HomeKit-Tiles
VIS widgets in HomeKit style
Current Release
0.4.8
Standarduser
HomeKit-Tiles for ioBroker-VIS
Homekit Tiles is a widget set based on the design of Apple HomeKit. The special feature of the widgets is that they do not contain any fixed style elements, but everything is formatted using CSS. As a result, there are no separate settings in the VIS editor for the position and/or size of the icons, labels, etc. The design is adjusted by changing the CSS code. For this purpose, the CSS code from the file /widgets/homekittiles/css/style.css can be used as a template. The code is inserted into the CSS tab in the VIS editor and can be customized as desired. It is also possible to add your own CSS classes via the VIS editor in the "General" section of the widgets.
The widgets are designed for VIS 1.x.
Note: For licensing reasons, no icons are included with this adapter. Very good sources for icons are:
🇩🇪 Dokumentation 🇺🇸 Documentation
Things to do
  • create Mini-mediaplayer
  • create Select-tile
  • create Checkbox for Sonos Group
  • Datepicker: dynamic day/month icons
  • Tiles: add button for dialog
  • optimize function 'infoText'
0.4.8 (2026-01-02)
  • Fixed issues from adapter checker
0.4.7 (2025-12-29)
  • Depencies updated
0.4.6 (2025-03-04)
  • Depencies updated
0.4.5 (2025-02-14)
  • hkt-Button-Set-Navigation-Submenu: added (optional) strokes to use with main menu widget
0.4.2 (2025-02-09)
  • hkt-settings-value: added format options for decimals
  • Thermostat dialog: prevent select menu inside of dialogs from open when dialog window opens
  • View in widget dialog: prevent select menu inside of dialogs from open when dialog window opens
0.4.1 (2025-02-08)
  • All tiles: added icon for state off
  • Optimized CSS for indicator
  • Removed forced font-size of widgets in View-In-Widget-Swipe
  • Removed forced font-size of widgets in View-In-Widget-Dialog
0.4.0 (2025-01-14)
  • Added Pinpad-Dialog
  • Added HTML-Dialog
  • Added hkt-Config-Modal (experimental): changes the styles of modal to blur instead of background color and transparency (modal darkens the background when a dialog window is open). For this config-item you need ipadOS 18.x to work with Safari or ioBroker Visu App. Simply place the config item somewhere in your VIS where it is always called (e.g. in the menu) and configure it as desired. It is not visible at runtime.
  • Made "modal" to default setting
  • Section 'dialog' splitted into 'dialog settings' and 'dialog content'
  • Made values of SwitchBool customizable and renamed 'SwitchBool' to 'Switch'
  • Repaired notification widget
  • Added Apple standard font 'SanFrancisco' to fonts (needed to be installed separatly)
0.3.3 (2025-01-03)
  • Added new style "text only" to switch and view-in-widget-dialog tiles
  • Fixed some issues from adapter checker
  • Fixed some styles of view-in-widget-swipe
  • Added arrow indicators to view-in-widget-swipe
0.3.2 (2024-12-03)
  • Added option to show icons colored on tiles and radio
  • Added new styles "big", "small" and "only icon" for all tiles
  • JSON Table: set no fixed height (min-hight is now 32px)
0.3.1 (2024-07-12)
  • Added submenu widget
0.2.7 (2024-07-10)
  • repaired Thermostat dialog tile widget
0.2.6 (2024-07-05)
  • Block operation: added ability to show widget disabled
  • Added JSON Table
  • Navigation-Button-Set: fixed notification arrangement
  • Dynamization of some input fields
0.1.1 (2024-07-02)
  • Added missing translations
  • Added new style "indicator" for all tiles (IF YOUR TILES LOOK BROKEN AFTER UPDATE: SELECT EVERY TILE IN EDITOR - JUST CLICK ON IT. Sorry for that.)
  • Radiobutton: new property "division" with selectable values
  • Radiobutton: change size automatically if direction was changed
  • Signal pictures: repaired comparision with number (<=nn)
  • Signal pictures: checkbox for show/not show in editor
  • Thermostat dialog: sort order of attributes (dialog attrs one up)
0.0.16 (2024-06-08)
  • (Standarduser) thermostat: fixed window-sizing
  • (Standarduser) date-picker: fixed block operation
0.0.15 (2024-05-31)
  • (Standarduser) dialog: fixed positioning
  • (Standarduser) thermostat: corrected symbols
  • (Standarduser) thermostat: show low bat and unreach on tile
  • (Standarduser) thermostat: added signal pictures
0.0.14 (2024-05-15)
  • (Standarduser) settings-bool: corrected height of widget
  • (Standarduser) thermostat: autofill + text templates + select for setpoint mode and heating profile
0.0.13 (2024-05-05)
  • (Standarduser) made colors of datepicker window nice
  • (Standarduser) removed test divs from hkt-ViewInWidget-Dialog
  • (Standarduser) added thermostat widget
0.0.12 (2024-05-03)
  • (Standarduser) added preview for label-widget
  • (Standarduser) added notification bubbles for navigation button-set
  • (Standarduser) removed navigation button (use navigation button-set instead)
  • (Standarduser) added Settings-Widget with select value list
0.0.11 (2024-04-30)
  • (Standarduser) added own signal pictures for all tiles widgets
  • (Standarduser) Radiobutton: allow HTML in button label
  • (Standarduser) Radiobutton: some css corrections
  • (Standarduser) added Text field (label) with predefined css-classes
0.0.10 (2024-04-26)
  • (Standarduser) added Object ID for Active State for View in Widget Dialog tile and Value tile
  • (Standarduser) repaired Increment function
0.0.9 (2024-02-02)
  • (Standarduser) corrected block operation. ATTENTION! You may have to delete and reinsert your widgets, if you used a different Object ID for blocking operation! Of cause only these widgets, where you used this function ;)
  • (Standarduser) corrected formatValue function
0.0.7 (2023-12-26)
  • (Standarduser) CSS adjustments
  • (Standarduser) changed block operation to old variant
  • (Standarduser) corrected value formatting in label groups
0.0.6 (2023-11-10)
  • (Standarduser) just some cleanup
0.0.5 (2023-11-04)
  • (Standarduser) fixed: adjustment of decimals in labelgroup 1 & 2
  • (Standarduser) fixed: readme
  • (Standarduser) not fixed: increment not working properbly
0.0.4 (2023-11-01)
  • (Standarduser) fixed: some corrections on CSS code
  • (Standarduser) fixed: widget description text
  • (Standarduser) fixed: wrong placement if dialog-height had a unit (ViewInWidget-Dialog)
  • (Standarduser) fixed: increment buttons on tiles were working insuficient
  • (Standarduser) added: variable number of digits at value-tile
  • (Standarduser) added: slider for ViewInWidget-Swipe
  • (Standarduser) added: ability to manipulate values in label-groups
0.0.2 (2023-10-14)
  • (Standarduser) initial release
Copyright (c) 2025-2026 Standarduser
