Widgets for the ioBroker.vis Adapter
Switches, sliders, tables, controls, checkboxes, radio buttons and more...
With our widget set you have the freedom to easily create individual visualizations for your smart home.
Important Note for Vis 2
This adapter was developed and tested for VIS 1. Errors may occur in Vis 2 that prevent the use of your visualization. Seamless compatibility will not be possible. A new adapter for Vis 2 can be found here: https://github.com/inventwo/ioBroker.vis-2-widgets-inventwo
Starting with version 4.1.x, the widgets are explicitly excluded from the Vis 2 editor and the adapter will no longer work in Vis 2 at all. If you want to continue using this adapter in Vis 2, you must stay on a version prior to 4.1.x.
Contents of the Adapter
Various widgets for switching, navigating and more.
Analog Clocks More Information
Digital Clocks More Information
Colorpicker More Information
For more information, check out the Wiki.
All Widgets from Version 2.0.0
Universal![]() |
Multi![]() |
Image![]() |
Table![]() |
List![]() |
Marquee![]() |
Radio Button![]() |
Slider vertical ![]() |
| Slider horizontal ![]() |
Colorslider horizontal ![]() |
Colorslider vertical ![]() |
Toggle Switch![]() |
Basic Switch![]() |
Checkbox/ Radiobutton ![]() |
Colorpicker![]() |
The following projects can be realized with the help of our widgets. Currently our adapter contains ONLY the pure buttons (see above). Clock and weather come from other adapters and may need to be installed additionally.
Support
If you like our work and would like to support us, we appreciate every donation.
(This link leads to our PayPal account and is not affiliated with ioBroker)
4.1.1 (2026-06-04)
- correct z-index layering for popups — date/time picker dropdowns now appear in front of the popup overlay instead of behind it (#583)
4.1.0 (2026-05-17)
- Hide widgets in vis 2 editor
4.0.1 (2026-05-15)
- Fixed widget gif images missing
4.0.0 (2026-05-15)
- (iobroker-bot) Adapter requires node.js >= 20 now.
- Updated dependencies
- Updated project structure to meet latest ioBroker standards
- Updated build process to use latest tools and best practices
3.3.5
- Fixed: #688 Radio button cannot write a boolean value
- Fixed: #736 Adapter checker errors in package.json and io-package.json resolved
- Fixed: #678 Mode in io-package changed from daemon to once
Older changes
Can be found in CHANGELOG_OLD.md
Icons from Icons8 https://icons8.com/
