Amazon Dash-Button
Adapter for Amazon Dash buttons
Current Release
1.2.0
Patrick Arns
Adapter to detect the presses on Amazon Dash Buttons in ioBroker.
This adapter does not work under Windows!
Steps
  1. Install libpcap-dev:
sudo apt-get install libpcap-dev
  1. Pair your Dash-Adapter within the Amazon App but don't select a product! Just quit the installation procedure at the product selection tab. Otherwise, you'll order every time a product ;) German instructions.
  2. Hit the dash button (should be white first, then flashing red)
  3. Within the adapter objects, a new dash button should appear which you can use to start scenes or within the JS adapter
  4. Sometimes it is required to give the network access rights to node:
sudo setcap 'cap_net_raw,cap_net_admin+eip' $(readlink -f $(which node))
HELP WANTED!
As this project is developed during my spare time. I`m actively looking for help to maintain and extend this adapter! If you're willing to help, drop me a line!
1.2.0 (2023-02-10)
  • (bluefox) added option to execute setcap rights by every start
1.1.0 (2020-02-25)
  • (foxriver76) support of compact mode
  • (foxriver76) usage of adapter-core and eslint
1.0.1
  • (Apollon77) BREAKING: Upgrade pcap library supports nodejs 10+ and also supports nodejs 12
0.3.1
  • (PArns) Added new Amazon MAC family
0.3.0
  • (foxriver76) materialize ui
  • (foxriver76) dash buttons are now of type device
0.2.9
  • (cernst1980) Ignore duplicate ARPs for 5 seconds
0.2.8
  • (offline4ever) Added new Amazon MAC family
0.2.7
  • (arteck) fixed MAC parsing
0.2.6
  • (arteck) edit admin
  • (arteck) add manual MAC Addresses
0.2.5
0.2.4
0.2.3
0.2.2
  • (PArns) Fixed function name in description
0.2.1
0.2.0
  • (PArns) Simplified MAC lookup (thx to GermanBluefox)
0.1.2
0.1.1
  • (GermanBluefox) Try to install libpcap-dev automatically
0.1.0
  • (Niksac) Added the ability to select an interface
0.0.5
  • (PArns) Fixed lastPushed
  • (PArns) Fixed GIT dependency which might cause problems on some systems
0.0.4
  • (PArns) Removed debug infos
0.0.3
  • (PArns) Fixed switch state
0.0.2
  • (PArns) Added switch state, which toggles between true and false
  • (PArns) Changed License
0.0.1
  • (PArns) Initial release
The MIT License (MIT)
Copyright (c) 2016-2023 Patrick Arns npm@patrick-arns.de
