Alpha ESS
Read and write data from and to Alpha ESS systems.
Current Release
4.1.0
Gaspode
alpha-ess adapter for ioBroker
For support please open a GitHub issue or visit
https://forum.iobroker.net/post/892023 https://www.storion4you.de/thread/683
This adapter logs into the web API of Alpha-ESS and retrieves information for your Alpha-ESS equipment.
Depending on your Alpha-ESS product, it is possible to get realtime data and configuration data for your equipment. Which data points are returned by the API depends on your Alpha-ESS equipment.
This adapter uses the Alpha-ESS Open API, which is an official and documented API for Alpha-ESS devices.
The quality attribute of each state is set accordingly to its status:
Qualitymeaning
0x00OK and up to date
0x01value not updated due to unknown reason, see debug log
0x02problem with online connection for this data point
0x12adapter disconnected or stopped
0x44API returned error or internal error, see debug log
Settings:
To be able to use the Alpha-ESS Open API, you have to register your Alpha-ESS device unter https://open.alphaess.com. Once registered, you get a developer ID and a developer key (called "Secret"). You will need these to have access to the Open API. How to find SN and Check code for registration is described here: https://github.com/alphaess-developer/alphacloud_open_api
  • Personal application ID: The application ID (see above)
  • Personal application Secret: The application Secret (see above)
  • Alpha-ESS System ID: The S/N (serial number) of your Alpha-ESS equipment
  • Interval to read realtime data: Unit: seconds.
  • Interval to read energy data: Unit: minutes.
  • Interval to read charging settings: Unit: minutes.
  • Interval to read discharging settings: Unit: minutes.
  • Interval to read summary data: Unit: minutes.
  • Interval to read wallbox data: Unit: minutes. Caution: Currently only one Wallbox is supported.
  • Update unchanged states: If this option is checked, states are changed even if the corresponding value is unchanged.
Disclaimer
All product and company names or logos are trademarks™ or registered® trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them or any associated subsidiaries! This personal project is maintained in spare time and has no business goal.
4.1.0 (2026-02-14)
  • (Gaspode) Read and write wallbox current
4.0.0 (2025-11-01)
  • (Gaspode) Update dependencies, Node.js version 20 or later is now required
3.0.1 (2024-12-22)
  • (Gaspode) Optimizations of reading pseudo-realtime power data for slow systems
3.0.0 (2024-12-21)
  • (Gaspode) Breaking Change: Renamed state "Charging_period 1_end" to "Charging_period_1_end"
  • (Gaspode) Optimizations in configuration dialog
2.3.0 (2024-12-20)
  • (Gaspode) Provides the ability to read pseudo-realtime power data using the API function getTodayPowerBySn. This feature is useful for systems that lack "realtime data support." When activated, data is fetched every 5 minutes and stored in the "Recent" folder.
2.2.0 (2024-12-16)
  • (Gaspode) Provide system information data (getEssList)
2.1.6 (2024-12-01)
  • (Gaspode) Migrated to ESLint 9
2.1.5 (2024-11-14)
  • (Gaspode) Optimized GUI for all screen resolutions (responsive design)
2.1.4 (2024-08-13)
  • (Gaspode) Updated some formal stuff
2.1.3 (2024-08-07)
  • (Gaspode) Increased read timeout from 10 to 20 s
2.1.2 (2024-08-07)
  • (Gaspode) Quality of states optimized
2.1.1 (2024-08-07)
  • (Gaspode) Do not longer report read timeouts as error. It should be enough to set the quality of concerned states to values according the table above and to display warnings, if values were not updated for a long time. To see details, debug log level must be enabled by the user.
2.1.0 (2024-08-01)
  • (Gaspode) Adapter requires node.js >= 18 and js-controller >= 5 now
  • (Gaspode) Dependencies updated
  • (Gaspode) Adapter logo updated. Alpha-ESS has kindly permitted to use the Alpha-ESS logo. This does not imply any affiliation with Alpha-ESS! Alpha-ESS is not the developer or provider of this adapter!
2.0.2 (2024-01-12)
  • (Gaspode) Updated Copyright year
2.0.1 (2024-01-03)
  • (Gaspode) Adapted timeout to new API restrictions
2.0.0 (2023-12-02)
  • (Gaspode) Breaking Change: Removed support of Closed API
1.3.0 (2023-11-22)
  • (Gaspode) Support wallbox with Open API
  • (Gaspode) Start and stop charging of wallbox with Open API
1.2.1 (2023-11-11)
  • (Gaspode) Fixed severe error in ClosedAPI
1.2.0 (2023-11-10)
  • (Gaspode) Added additional realtime attributes for OpenAPI
1.1.1 (2023-11-04)
  • (Gaspode) Closed API adapted to latest Alpha-ESS changes and enabled again
1.1.0 (2023-11-04)
  • (Gaspode) Closed API disabled (temporarily?) because API has been changed by Alpha-ESS
  • (Gaspode) Read back changed settings values 2 seconds after they have been changed
1.0.2 (2023-10-05)
  • (mcm1957) Updated required node version to 16 or newer
1.0.1 (2023-10-03)
  • (Gaspode) Adapted fetching energy values using 'Closed API' to latest API changes by Alpha-ESS
1.0.0 (2023-06-20)
  • (Gaspode) Support also the new official OpenAPI provided by Alpha-ESS
  • (Gaspode) Set state quality accordingly to status of data
  • (Gaspode) Writing charging and discharging settings implemented for 'Closed API' and OpenAPI
  • (Gaspode) Remove no more supported states at startup automatically
0.4.0 (2023-02-16)
  • (Gaspode) Optimized deletion of group states
  • (Gaspode) Added new Realtime state for pmeter_dc
0.3.0 (2023-02-11)
  • (Gaspode) Read selected statistical data
  • (Gaspode) Added Summary data
  • (Gaspode) Refactored complete implementation
  • (Gaspode) Changed the unit of settings for all intervals, except of realtime data, to minutes (Caution: settings are reset to defaults)
  • (Gaspode) Remove disabled states at adapter startup
  • (Gaspode) Removed no more supported value 'createtime' (state ID Realtime.Last_update).
  • (Gaspode) Optimized rounding for selected values
  • (Gaspode) Added states EV1_power, EV2_power, EV3_power and EV4_power to Realtime folder
0.1.0 (2023-01-15)
  • (Gaspode) First release for Latest repository
  • (Gaspode) Corrected typo in state ID Battery_SOC
  • (Gaspode) Implemented improvements as suggested in code review
  • (Gaspode) Slow down requests in case of permanent errors
  • (Gaspode) Changed adapter type from metering to energy
  • (Gaspode) Correction for NPM
  • (Gaspode) Enable NPM
0.0.5
  • (Gaspode) Use meaningful state names
  • (Gaspode) Use suitable state roles
  • (Gaspode) Added new state for Alpha-ESS settings parameter 'upsReserve'
0.0.4
  • (Gaspode) use axios to perform Alpha-ESS API calls instead of deprecated request
  • (Gaspode) New option "Update unchanged states" added
0.0.3
  • (Gaspode) refactored API calls, added daily energy values
0.0.2
  • (Gaspode) corrected api call for realtime data
0.0.1
  • (Gaspode) initial release
Copyright (c) 2025-2026 Gaspode gaspode69@online.de (NO SUPPORT VIA EMAIL)
