vis-material-webfont adapter for ioBroker
Material Design Icons by (https://materialdesignicons.com/)
Usage
Add basic-HTML and use General -> CSS class. (https://dev.materialdesignicons.com/getting-started/webfont)
Basic
Each icon can be referenced by their name prefixed with mdi-. For instance to get the home icon mdi-home.
Example: mdi mdi-home
Rotate
mdi-rotate-45 - Rotates 45 Degrees.
mdi-rotate-90 - Rotates 90 Degrees.
mdi-rotate-135 - Rotates 135 Degrees.
mdi-rotate-180 - Rotates 180 Degrees.
mdi-rotate-225 - Rotates 225 Degrees.
mdi-rotate-270 - Rotates 270 Degrees.
mdi-rotate-315 - Rotates 315 Degrees.
Example: mdi mdi-account mdi-rotate-45
Flip
mdi-flip-h - Flip horizontal.
mdi-flip-v - Flip vertical.
Example: mdi mdi-account mdi-flip-h Note: mdi-flip-* and mdi-rotate-* classes cannot be used on the same element at the same time.
Spin
mdi-spin - Spinning icon.
Example: mdi mdi-loading mdi-spin
More
To see more (/widgets/material-webfont/css/materialdesignicons.css)
0.0.3
- (om2804) fixes
0.0.1
- (om2804) initial release
Apache 2.0 and SIL Open Font License 1.1
Copyright (c) 2019 om2804 om2804@mail.ru
Copyright (c) 2014, Austin Andrews (http://materialdesignicons.com/), with Reserved Font Name Material Design Icons.
Copyright (c) 2014, Google (http://www.google.com/design/) uses the license at https://github.com/google/material-design-icons/blob/master/LICENSE
