material widgets
material Widgets for ioBroker.vis
Current Release
0.2.0
nisiode, iobroker-community-adapters
material - Material widgets for ioBroker.vis.
You can read instructions in material.js, material.html files
These widgets are in addition to the material design style of Uhula, which you can find here: https://github.com/Uhula/ioBroker-Material-Design-Style
The adapter uses CSS to set a black background and white as the font color. This means that it is only suitable for dark vis layouts.
In some installations, the font in the context menu may no longer be readable. This is probably caused by cross-effects from other adapters. To analyze these, please read the following post. https://forum.iobroker.net/topic/79188/vis-anzeigen-zerst%C3%B6rt/27
Example
0.2.0 (2025-01-12)
  • (oweitman) Some adapter settings have been fixed.
  • (oweitman) Some adaption for a new release have been applied.
  • (mcm1957) Dependencies have been updated.
  • (pix) feat: new window shutter widget
  • (pix) feat: new humidity widget added
0.1.3 (2018-01-21)
  • (nisio) feat: new dimmer widget
0.1.2 (2018-01-20)
  • (nisio) feat: switch added to light widget
0.1.1 (2018-01-14)
  • (nisio) feat: temperature and light widget
0.1.0 (2018-01-13)
  • (nisio) Initial version for public testing (includes css from material design styles V1.8)
0.0.1 (2018-01-01)
  • (nisio) Initial version for internal testing
The MIT License (MIT)
Copyright (c) 2025-2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2015-2024 nisiode nisio.air@gmail.com
