dashboard.sites.<siteKey>.live.htmlLive power flow (Solar → Home ↔ Grid, battery)
…dashboard.htmlLive + settings combined (tablet layout)
…energy.htmlDaily kWh tiles + autarky / self-consumption
…settings.htmlLimits & modes (read-only)
…diagnosis.htmlWarnings, MQTT, device health
…devices.htmlDevice inventory
anker-solix.0.dashboard.overview.htmlMulti-site comparison
<siteKey> is the first 8 characters of the Anker site ID (same idea as solix4).
VIS / VIS-2: add widget HTML Dashboard (set anker-solix) and bind it to e.g. anker-solix.0.dashboard.sites.<siteKey>.dashboard.html, or use the generic VIS HTML widget. Resize to tablet size (~900×700 px). The HTML refreshes on each adapter poll.
Enable Objects → Tagesstatistiken for kWh tiles; enable Leistungsflüsse for live power values.
0.10.105
  • Repo checker (#9): removed forbidden prepare script (E0094); common.news lists npm-published versions only (E2004); enable local hooks with npm run setup:githooks
  • CI (#10): adapter tests on Node.js 22 / 24 / 26; @iobroker/adapter-core → 3.4.3; Modbus TCP read timeout uses adapter.setTimeout (S5005)
  • News translations expanded for remaining npm versions (W1145)
0.10.104
  • VIS / VIS-2: widget set anker-solix is copied to VIS file storage on adapter start; VIS-2 catalog rebuild triggered automatically
  • VIS widgets: HTML Dashboard, Site Dashboard (tablet), Multi-site Overview (bind dashboard.*.html states) plus existing Energy Home
0.10.103
  • HTML dashboards (solix4-style): live flow, settings, daily kWh, diagnosis, devices, overview under dashboard.sites.*.html — inspired by ioBroker.solix4 (Michael Horn / michihorn64); see CREDITS.md
0.10.102
  • Fix: daily kWh statistics for SB4 / Power Dock — info/warn logs when cloud fetch runs or returns empty; recover poll state that could skip daily energy forever; fallback to solarbank.*.statistics.* when combiner site has no combiner_box object yet
  • Admin: hint under energy statistics (daily vs week/month/year schedule, combiner path)
0.10.101
  • Modbus (local): profiles for Anker SOLIX X1 HES and V1 Smart EV Charger (official protocol register maps; X1 little-endian 32-bit and string decode; existing Solarbank/Gen2 profiles unchanged)
0.10.100
  • VIS Energy Home: duplicate grid-to-home flow line fixed — remove legacy grid SVG paths, show only import or export line at a time (GitHub-only)
0.10.99
  • VIS Energy Home: VIS-1 duplicate grid/battery cards fixed — widget destroy/cleanup on re-render, legacy card removal, cache-busted CSS/JS (GitHub-only)
0.10.98
  • VIS Energy Home: single always-visible grid and battery power cards; label and value switch between import/export and charge/discharge while flow lines show direction (GitHub-only)
0.10.97
  • VIS Energy Home: grid and battery power cards share one slot each and toggle by active flow — Grid → Home vs PV → Grid, Entladen vs Laden (GitHub-only)
0.10.96
  • VIS Energy Home: energy flow lines realigned to the Home hub (PV, grid import/export, battery charge/discharge, EV); SVG coordinates now match card positions (GitHub-only)
0.10.95
  • VIS Energy Home: separate cards for Grid → Home, PV → Grid, SOC, charge, and discharge; dedicated flow lines per direction; widget settings grouped into Grid flows and Battery (GitHub-only)
0.10.94
  • VIS Energy Home: removed auto-discovery and card hiding; all states (PV, home, grid import/export, SOC, battery charge/discharge, EV, footer) are assigned manually in widget settings (GitHub-only)
0.10.93
  • VIS Energy Home: grid uses grid_to_home_power (import) vs photovoltaic_to_grid_power (export); battery uses bat_charge_power vs bat_discharge_power; energy line animation direction matches flow (GitHub-only)
0.10.92
  • VIS / VIS-2 Energy Home: clean house background (no baked-in UI); slim animated SVG energy lines and cards as overlays; broader auto-discovery (system, combiner, smartmeter, solarbank, modbus, ev_charger); all cards always visible; live view subscribes discovered states (GitHub-only until next npm release)
0.10.91
  • VIS / VIS-2: first Energy Home widget (auto state discovery, combiner/modbus aware); restartAdapters vis + vis-2; requires iobroker upload anker-solix after install (GitHub-only until next npm release)
0.10.90
  • Modbus only: skip Anker cloud/Python when the checkbox is enabled; no credentials or usage terms required; instance LED is green when at least one local Modbus device is connected
  • Docs: README supported devices + special notes for SB4 / Max / Modbus Gen 2; valid state roles for usage-mode and EV-charger lists; Modbus admin i18n
0.10.89
  • Admin: fix GUI error when opening Modbus (local) (hidden must use data.enableModbus; table items as array with attr)
  • Docker: buanet guide uses stock Python 3.11 as default (0.10.87 best-effort); 3.12 image/userscript optional
0.10.88
  • Modbus (optional): local TCP poll and control for official devices (Solarbank 4 / Max AC / Max, Smart Meter Gen 2, Smart Plug Gen 2); cloud Python bridge unchanged
  • Docker: buanet/iobroker Python guide (docs/docker-buanet.md)
0.10.87
  • Python: Debian 12 Bookworm Docker containers (e.g. buanet v11) accept system Python 3.11 as best-effort; all other hosts still require 3.12+
0.10.86
  • Solarbank 1 (E1600): writable preset_charge_priority (0–100 %) and preset_discharge_priority (switch) via set_home_load — not applicable to SB2/SB3
0.10.85
  • Admin: curtailment hint/path labels use new i18n keys so Admin no longer keeps stale solarprognose.de text after the pvforecast switch
0.10.84
  • Curtailment: switch forecast source from solarprognose.de / ioBroker.solarprognose to ioBroker.pvforecast because solarprognose.de is shutting down. Plant path (…power.hoursToday); resolution option 60/30/15 min (default 60). (0.10.82/0.10.83 were not published: CI lint / unpublished news entries.)
0.10.83
  • Fix: CI lint for curtailment/pvforecast (prettier, require-await, redundant type unions) — not published (see 0.10.84)
0.10.82
  • Curtailment: switch to pvforecast (solarprognose.de shutting down) — not published (CI lint failure; see 0.10.84)
0.10.81
  • Repository review (mcm1957): restore standard test-and-release workflow — adapter tests on every push/tag (Linux + Windows matrix), deploy only after all jobs succeed (no always() / no skipped-tests workaround); declare linux + win32 in package.json; README: Windows supported & tested, macOS not supported
0.10.80
  • Object dump fix: persist periodScheduleOffsetSec via extendForeignObjectAsync on system.adapter.<instance> (avoids invalid anker-solix.0.system.adapter.* object without type/common, E3004/E3007)
0.10.79
  • Repository re-review: per-instance period energy schedule jitter; sensor-kind state name migration; remove unused curtailmentModeBefore; document Linux + tested Windows support
0.10.78
  • Adapter-check: use adapter.setTimeout instead of plain setTimeout (E5005)
0.10.77
  • Repository review: English-only log messages; English default state names and list labels (common.name/common.states)
0.10.76
  • Object structure: list controls use role state (max_total_ac_output, EV charger mode lists; E1008/E1009)
0.10.75
  • Object structure (PR review): folder → device → channel hierarchy before states (E3009); valid ioBroker roles/types (E1008/E1009/E1011)
  • Dev: @alcalzone/release-script 5.2.1 (E0036)
0.10.74
  • TypeScript 6 (W0083); tsconfig.json adds mocha types for tsc --noEmit
  • CI: testing-action-adapter and testing-action-deploy use @v1 (S3043/S3044); testing-action-check stays @v2.0.0 (no floating @v2 tag)
  • Tests: npm pack must exclude CHANGELOG_OLD.md (S9508)
0.10.73
  • README: removed discouraged GitHub-URL installation section (adapter-check E6013)
  • Tests: test/io-package-policy.js guards against GitHub URL install text in README
0.10.72
  • Repository checker: admin i18n synced for all languages (W5604/W5605); package.json os aligned with Linux CI (E3027)
  • Tests: test/i18n-policy.js and E3027 check in test/io-package-policy.js
0.10.71
  • Python install: detects host profile (Linux server, Home Assistant ioBroker add-on, Windows, container)
  • HA: venv-first, get-pip.py with --break-system-packages / PIP_BREAK_SYSTEM_PACKAGES for PEP 668
  • Windows: tries py -3.13, py -3.12, Program Files paths; parses --version (no broken shell -c check); adds tzdata for Europe/Berlin
  • Bridge: uses resolved Python spawn spec (py -3.12 args) consistently in daemon and one-shot mode
  • Deps check: aiohttp + ZoneInfo("Europe/Berlin") before skipping install
0.10.70
  • Repository / CI: common.news capped at 7 npm-published versions; workflow concurrency per ioBroker.example; admin header size ≤ 5; automated checks in test/io-package-policy.js; CHANGELOG_OLD.md excluded from npm package
0.10.69
  • Curtailment: after midnight (Europe/Berlin) phase inactive until solarprognose forecast signature changes; then safe modeAfter release (no export while waiting)
0.10.68
  • Admin: Python install button at bottom of Options tab
0.10.67
  • Admin: removed Devices tab and cloud device reload; device filter on Objects; Login cache tab rightmost
0.10.66
  • Admin: device list and login-cache status via useNative responses
0.10.65
  • Login cache tab: backup/restore; auto-backup after first login
0.10.64
  • Curtailment admin: hint text; combiner vs standalone field toggle fix
0.10.63
  • Fix bat_discharge_power; admin: terms under Account, Objects tab, curtailment UI (combiner / solarprognose link)
0.10.31
  • Week/month/year statistics: fetched once per day after 23:00 / 23:15 / 23:30 (Europe/Berlin) on the next detail poll, not every detail refresh
0.10.30
  • Week/month statistics: fetched like Home Assistant (energy_daily, device_sn empty for site totals); avoids energy_analysis 10003 with combiner SN; year still via energy_analysis
0.10.29
  • Curtailment: instance setting Minimum live PV (W) (curtailmentMinPvW, default 50); fix ESLint/Prettier CI failure on 0.10.28
0.10.28
  • Curtailment: manual mode and ac_output_limit only when live PV ≥ 50 W — no midnight feed-in from forecast (fixes 4800 W at livePv=0)
0.10.27
  • Period energy_analysis: per-call retry on 10003, partial metrics if only some calls fail; uses combiner/solarbank SN; success log only when kWh values exist
0.10.26
  • Week/month period stats: fetched on first detail refresh when only period groups are enabled (not after ~30 min); week interval = every detail refresh (was every 3rd); log line Period statistics updated (week)
0.10.25
  • Fix: curtailment.soc_percent state object is created on start (was missing since 0.10.16)
0.10.24
  • Fix: NameError: needs_daily_energy_poll / missing PERIOD_YEAR imports in 0.10.23 (incomplete release)
0.10.23
  • Fix: missing _update_energy_periods crashed the bridge daemon (AttributeError) → one-shot fallback and extra 429 load
  • Year/month/week only: skips daily poll_device_energy (no “today” entity group); period energy_analysis only every Nth detail refresh (year ≈ 8×)
  • On 429: no one-shot fallback; period stats back off 30 min; parallel polls skipped
0.10.22
  • Energy statistics (daily + week/month/year) only on combiner_box when a combiner exists; no duplicate states under system.* or each solarbank.*
0.10.21
  • Fix: IoBrokerAnkerApiClient stored no config → daemon crashed (AttributeError), one-shot bridge fallback, extra API load and 429 rate limits
  • Week/month/year energy_analysis calls are rotated (one period per detail refresh) instead of all three at once
0.10.20
  • Period energy statistics (week / month / year) use subfolders: statistics.week.*, statistics.month.*, statistics.year.* (instead of flat week_* under statistics.*)
  • Release 0.10.19 tag had no npm deploy (CI lint); install 0.10.20 or newer
0.10.18
  • Entity groups Weekly / monthly / yearly energy statistics (enableEnergyStatisticsWeek|Month|Year): kWh totals for current calendar week, month, and year via Anker energy_analysis API
0.10.17
  • Fix: Stale build/ still ran old curtailment code that set grid export limit (grid_export_limit) to up to 4800 W on adapter start (App: Netzeinspeisungs-LeistungsgrenzeAnpassen). Rebuilt build/ from current TypeScript; tests verify compiled curtailment never touches feed-in controls
0.10.16
  • Combiner sensor total_state_of_charge: cloud total or capacity-weighted average of all site solarbanks (poll + ioBroker state)
  • Curtailment uses total SOC for missing_charge_wh, max_charge_w, and soc_percent
0.10.15
  • Curtailment: ac_output_limit via API only (no MQTT) to avoid station side effects
  • Fix SOC handling when combiner had no SOC (max_charge_w wrong); ensure missing_charge_wh state exists on upgrade
0.10.14
  • Curtailment: only manual mode + ac_output_limit (no grid_export_limit, allow_grid_export, home load preset, AC charge limit)
  • New state curtailment.missing_charge_wh; active phase: export = live PV − calculated max charge
0.10.12
  • Curtailment combiner: export via ac_output_limit (max_load); home load preset 0 W (superseded by 0.10.14+)
0.10.11
  • Curtailment: prefer system.{siteId}.sensors.total_pv_power for live PV
0.10.10
  • Curtailment combiner: export via set_output_power (later replaced); 4800 W cap; more PV sensors for live_pv_w
0.10.9
  • Curtailment active phase: AC output = full PV (intermediate behaviour; refined in 0.10.14+)
0.10.8
  • Curtailment: before = instant export = live PV; active = slow battery charge + export surplus
0.10.7
  • Curtailment: export limit follows live PV; updates when generation sensors change
0.10.6
  • Curtailment: manual mode, no charge, export limit from hourly forecast (also before curtailment window)
0.10.5
0.10.4
  • Curtailment Admin: combiner checkbox, device ID + solarbank type (standalone) or 4 slots with “none” (combiner); no usage-mode change before curtailment window
0.10.3
  • CI: curtailment unit tests use Mocha/Chai (fixes adapter-check lint)
0.10.2
  • Curtailment AC limits: standalone 800 W; combiner per unit SB2 1000, SB3 1200, SB4 2500 W
0.10.1
  • Curtailment: Combiner limit = sum of per-unit profiles (max 4 mixed solarbanks)
0.10.0
  • Optional curtailment avoidance via solarprognose forecast (Admin tab, curtailment.* states)
0.9.9
  • package.json keyword ioBroker; entity group headers with schema size property
0.9.8
  • Admin UI: all option/entity fields with lg/xl breakpoints; CI release fix
0.9.7
  • Adapter-check: npm news sync, admin responsive layout, README copyright, npm package excludes Python cache
0.9.6
  • Adapter-check compliance: Node 22+, admin UI sizes, compact-mode Python install, dependabot
0.9.5
  • Admin warning before Clear Anker login cache; log after clear
0.9.4
  • Log exact authcache path when login cache file is missing
0.9.3
  • Fix: Valid authcache no longer treated as failed login after restart (captcha 100032)
0.9.2
  • Keep authcache on re-auth; reload token on 401 before forced login
0.9.1
  • Captcha error 100032 mapping and README troubleshooting
0.9.0
  • Configurable entity groups (HA-style); API scope follows enabled groups
0.8.1
  • Fix Python bridge ApiCategories.device_parm crash
0.8.0
  • Daily energy statistics under statistics.*
0.7.0
  • Usage mode preset_usage_mode, AC fast charge switch
0.6.0
  • Persistent bridge daemon, HA-aligned poll, multisystem controls, rate-limit fixes (see CHANGELOG_OLD.md for 0.6.1–0.6.5)
0.5.0
  • Python auto-install, device selection, staggered polling, repository rename (see CHANGELOG_OLD.md for 0.2.0–0.4.2)
Older release notes: CHANGELOG_OLD.md and git history.
Publishing (npm & ioBroker catalog)
npm: Release via git tag (v*) and CI deploy after adapter check is green. Publishing uses npm trusted publishing (OIDC from GitHub Actions — no long-lived npm token). Classic automation tokens are deprecated by npm from January 2027; this adapter is already on trusted publishing. Register in ioBroker.repositories once the package is on npm.
Before each release (enforced by npm run test:packagetest/io-package-policy.js; run locally via npm run verify:ci before every push):
  1. Bump version in package.json and io-package.json (must match).
  2. Add a ### x.y.z section to this README changelog (E6006).
  3. Add one new common.news entry for that version only when publishing to npm (tag v*); keep at most 7 news keys — only versions already on npm (plus the version you are about to publish). GitHub-only interim versions must not appear in common.news (E2004). Move removed text to CHANGELOG_OLD.md. Document all versions in this README changelog.
  4. Admin jsonConfig.json: header size must be ≤ 5 (use 5 for smallest heading).
  5. Do not add root files to npm files unless needed (CHANGELOG_OLD.md stays out of the package).
  6. package.json os must match the OS matrix in test-and-release.yml (E3027). Keep admin i18n/*.json in sync with en.json (W5604/W5605).
  7. Do not add a prepare script (E0094). After clone, run npm run setup:githooks once so the pre-push hook runs verify:ci.
Copyright (c) 2026 MatthiasUlrich1 info@my-smart-home-support.de
MIT — see LICENSE
