ioBroker.vis2-materialdesign
Material Design widgets for ioBroker VIS 2
This adapter is maintained by typhosj. The widgets are based on the original VIS Material Design widget work by Scrounger.
Documentation: Deutsch · English
Design status
Every widget ships two presentations, selected per widget in the editor under General → design style:
- Material 3: Material 3 color roles, shape, type and state layers. The preset for newly inserted widgets.
- Classic: the established Material Design 2-era look. Unchanged, and what every widget of an existing project keeps using.
- Project default: follows the default style set in the adapter's Design tab, for switching a whole project at once.
Newly inserted widgets appear in Material 3. Existing projects stay classic and unchanged until you switch a widget over or change the project default in the Design tab.
Material 3 changes presentation only. Component IDs, option names, object IDs, state values, write behaviour, timers and navigation are identical in both modes, so switching a widget back and forth never changes what it does.
Switching an existing project
- Select a widget, open General → design style and pick
Material 3. - Any color, font or size you explicitly configured still wins — Material 3 only fills in the values you left empty. To let a widget follow the Material 3 palette, clear those fields.
- Switch widget by widget and check the result, or set the default style in the
adapter's Design tab and leave the widgets on
Project default; a saved project is never converted implicitly. - Setting the style back to
Classicrestores the old look exactly.
Dark mode follows the same vis2-materialdesign.0.colors.darkTheme state the
classic widgets already use: auto takes it from VIS 2's own theme, light
and dark force one. The adapter's Design tab takes one seed color and
derives the complete Material 3 scheme from it — all 18 roles, light and dark,
with every on-* pair — into vis2-materialdesign.0.colors.md3Scheme, which the
widgets read. Leave the seed empty and you get Google's contrast-verified
Material 3 baseline palette.
Requirements
- ioBroker with Admin 7.6.20 or newer
- Node.js 22 or newer
- an installed VIS 2 adapter
- a current Chromium-based browser or Firefox (target environment)
Vibration feedback depends on the browser and device. See the browser compatibility table.
Installation
Install Material Design Widgets (vis2-materialdesign) from the ioBroker
Admin adapter list. No separate adapter process is needed for widget delivery.
Quick start
- Open the VIS 2 editor and a project.
- Open the Material Design widget set.
- Drag a widget into the view and select it.
- Configure its object ID and behaviour in the WIDGET tab.
- Save the project and test the view in runtime mode.
Theme use is optional. Configure colors and fonts in the adapter's Theme Editor, save them, then use Theme → use theme on a selected widget. This copies the matching theme references into that widget; explicit widget settings can still be changed afterwards.
Documentation
Support
Report current VIS 2 problems in the GitHub issue tracker.
Feedback on the Material 3 style — how it looks and feels next to what you know from the original adapter, not only what crashes — has its own form: Material 3 design feedback. Material 3 is the style newly inserted widgets get; the classic style stays a full per-widget option and is not deprecated, so nothing you report is a reason to wait with an upgrade.
- (typhosj) Fixed the JSON Chart flashing its red "Error in JSON string" for the first moments of every page load: an empty datapoint — which is what the widget sees until the first value of its subscription arrives — was read as a broken JSON string. Only content that really is malformed reports the error now. The Top App Bar showed the same error on a drawer whose JSON string had not been filled in yet
- (typhosj) Fixed a short appointment showing no name at all in the Calendar's week and day view: an appointment box is as tall as the appointment is long, so a 15-minute entry got about 14 px while the stacked time and name lines needed 44 px. Time and name share one line with an ellipsis now, an appointment long enough to have the room wraps instead of being cut, and hovering an entry — which is the first tap on a touch device — opens it to its full text. Every entry carries its full text as a tooltip as well, and the month view opens the same way
- (typhosj) Fixed the Calendar ignoring event height outside the month view: the option sits in the editor for every view but only the month grid ever applied it. In the week and day view it now sets the minimum height of an appointment box, which is the second way to make short appointments readable
1.0.0 (2026-09-07)
- (typhosj) Added a second design style, Material 3, selectable per widget under General → design style, plus Project default for switching a whole project at once from the adapter's new Design tab. Material 3 is the preset for newly inserted widgets; every widget of an existing project stays classic until you switch it over, and switching back restores the old look exactly — the style changes presentation only, never component ids, option names, object ids, values, write behaviour, timers or navigation
- (typhosj) Added the Material 3 color system: one seed color in the Design tab derives the complete scheme — all 18 roles, light and dark, with every
on-*and-containerpair — intovis2-materialdesign.0.colors.md3Scheme, which the widgets read. An empty seed gives Google's contrast-verified baseline palette. The color math runs once per save in the admin, never in the widget runtime - (typhosj) Added the Material 3 type scale, shape scale and component geometry, plus the static half of Material 3 Expressive (state layers, elevation, corner and motion tokens). A size, color or font you set explicitly still wins in both styles — Material 3 only fills in what you left empty
- (typhosj) Added Material Symbols Outlined as an opt-in second icon source next to Material Design Icons. Pick it in any icon field with the Symbols button; names are stored with an
ms-prefix. Both fonts are self-hosted, and a panel downloads one only when a glyph from it is actually drawn - (typhosj) Added a show advanced options switch to every widget, right below the design style: it hides the rarely used option groups so the editor opens on what a widget is normally configured with. A widget that already carries advanced values keeps showing them without the switch
- (typhosj) Migrated the charts from Chart.js 2.9.4 to 4.5.1. Existing chart configurations keep their option names and values
- (typhosj) Added the value labels and grid options the JSON Chart was missing: it now carries the same bar values group the Bar Chart has (show / auto / off, decimals, appended unit, font and color), its value axis can hide its grid or set its color, and its category grid can sit between the categories instead of running through them. A chart that leaves the options unset keeps drawing no labels
- (typhosj) Added background color, border color, border width and corner radius for the value labels of the Bar, Pie and Line History charts (upstream wish #68)
- (typhosj) Added an alternating row color to the Table widget, so every second row can carry its own background (upstream wish #127)
- (typhosj) Reworked accessibility: keyboard semantics and accessible names for clickable cards, icon lists, table headers and the alert close button, and measured contrast plus WCAG 2.5.8 target sizes for the Material 3 controls
- (typhosj) Reworked the editor language: 94 Ukrainian labels that were not translations but shouted English ("CENTER", "DATAPOINT", "ROTATE 90 DEGRESS") are gone, the remaining English labels are translated in the other nine languages, the plain-language dropdown values (on/off, none, contains, exists, left/right/top/bottom, 12 h / 24 h) are translated in all 11, and the adapter description in the admin list no longer describes the VIS 1 adapter. About 700 entries in total; the documented Material and chart.js variant names (filled, tonal, outlined, pie, doughnut, standard, dense, …) stay verbatim so the editor keeps matching the documentation
- (typhosj) Fixed the Value widget's calculation, condition and color expressions running the datapoint's own text as program code, and the iframe dialog's address skipping the URL check every other link in the widget set goes through. In both cases something outside the project — an MQTT topic, an HTTP response, a cloud adapter, an imported view — could have code of its own executed in every browser showing the page. The same change ends two crashes the expressions caused: a condition compared against a text state, and a mistyped expression, each blanked the whole view instead of just that widget
- (typhosj) Fixed eight layout defects with one cause, VIS 2 clipping the widget box: the card layouts of the four charts, the List, the Table and the Material 3 elevated button lost their shadow and rounded edge, and the Bar and Line History charts lost their bottom axis and legend when "use card" was on
- (typhosj) Fixed the Table drawing a divider under the last row, the calendar day button being cut off in the week and day view, the Card widget's "Horizontal" layout having no styling at all, the doughnut chart placing its value labels outside the colored ring, and the Round Slider drawing nothing at all at a full 360° arc
- (typhosj) Fixed the number options of Progress, Progress Circular, Slider, Round Slider, the buttons and the Value widget falling back to 0 instead of their declared default once the field was emptied in the editor — the same drift the Calendar was fixed for in 0.3.5, in the copies that were left behind. A Progress whose maximum had been cleared stood at 0 % whatever the datapoint said, and a Value whose "max decimals" had been cleared dropped every decimal place
- (typhosj) Fixed the Table shifting the columns of every row that carries one field fewer than the first: each row was read against its own field order, so one missing field slid the rest of that row a column to the left. Every row follows the columns of the first row now
- (typhosj) Fixed read-only and "working"-locked sliders, switches, checkboxes and buttons still vibrating and playing the click sound on every touch while refusing to move, and a slider drag that the phone takes away — an incoming call, a palm on the screen — still sending the value the finger rested on a moment afterwards
- (typhosj) Fixed the duration and timestamp formats eating their own unit labels: every d, h, m and s in the text counted as a format token, so
hh:mm [Std]came out as08:30 St0. Text in square brackets stays literal now, the way it did in the VIS 1 widgets - (typhosj) Fixed the per-view visibility condition of the Masonry and Grid containers doing the exact opposite of what it says: a view with "== 1" was hidden precisely while its state was 1 and shown at every other value. The condition that holds shows the view now, the way the same operators have always worked in the Icon List. A project that flipped its condition to work around this —
!=where==was meant — needs it flipped back - (typhosj) Fixed the classic style ignoring the dark mode of VIS 2. Its colors were all drawn for a light page: the input, select and autocomplete labels, the list sub-text, the table cells and the calendar controls sat at 1:1 against a dark background, the drawer of the top app bar let its entries inherit the page color, which put white text on its white surface and black text on it once the surface followed the theme — they take the ink their own surface asks for now, whichever way a theme binding paints it, cards — the html card, the list and icon list cards, the table card, the four chart cards, the dialog and the select dropdown — stayed white islands, and the outlined inputs, selects, cards and tables lost their border entirely. Text, the surfaces a widget paints itself and its hairlines follow the theme now, and the accent blue takes a lighter tint where the dark surface would otherwise leave it at 3.3:1. The progress label follows the theme too instead of drawing the accent blue on its colored bar. A color set in the editor still wins over all of it — a project that picked a dark text color for the formerly white card has to pick a lighter one
- (typhosj) Fixed four editor labels that named the wrong thing: the vibration duration is in milliseconds, not seconds; the round slider's "knob zoom at control" is a permanent factor on the knob size; the icon slider's "slider thickness" is the diameter of its arc, not its stroke; and the top app bar's "fallback value if not in user group" is simply the entry preselected until the first click. Only the labels changed, in all eleven languages — no option, value or behaviour moved
- (typhosj) Fixed the Theme Editor rewriting several hundred objects on the next save after the admin language was switched
- (typhosj) Updated Material Design Icons from 6.9.96 to 7.4.47: 671 new icons, 7447 in total. Twenty names were retired upstream and no longer render —
android-messages,book-variant-multiple,desktop-mac,desktop-mac-dashboard,discord,email-receive,email-receive-outline,email-send,email-send-outline,format-textdirection-l-to-r,format-textdirection-r-to-l,google-controller,google-controller-off,google-home,lecturn,tablet-android,text-to-speech,text-to-speech-off,timeline-helpandtimeline-help-outline. Pick a replacement from the icon picker where one of them was used - (typhosj) Updated the admin UI framework (
@iobroker/adapter-react-v58.3.2) and the two bundled webfont packages - (typhosj) Documented how a widget shows the value of a state inside its texts — an object id in curly braces in any text or HTML field, which is what makes a List show several values below each other instead of one Value widget per state. The object id of a list row only controls that row (reported in the forum)
0.4.0 (2026-08-25)
- (typhosj) Added automatic filling of the widget fields from the metadata of the datapoint you pick (issue #15): name, unit, min/max/step, decimals, the states, the icon and the room/function of the object reach the fields that carry them, in Value, Slider, Round Slider, Progress, Progress Circular, Switch, Checkbox, Button State, Button Toggle, Select, Autocomplete, Input, List, Icon List and Table. A value you typed is never overwritten, not even when it happens to equal the default, and a field you cleared stays empty — the new refill fields from the object button in the same section does it anyway and names beforehand what it would overwrite. A list row also gets its right-hand column as a binding to the state, the Select builds its menu entries from the states, the Table takes its columns from the JSON it reads, and the sliders pick up a WORKING datapoint sitting next to the level. A binding you set counts as your own value, because the binding dialog leaves no other trace; an icon the object only resolves inside its own adapter folder is dropped in favour of what its role says, so no widget shows a broken image; and a menu built from the states clears the entries above its new count, which the button names before it does it
- (typhosj) Fixed the "padding bottom" of the List and Icon List header having no effect in any setting: the header row had a fixed height, so the bottom padding hung below its content box and the header container clipped it away. The height is a minimum now and all four paddings take part - more padding at the bottom lifts the header text, which is what an alignment "bottom" would have done. Its default drops from 20 to 0, because those 20 px were never drawn
- (typhosj) Fixed the calendar month grid showing the view background through its day cells: the days and the weekday header were left transparent, so on a view with a dark background or a background image the grid looked empty and the day numbers were unreadable. Both now paint the widget's own surface, and the month view's weekday names follow the dark theme like the week and day views already did. An explicitly set day, header or label color still wins
- (typhosj) Fixed all four charts being thrown away and rebuilt on every incoming value: their data and options are built fresh on each render, and the chart canvas read that as a new chart. The entry animation restarted, an open tooltip closed and the canvas flickered whenever a datapoint changed. The existing chart is updated in place now, and only a changed chart type builds a new one
- (typhosj) Fixed the Line History chart's "refresh method" being able to add refreshes but never to restrict them: the live values of every data series counted towards the refresh no matter what was selected, so "time interval" queried the history adapter on every incoming value instead of on its interval, and "by object" never waited for its trigger datapoint at all. The values now count only under "realtime" and the trigger only under "by object"
- (typhosj) Fixed two widgets on the same view fighting over the theme colors: the theme's CSS variables were written page-wide, so whichever widget rendered last decided the colors for every other one. Visible as soon as two widgets resolved the dark setting differently — one of them dragged the whole view along. Each widget now carries its own set
- (typhosj) Fixed the adapter configuration freezing for tens of seconds when saving: the several hundred theme states were written one round trip after another. They go out in batches now, which matters most when the admin is open over a slow connection
- (typhosj) Fixed "generate global script" replacing an existing script without a word: the script object was overwritten whole, so anything edited in the script editor was gone, and writing it enabled restarts the JavaScript instance. It asks before doing either now and keeps the script's enabled state instead of switching it back on
- (typhosj) Hardened the sanitizer for HTML coming from a state against SVG animation elements:
<animate>,<set>and<animateTransform>rewrite another element's attribute while it is already on the page, so ajavascript:URL smuggled in through one of them never passed the URL check. They are dropped now, like the other active-content elements
0.3.5 (2026-08-20)
- (typhosj) Fixed the Bar Chart rendering nothing at all, and the Pie Chart tooltip and the Value widget throwing, when a decimals field was given a minimum above its maximum — which is what filling in "min decimals" and leaving "max decimals" empty adds up to. The maximum is lifted to the minimum now instead of breaking the widget
- (typhosj) Fixed HTML from a state being able to carry a
<style>block: its rules are page-wide, so one state value could hide a whole VIS view or lay an invisible layer over it, and the text inside such a block is re-parsed on the way back out, which turns an inert<img onerror>into a live one - (typhosj) Fixed every number option of the Calendar falling back to 0 instead of its declared default once the field was emptied in the editor: the day axis collapsed from 24 hours to one, rows dropped to the 12 px floor and the click sound went silent. The same three coercions are shared by all fourteen widgets that had drifting copies of them now
- (typhosj) Fixed the "min screen resolution" of the Alerts hiding every alerts widget on the page instead of the one it was set on, so two of them with different breakpoints hid each other
- (typhosj) Fixed the Alerts never announcing anything to a screen reader — the widget whose whole job is showing messages had no live region — and replaced the hard-coded English labels that input, select, table, top app bar, card, icon list and list read out
- (typhosj) Added the animation duration to the Line History Chart, the shared chart setting the other three offered while this one was stuck at 1000 ms, and gave its time axis the label font its own y axis already took. Added the eleven tooltip options to the JSON Chart that the other charts have offered all along
- (typhosj) Fixed the theme colour of the Icon widget reaching no widget at all: it was filed under "Material Design Icon", a name the widget does not use
- (typhosj) Fixed 37 attribute labels printing their raw key in the editor (
refreshOnWakeUp,state_oid,header_height,topAppBarZ_indexand the rest), across the HTML card, all four charts, both dialogs, the icon list, the list, the top app bar, the alerts, the autocomplete and the view-in-widget pair. The object-id section of the Button State Multi, Button State Multi vertical and Icon Button State Multi showedgroup.buttonOidsfor the same reason, as did the two view-in-widget group headers - (typhosj) Fixed the Icon List's "sub label font color selected" dark-mode colour being stored under the light-mode object id: the dark value overwrote the light one and the dark state was never created. Pick that one colour once more if you had set it
- (typhosj) Fixed the editor's use theme button writing into options that do not exist, where it silently did nothing: a Pie Chart carried x/y axis colours and fonts although a pie has no axes, the JSON Chart axis and value fonts it never draws, the linear Slider the round slider's background colour, the List a switch hover colour it does not offer, and the drawer header a text size it has no field for. The 53
AdapterStatusentries went with them — that was a VIS 1 JavaScript, never a widget of this adapter - (typhosj) Fixed
listTypeButtonNavstaying English in eight languages and naming the wrong widget in Chinese, andlistTypeButtonLinkspelling URL as "Url" everywhere - (typhosj) Fixed the third option of every alignment dropdown reading "rechts" in all eleven languages, including English, French and Spanish.
flex-starthad its own slips — Russian read "оставил" (left behind, the verb) and Chinese "剩下" (what remains) — andextraAttrandhtmlTextshowed their raw key names - (typhosj) Fixed the charts writing the Material Design blue into
Chart.defaults.global, a mutation that reached every chart.js instance on the page, this adapter's or not; each axis carries the colour itself now. The dark-theme state is re-subscribed when its object id is changed in the editor, instead of taking effect only after a page reload.vibrateOnMobilDevicesvibrates in the nine widgets whose editor showed a default of 50 while the code fell back to 0. The Calendar only runs its minute clock where the "now" line is actually drawn, instead of re-rendering every calendar every minute - (typhosj) Removed the editor sections that opened onto nothing: icon buttons carry no label, so their label group was empty, and the Installed Version's common group had lost its only field
- (typhosj) Changed the sliders to stop flooding the bus while dragging: every pointer move used to write a state, so one drag produced hundreds of writes and a Zigbee lamp ended up seconds behind the finger. The first move still goes out at once, the rest is limited to one write per 200 ms, and the release always writes the value the finger stopped on. The new send value on release goes further and writes nothing at all until the pointer comes up. Affects Slider, Round Slider and Icon Button Slider
- (typhosj) Fixed the last settings that did nothing: the chart card title size and the JSON chart's bar width; the Top App Bar drawer's vibration, hover colours and sub-list background; the List's scroll-to-top on change, selected-row colour and switch hover colour; the Input's hover background and its hint that waits for focus like Select's; the Progress strip distance; the Card's title-section background; the Alerts close-icon press colour; the Dialog's close-button size and its pressed colour, which now also works in the windowed dialog; and the Icon Button Slider's colorize and colorize factor
- (typhosj) Added a legend to the Bar Chart, which declared the whole legend group and drew none, and put Pie, JSON and Bar on one legend implementation — so the JSON chart's legend learned the point style the other two already had
- (typhosj) Added the change effect and "hidden on load" to the Value widget: the value flashes in its effect colour and size for the configured duration whenever it changes (not when the first state arrives, so a dashboard does not light up on load), and the widget can stay invisible until its state is there, holding its box so the layout does not jump
- (typhosj) Fixed the per-view min/max width of the Grid and Masonry views doing nothing: a view is hidden outside the widget width it names, and an empty bound means no bound on that side. Masonry's alignment reaches its columns as well now — it was the only alignment setting the widget has, and it was read under two field names Masonry never declared
- (typhosj) Moved input type from Select, which has no text entry for it to act on, to Autocomplete, where it reaches the filter input: date and time give the browser's own picker
- (typhosj) Added the sixteen Select and Autocomplete fields that were decoration: the hint text with its font, size and colour (shown only while the list is open unless "always show" is set), an entry counter, the hover and selected background and border colours, the label offset, and auto-focus (which stays off in the editor)
- (typhosj) Fixed the values group of the Bar, Pie and Line History charts being decoration: the datalabels plugin was loaded but never configured, so Bar and Pie drew the raw number in the plugin's own style and Line History drew nothing. Font, colour, box, placement, rotation and the "every n-th value" step all apply now. The Line History default moves to off — a history line carries hundreds of points and a label on each is a wall of text — while Bar and Pie keep theirs on
- (typhosj) Added the ten Bar Chart axis settings that the editor offered and nothing read: bar width, the automatic label skip, the x-axis label rotation, offset and grid-line offset, and on the value axis the step size, the minimum and maximum digits, the tick limit and the appended unit
- (typhosj) Fixed the chart padding doing nothing in all four charts and the tooltip box geometry doing nothing in Bar and Pie: arrow size, distance, corner radius, padding, title margin and the colour box reach chart.js now. The Bar tooltip applies its own decimals setting, both Bar and Pie append the configured tooltip text, and "disable hover effects", the hover colour and the hover border reach the chart
- (typhosj) Removed 63 editor settings that no widget read, so nobody has to wonder why they have no effect:
debug(declared for 45 widgets, read for one console line), the Bar Chart's bar label text, its tick source and its zero-line width and colour, the Top App Bar's backdrop item layout with its two background heights and its six colours, its permission selector with the disabled-entry fonts and colours, the Grid and Masonry resolution assistant, and the Select and Autocomplete ripple colour, which this port has no ripple for. Values already saved for them stay in the project and are simply ignored - (typhosj) Closed the nineteen npm audit advisories in the build's transitive dev dependencies (brace-expansion, serialize-javascript, diff, uuid, nanoid, js-yaml, undici, postcss, adm-zip and the vite 7 line). The adapter declares no runtime dependencies and ships only its built bundles, which came out byte-identical after the change
- (typhosj) Fixed the close-icon field of the Dialog being the last one on VIS 2's own icon picker, which loads its value as an image and answered the default
closewith a 404 in the editor. It uses the widget set's own icon and file picker now, like every other icon field - (typhosj) Fixed the Masonry Views collapsing its columns to thin lines: the alignment option carries text-align values and was written as
justify-items, which shrinks every grid column to the width of its content. It aligns the content of a column again and the columns fill the widget as before - (typhosj) Changed
vis2-materialdesign.0.colors.darkThemefrom a switch into a three-way setting:autofollows VIS 2's own theme,lightanddarkforce one. The widget set used to know only a boolean of its own that nothing in VIS 2 ever moved, so a light view could show dark widgets. Storedtrue/falsevalues and every script writing them keep working;autois the default for new installations - (typhosj) Fixed the header of the List and the Icon List being a card: it carried the card class, whose column layout put the header image above the heading instead of beside it and turned the header alignment into a vertical one, so left, center and right moved the header up, to the middle and down. Its rounded frame and shadow were drawn around the header too and VIS 2 cut them off at both sides (issue #14)
- (typhosj) Removed the List option "enable overflow": a row grows with its content in VIS 2, so there was nothing left for the option to release (issue #14)
- (typhosj) Fixed the List and Icon List drawing their rows one header height taller than the widget box: the list, the card and the card's text section each measured themselves against the whole widget, so with a header the lower rows ended up outside the widget and VIS 2 clipped them away. Header and content now share the box
- (typhosj) Fixed the alignment of the Icon List header doing nothing: the header row is a flex row, which ignores
text-align, socenterandflex-endstayed on the left (the List header got the same fix) - (typhosj) Fixed an appointment over midnight being drawn at its start time on every day it touches in the week and day view of the Calendar: a 23:00–01:00 appointment showed at 23:00 on both days. Each day now gets the part of the appointment that falls into it — the first day to midnight, the next one from midnight — and a day that only carries a part outside the configured time axis shows nothing
- (typhosj) Fixed the week and day view of the Calendar snapping every appointment to the interval lines: an appointment was pulled back to the line above it and stretched to full intervals, so 08:30 started on the 08:00 line and 15 minutes filled the hour. It is now placed and sized by the minute, like VIS 1; only an appointment without an end still gets one interval. Overlapping is measured in minutes too, so two appointments that merely share an hour no longer split the column
- (typhosj) Fixed the Top App Bar still swallowing clicks meant for the widgets below it. Its own box already passed them through, but VIS 2's frame around the widget stays a click target of its own and ate them as soon as the app bar was stacked above a view (view in widget, or a neighbour with a lower z-index). Only the bar, the drawer and its scrim take clicks now; in the editor the widget stays selectable
- (typhosj) Fixed the List divider styles
paddedandinsetand the layoutscardandcardOutlinedlooking exactly likestandard: all four only set class names whose geometry came from a stylesheet VIS 2 does not load. The dividers carry their insets again, and both card layouts their card geometry — inset far enough that VIS 2's clipping no longer eats the elevation shadow (issue #14) - (typhosj) Fixed the List fonts for the right and the second right text never reaching the text, and the row header font sharing its setting with the widget header, so one field restyled both. Row headers now have their own font (listItemHeaderFont) — a row header font that was set through the font group before has to be picked once more — and the left-hand font labels say which text they belong to. listBackground wrote a CSS variable no rule read and paints the widget again (issue #14)
- (typhosj) Added three layout options to the List: the header image can sit right of the heading with its own distance, the header alignment now moves the header (the flex row ignored
text-align), and the switch/checkbox can be placed after the right text with a configurable gap (issue #14) - (typhosj) Fixed the Calendar settings that existed in the editor but were never read: click sound and vibration now fire on the control buttons and the day numbers, the "selected / hover" colors of day numbers and control buttons are applied, and the control layouts
raisedandunelevatedrender as filled buttons,raisedwith its elevation (issue #13) - (typhosj) Fixed a day number of the Calendar opening the target view on the date the view was left on instead of the day that was clicked, and a month step from the 31st skipping a month (issue #13)
- (typhosj) Fixed overlapping appointments of the Calendar covering each other in the week and day view: the option overlap mode now does what it says —
columnsplits the width between them,stackoffsets them — and the day view shows the calendar week in the corner above the time axis like the week view (issue #13) - (typhosj) Added direct support for the ical adapter to the Calendar: a state like
ical.0.data.tablecan be used as it is. The widget reads the adapter's own field names (event,_date,_end,_allDay,_calColor) next to the documented start/end/name format, and converts its UTC timestamps to local time so an appointment no longer lands on the wrong hour or day (reported in the forum) - (typhosj) Added a line on the current time to the week and day view of the Calendar, moved on every minute. It can be switched off and colored in the time-axis group (reported in the forum)
- (typhosj) Added the calendar week to the week view of the Calendar, above the time axis, following the existing "show calendar week" option (reported in the forum)
- (typhosj) Fixed all-day and multi-day appointments of the Calendar covering one day too many: an all-day end is exclusive, and the ical adapter writes it as midnight of the following day, which the widget still counted as a day of its own. An end at midnight now ends the appointment on the previous day, whether it is written as a date or as a timestamp (reported in the forum)
- (typhosj) Fixed the month view of the Calendar dropping the start time of an appointment that has one; it shows the time in front of the name again, like VIS 1 (reported in the forum)
- (typhosj) Fixed the Calendar option font color for past days doing nothing: past days are dimmed with it again, in the month grid and in the day header of the week and day view (reported in the forum)
0.3.4 (2026-08-16)
- (typhosj) Fixed the Min/Max limit of the Addition buttons: a single bound was always read as the minimum, so a maximum like
50lifted the state up to 50 on the first press and then counted on without any limit. A single bound is now the end the step runs into — a step up stops at a maximum, a step down at a minimum — while0;100keeps bounding both ends. An empty field, and an empty half in50;, also stopped acting as a bound of 0, so a button without a limit can count into negative values again (issue #12) - (typhosj) Fixed every active option of the Navigation buttons doing nothing: the variant reads no object, so "active" was always false and label true, active label color, active background, active image and active image color never showed. Active now means the target view is the one on screen, which is what highlights the current page in a navigation bar (issue #11)
- (typhosj) Fixed the button styles
raisedandunelevatedlooking identical: no shadow was drawn at all, and the shadow is the whole difference between them.raisednow carries the Material elevation and gives up 4 px of its box for it, because VIS 2 clips a widget at its edge — the opening button of the Dialog widgets got the same room, its shadow was drawn but clipped away (issue #11) - (typhosj) Fixed the chart area background, the card's section background and every tooltip option except "show tooltip" being editor fields the four chart widgets never read: mode, position, colors and fonts now reach chart.js, the Line History tooltip formats its value with the configured decimals and unit, and its points take the line color instead of the translucent fill (issue #10)
- (typhosj) Fixed the fade of the Advanced View widgets never running — the jQuery easing name went straight into CSS and the views were switched through
display, which cannot animate — and made thepersistent,notIfInvisibleanddebugoptions of the8variant do what they say. The droppedslowConnectionoption only delayed a VIS 1 network path that VIS 2 does not have (issue #9) - (typhosj) Fixed multi-color SVG icons being flattened to one blue in the Icon List and List widgets: the default item color was applied before the "did the user pick a color?" check, so every SVG was masked. An SVG keeps its own colors now unless a color is chosen explicitly (issue #8)
- (typhosj) Fixed the push button writing its off value on a release the button never saw the press for: a view loading under the pointer, a widget taking focus while a key is down, or a hover followed by a mouse-leave wrote the state with nobody touching the button
- (typhosj) Fixed the Theme Editor's config dialog closing before the runtime state sync finished, which could leave the object tree half migrated; the dialog now waits for the sync to complete before closing, and shows a toast when it finishes without closing
- (typhosj) Fixed the Top App Bar swallowing every click in the empty part of its widget box: the box has to be as tall as the drawer it opens, and the transparent area below the bar blocked the widgets underneath. Only the bar, the drawer and its scrim take clicks now
- (typhosj) Fixed the drawer of the Top App Bar and the Dialog overlay staying behind other widgets whose CSS-general z-index was set: their own z-index option could only sort them inside the widget itself. Both now lift the widget while the drawer or the dialog is open
- (typhosj) Fixed the button style of the Dialog and Dialog iFrame widgets doing nothing: the opening button was always drawn filled, so
text,outlinedandiconlooked exactly likeraised. The flat styles now drop the fill and carry the primary color in border and label,raisedgets its shadow back, andiconis round (issue #6) - (typhosj) Fixed the
textandoutlinedstyles of the button widgets painting their label in the on-primary color (white by default) on a transparent background, which left it invisible; label and border now use the button color - (typhosj) Fixed every repeating editor group not letting a single entry be added: VIS 2 puts the add, clone and delete buttons on the last of these groups, and all of them hid exactly that one — while typing a number into the matching count field does not rebuild the groups either. That group now shows as an add bar carrying only the buttons and a line naming it, so the count keeps meaning the number of entries. Affected the menu entries of Select, Autocomplete and Top App Bar, the data sets of all four charts, the columns of the Table, the views of Advanced View, Advanced View in Widget and Responsive Layout, and the object list of the multi-state buttons (issue #7)
- (typhosj) Fixed the + button of the List and Icon List rows adding a row the runtime never drew: the button counted up a second, hidden index while the widget kept reading "count of list items". Both now use one number, and the hidden index is gone (rows added past the count through that button have to be added once more)
- (typhosj) Fixed the Select and Autocomplete widgets dropping every menu entry that was given a label but no value — which is what the editor stores for a freshly added entry. Such an entry now uses its label as the value written to the object (issue #7)
- (typhosj) Fixed the Select and Autocomplete data method "states of the object" never showing a single entry: the widget read the states from an object cache that VIS 2 does not hand to widgets, so it always saw nothing (issue #7)
- (typhosj) Changed every count option to mean what it says: 3 now gives three entries. VIS 1 stored the last index there, so 3 produced four — this affects the data sets of the Bar, Pie and Line History charts, the menu entries of the Top App Bar, the table columns, the select and autocomplete values, the object ids of the multi-state buttons, and the views of Advanced View in Widget and of the responsive layouts. Check the value once when you rebuild such a widget from a VIS 1 project, otherwise its last entry disappears
- (typhosj) Fixed the Select and Autocomplete widgets offering only the first list entry in the editor: the item group carried the fields of entry 0 instead of repeating per entry, so a "number of select values" above 1 had nowhere to be filled in
- (typhosj) Fixed the per-data-set options of the Bar, Pie and Line History charts being editable only for the first data set: bar color, label, value text, tooltip text — and the per-series line and y-axis settings of the Line History chart — appeared once instead of once per data set, so a chart with several data sets could not be styled per series like in VIS 1. Each data set now has one group holding its object id and all of its options; existing charts keep every saved value (reported in the forum)
- (typhosj) Fixed the icon picker showing only the first 400 of the 6809 icons with no way to reach the rest — the grid ends there and neither scrolling nor paging went further, so an icon whose name you did not know was unreachable. The grid now keeps loading while you scroll (issue #4)
- (typhosj) Documented how the Top App Bar switches views — it writes the selected menu index into its object id, and an Advanced View in Widget 8 with the same object id shows the matching view (reported in the forum)
0.3.3 (2026-07-24)
- (typhosj) Fixed the Theme Editor's runtime state sync: it never created the intermediate channel objects for nested color/font states, used the "value" role (number-only) for string values, and could leave font-size states with a stale string/number type mismatch
- (typhosj) Removed the "mocha" devDependency; it is already provided by
@iobroker/testing
Copyright (c) 2026 typhosj typhosj@gmx.de
Copyright (c) 2021 Scrounger scrounger@gmx.net
The widgets are based on the original VIS Material Design widget work by Scrounger scrounger@gmx.net.
