Tesla
Adapter for Tesla
Current Release
3.2.2
TA2k, iobroker-community-adapters
Tesla adapter for ioBroker
All Tesla vehicles and Powerwalls from the Tesla App are displayed and updated via the official Tesla Fleet API.
Vehicle commands (lock, unlock, climate, charging, etc.) are supported for all models including post-2021 vehicles that require end-to-end command signing (Vehicle Command Protocol).
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and for information on how to disable the error reporting, see Sentry-Plugin Documentation! Sentry reporting is used starting with js-controller 3.0.
Requirements
  • Tesla account with vehicles or energy products
  • Node.js >= 22
  • A registered Tesla Fleet API application (Client ID + Client Secret) from developer.tesla.com
  • A Fleet Key domain (for virtual key installation on the vehicle)
Setup (Step by Step)
The adapter admin UI guides you through 4 steps:
Step 1: Generate Key Pair
  1. Click Generate Key Pair in the adapter settings to create an EC key pair (prime256v1)
  2. Click Copy Public Key and go to fleetkey.net - paste it under "Host Public Key" and create a subdomain (e.g. abc123.fleetkey.net)
  3. After saving, FleetKey.net hosts your Public Key. Tesla will download the key from there during registration.
Step 2: Tesla Developer App
  1. Create a Fleet API Application at developer.tesla.com
  2. Set Origin to your full FleetKey subdomain (e.g. https://abc123.fleetkey.net)
  3. Set Redirect URL to https://auth.tesla.com/void/callback
  4. Copy Client ID and Client Secret from the created app and enter them below together with your FleetKey domain (e.g. abc123.fleetkey.net)
Step 3: Authentication (OAuth2)
  1. Click Generate Auth Link - a new browser tab opens with the Tesla login page
  2. Log in with your Tesla account and authorize the app
  3. After login you will see "Page Not Found" - this is expected! Copy the complete URL from the browser address bar
  4. Paste the URL into the code URL field and click Save and close
Warning: Never share this URL with anyone! It grants access to your Tesla account.
Re-authorize after changing Tesla scopes
If you add or change scopes in the Tesla Developer App later, the existing refresh token will not automatically receive these permissions. Reset the stored Fleet session first, then run the OAuth flow again:
  1. Enable Reset Login/Token Information in the adapter settings.
  2. Save and close the settings once. The adapter deletes the stored Fleet session and Code URL and restarts.
  3. Open the settings again, generate a new Auth Link and authorize Tesla with the required scopes.
  4. Paste the new callback URL into Code URL and save again.
A new callback URL without resetting the stored session is ignored while the old session can still be refreshed.
Step 4: Install Virtual Key
The Virtual Key is required to send commands to your vehicle (lock/unlock, climate, charging, etc.). Without it, you can only read vehicle data. You can do this step after the adapter is running.
  1. Open the Virtual Key URL shown in the adapter settings on your phone (or scan the QR code)
  2. The Tesla App will ask you to confirm adding a "third-party key"
  3. Go to your vehicle and hold your key card to the center console to confirm the installation
Remote Commands
Remote commands are available under tesla-motors.0.<VIN>.remote.
Supported commands include:
  • Lock/Unlock: door_lock, door_unlock
  • Climate: auto_conditioning_start, auto_conditioning_stop, set_temps, set_preconditioning_max, remote_seat_heater_request, remote_auto_seat_climate_request, remote_steering_wheel_heater_request
  • Charging: charge_start, charge_stop, set_charge_limit, set_charging_amps, charge_port_door_open, charge_port_door_close, set_scheduled_charging
  • Trunk: actuate_trunk (front/rear)
  • Windows: window_control (vent/close)
  • Security: set_sentry_mode, remote_start_drive
  • Media: media_toggle_playback, media_next_track, media_prev_track
  • Other: flash_lights, honk_horn, trigger_homelink, schedule_software_update
Climate-dependent seat and steering-wheel commands, including remote_auto_seat_climate_request, require active preconditioning or Climate Keeper. Start climate first with auto_conditioning_start (or enable Climate Keeper) before sending these commands. If climate is off, Tesla rejects the command with cabin comfort remote settings not enabled.
Field Description
  • df: driver front
  • dr: driver rear
  • pf: passenger front
  • pr: passenger rear
  • ft: front trunk
  • rt: rear trunk
Technical Details
  • Fleet API: Regional endpoints (EU/NA/CN) with automatic region detection from JWT token
  • Command Signing: ECDSA P-256 + HMAC-SHA256 via protobuf (Vehicle Command Protocol)
  • Two Domains: DOMAIN_INFOTAINMENT (climate, charging, media) and DOMAIN_VEHICLE_SECURITY (lock, unlock, trunk)
  • Session Management: ECDH handshake per domain, epoch + counter based, stored in ioBroker state
  • Token Refresh: Automatic refresh before expiry
Admin UI and migration notes
The adapter settings use ioBroker's jsonConfig admin UI. Existing adapter instances keep their saved configuration, but the settings page was reorganized to make the Fleet API setup, Fleet Telemetry bridge and field selection easier to maintain.
When updating from an older 2.x version, please open the adapter settings once and verify the Fleet API credentials, virtual key domain and optional Fleet Telemetry settings before starting a new Fleet Telemetry configuration.
Optional Fleet Telemetry mode (MQTT bridge)
Starting with the Fleet API migration, the adapter can also be used together with Tesla's Fleet Telemetry service to reduce vehicle_data polling costs. Fleet Telemetry is optional. If it is disabled, the adapter keeps the existing polling behavior unchanged.
The first implementation uses an MQTT bridge and deliberately keeps the Fleet Telemetry receiver outside of the adapter:
  1. Tesla vehicles stream telemetry to a self-hosted fleet-telemetry server.
  2. The server publishes selected vehicle fields to MQTT.
  3. The adapter subscribes to the MQTT topics and writes the data back into the existing Tesla state tree.
This keeps current scripts and aliases working while reducing regular vehicle_data requests.
For a practical, beginner-friendly setup walkthrough with Docker Compose, certificates, TCP passthrough, adapter settings and troubleshooting, see docs/fleet-telemetry-setup.md.
Requirements
  • A reachable Tesla Fleet Telemetry server with transmit_decoded_records=true.
  • An MQTT broker that is reachable by the ioBroker host.
  • A local vehicle-command proxy for Fleet Telemetry configuration calls.
  • A server certificate / CA chain for the public Fleet Telemetry endpoint.
  • A vehicle with Fleet Telemetry support and a paired virtual key.
The Fleet Telemetry server must be reachable by the vehicle on the configured public host and port. In many installations this requires TCP passthrough instead of a normal HTTPS reverse proxy because Tesla connects directly to the Fleet Telemetry server.
Additional adapter settings are available for:
  • enabling telemetry mode
  • the local vehicle-command proxy URL used to configure telemetry on the car
  • the telemetry server hostname / port / certificate chain
  • MQTT broker, topic base and credentials
  • the Fleet Telemetry field selection and per-field interval_seconds / optional minimum_delta
  • an optional periodic Fleet API sync for data that is not covered by telemetry
Adapter setup
  1. Run and expose the Fleet Telemetry server.
  2. Configure its MQTT datastore to publish decoded records to your MQTT broker.
  3. Run the vehicle-command proxy in the same trusted network as ioBroker.
  4. Configure the adapter settings:
    • enable Fleet Telemetry mode
    • enter the vehicle-command proxy URL
    • enter the public Fleet Telemetry hostname, port and CA/fullchain PEM
    • enter MQTT broker, optional credentials and topic base
  5. Select the desired fields, intervals and optional minimum deltas on the Fleet Telemetry fields tab.
  6. Use the admin action Check Fleet Status first.
  7. Use Configure Fleet Telemetry to send the configuration to the vehicle.
  8. Use Read Fleet Config to verify that the vehicle reports the configuration as synced.
The admin actions surface common error reasons such as missing virtual keys, unsupported firmware, disabled streaming or reached Fleet Telemetry config limits.
MQTT topic format
The adapter subscribes to the MQTT topic base configured in the admin UI. With the default topic base tesla-telemetry, the expected topics are:
  • tesla-telemetry/<VIN>/v/<FieldName> for telemetry values
  • tesla-telemetry/<VIN>/connectivity for connectivity events
  • tesla-telemetry/<VIN>/errors/<Type> for telemetry errors
  • tesla-telemetry/<VIN>/alerts/<Type>/current for current alerts
The admin UI contains a dedicated Fleet Telemetry fields tab. The Tesla field catalogue is split into collapsible category groups so the admin page only has to render/open smaller sections at a time. There you can enable/disable individual Tesla telemetry fields and set the update interval in seconds per field. Optional minimum_delta values can be configured for numeric fields where Tesla supports them. If the field is left empty and the admin UI shows a placeholder, the adapter uses that default when building the vehicle configuration. For Location, OriginLocation and DestinationLocation, Tesla interprets minimum_delta in meters, so the default 100 m roughly matches 0.001° latitude/longitude and avoids tiny GPS jitter updates. Other useful defaults are provided for common percentage, range, speed, temperature, current, voltage, power and energy fields. Fields that are already mapped by the adapter are written back into the existing Tesla state tree. Other selected fields are stored as raw values under <VIN>.telemetry.fields.<FieldName> so scripts can still use them.
Mapped fields currently include the most commonly used charging, battery, position and lock states:
  • Soc -> charge_state.battery_level
  • ChargeState -> charge_state.telemetry_charge_state
  • DetailedChargeState -> charge_state.charging_state and charge_state.detailed_charge_state
  • ChargeLimitSoc -> charge_state.charge_limit_soc
  • ChargeAmps -> charge_state.charge_amps and charge_state.charger_actual_current
  • ChargeCurrentRequest -> charge_state.charge_current_request
  • ChargeCurrentRequestMax -> charge_state.charge_current_request_max
  • ChargingCableType -> charge_state.conn_charge_cable
  • ChargePortDoorOpen -> charge_state.charge_port_door_open
  • EstBatteryRange -> charge_state.est_battery_range
  • VehicleSpeed -> drive_state.speed
  • Gear -> drive_state.shift_state
  • Location -> drive_state.latitude and drive_state.longitude
  • Locked -> vehicle_state.locked
  • Odometer -> vehicle_state.odometer
  • VehicleName -> vehicle_state.vehicle_name
Internally, the selection is stored as JSON for backwards compatibility with older admin versions. Manual JSON values may be plain seconds or full Tesla field options:
  "Soc": { "interval_seconds": 1, "minimum_delta": 1 },
  "ChargeState": 1,
  "DetailedChargeState": 1,
  "ChargeAmps": 1,
  "Location": { "interval_seconds": 10, "minimum_delta": 100 },
  "Locked": 1
Fleet Telemetry is change-based: a field is only emitted after its interval_seconds elapsed and the value changed. Where configured, minimum_delta additionally suppresses smaller numeric value changes before they are sent. The default preset therefore uses Soc with interval_seconds=1 and minimum_delta=1, so battery level updates are reported quickly but only after at least one percentage point changed. Setting a field to false omits it from the vehicle configuration.
When telemetry mode is enabled, Fleet Telemetry is used as the primary live source. The optional periodic Fleet API sync still polls the normal vehicle_data endpoints in the configured normal update interval so states that are not covered by the selected telemetry fields continue to be refreshed. Set the normal update interval to 0 to disable this scheduled Fleet API sync entirely. The comma-separated exclude list also applies to periodic API sync polling and can contain vehicle_data endpoints such as charge_state, climate_state, drive_state, vehicle_state, vehicle_config, location_data and dedicated endpoints such as charge_history.
Diagnostic states are available under tesla-motors.0.info.*:
  • telemetryConnected
  • telemetryConfigured
  • telemetrySynced
  • telemetryLastMessage
  • telemetryLastError
  • telemetryLastApiSync
  • telemetryLastVehicleDataSync
  • telemetryLastChargeHistorySync
Questions and Discussions
https://forum.iobroker.net/topic/47203/test-tesla-motors-v1-0-0
3.2.2 (2026-07-27)
  • (TA2k) fix QR Code generation
3.2.1 (2026-06-05)
  • (ChrMaass) Update the release tooling dependency to satisfy the ioBroker repository checker.
3.2.0 (2026-06-01)
  • (ChrMaass) Reduce routine Fleet API polling log noise by moving frequent vehicle state and vehicle_data messages to debug while keeping anomalies as warnings.
3.1.1 (2026-06-01)
  • (ChrMaass) Clarify Tesla OAuth re-authorization after scope changes and log missing-scope errors with a reset hint.
3.1.0 (2026-05-31)
  • (ChrMaass) Support the normal Fleet command endpoint for vehicles that do not support or do not require the Tesla Vehicle Command Protocol.
3.0.1 (2026-05-31)
  • (ChrMaass) Fix the Sentry README notice to match the repository checker standard wording.
Copyright (c) 2026 iobroker-community-adapters iobroker-community-adapters@gmx.de
Copyright (c) 2021-2025 iobroker-community
