Technic widgets for ioBroker VIS 2 with a consistent dark teal design language for smart home visualization.
Widgets
Window - Wall – Window and roller blind control with SVG visualization, Auto/Manual mode toggle, position slider, context menu and quick-set buttons (0 / 25 / 50 / 75 / 100%).
Switch - Boolean – On/off switch with selectable SVG icons and configurable on/off colors.
Dimmer - Light – 270° arc dimmer with draggable knob, dynamic lamp ray animation, power toggle and brightness percentage display.
Requirements
- ioBroker js-controller >= 6.0.11
- ioBroker VIS 2 >= 2.0.0
- Node.js >= 20
Installation
Install via the ioBroker Admin interface by searching for "vis-2-widgets-technic" in the adapter list.
After installation do a hard refresh in your browser (Ctrl+Shift+R).
Design
All widgets use a consistent color palette:
- Teal
#2ecfbf– Active / ON state - Secondary
#5f8f8a– Inactive / OFF state - Background
#0d1820– Widget background - Text
#c8e6e3– Labels and text
0.1.20 (2026-06-28)
- fix: complete translations for all news entries
0.1.19 (2026-06-28)
- fix: remove duplicate English news translations flagged by repochecker
0.1.18 (2026-06-27)
- Remove postinstall script, fix i18n translations (component mode), remove demo widget and template keys
0.1.17 (2026-06-27)
- Release 0.1.17
0.1.16 (2026-06-26)
- Translate all widget names and labels to English, fix window blind open/close logic, add quick-set buttons (0/25/50/75/100%)
0.1.15 (2026-06-21)
- Release 0.1.15
0.1.14 (2026-06-21)
- Release 0.1.14
0.1.13 (2026-06-19)
- fix: workflow permissions and provenance flag
0.1.12 (2026-06-19)
- fix: enable npm provenance via GitHub Actions, remove debug script
0.1.11 (2026-06-19)
- fix: remove process.env/exit for compact mode compliance
0.1.10 (2026-06-19)
- fix: correct web restart command chaining in install.js
0.1.9 (2026-06-19)
- fix: call iobroker.js directly to bypass broken wrapper recursion
0.1.8 (2026-06-19)
- fix: capture real stderr in install.js for debugging
0.1.7 (2026-06-19)
- fix: persistent logging in install.js for debugging
0.1.6 (2026-06-19)
0.1.5 (2026-06-19)
- fix: robust install.js with retry and file verification for fresh installs
0.1.4 (2026-06-18)
- Initial npm release
0.1.3 (2026-06-18)
- Added BeleuchtungDimmer widget
0.1.2 (2026-05-01)
- AnAusSchalter widget with SVG icons and freely configurable colors
0.1.1 (2026-04-01)
- FensterNormal widget with SVG transparency and context menu
0.1.0 (2026-03-01)
- Initial release
MIT License Copyright (c) 2026 iobroker-community-adapters
See LICENSE for full text.
