Alexa Timer for Vis
Output Alexa timer to display timers in the VIS
Current Release
3.0.3
Michael Roling
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and instructions on disabling error reporting, please refer to the Sentry-Plugin Documentation! Use of Sentry reporting starts with js-controller 3.0.
alexa-timer-vis adapter for ioBroker
Output Alexa timer to display in the vis
If you like it, please consider a donation:
paypal
This is an example of my vis
Functionality
A timer or several by voice input, is created via Alexa, this is evaluated by the adapter and written in states in order to make them visible in the Vis. So you have a better overview if you have several timers active at the same time.
  • ---- Alexa2 Adapter is needed ----
  • The Vis Widget isn´t yet integrated
  • Every Timer has a button, to stop it. Stops the Timer in Alexa and in the Adapter
  • Unlimited timers can be created with Alexa by voice command.
  • On adapter start, 4 folders will be created with all states.
  • Additional folders will be created as soon as a 5th and more timers are created via Alexa's voice input.
Timer add ( Examples )
  • Alexa, Timer 5 minutes
  • Alexa, fries Timer 9 minutes
  • Alexa, set a timer for 1 hour and 30 minutes
  • Alexa, set a Timer for 2 hours
  • Alexa, Timer for 120 minutes
  • Alexa, Timer 9 minutes Spaghetti
Timer delete ( Examples )
  • Alexa, delete all Timers
  • Alexa, delete fries Timer
  • Alexa, delete 5 minutes Timer
If you have any suggestions for improving something or adding other functions, feel free to contact us
3.0.3 (2026-06-12)
  • FIX: #295 Extend timer
  • CHORE: Update dependencies
3.0.2 (2026-05-30)
  • CHORE: Repository checker
  • FIX: #288 Stop timer
3.0.1 (2026-05-23)
  • FIX: Update connection state to true when initializing AlexaTimer
3.0.0 (2026-05-23)
  • FIX: #270 Errors has no existing object
  • FEAT: Complete refactored with new logic, it should work with all languages which are supported by Alexa2 adapter
  • Chore: Alexa2 adapter version >= 3.28.1
2.2.2 (2025-12-12)
  • FIX: Errors reported by sentry
Copyright (c) 2021-2026 Michael Roling michael.roling@gmx.de
