signal-cmb
Send messages from ioBroker to your Signal messenger
Current Release
0.3.0
derAlff
signal-cmb adapter for ioBroker
Big thanks to free CallMeBot service, this adapter allows you to send Signal messages to yourself or other number.
Note : The Free API is only for personal use!
Configuration
Following documentation was copied from callmebot page.
You need to get the API key form the bot before using the API:
  • Add the phone number of the CallMeBot into your Phone Contacts (Name it it as you wish). You can find the actual phone number here: https://www.callmebot.com/blog/free-api-signal-send-messages/
  • Send this message I allow callmebot to send me messages (in english) to the new contact created (using Signal of course).
    If you receive an GUID inside the "test-link", you can use this GUID instead of your phonenumber inside the adapter. You can also send
    the message I allow callmebot to send me messages aigain. Normally you should see your phonenumber inside the link now and you can use your phonenumber inside the adapter.
  • Wait until you receive the message API Activated for your phone number. Your APIKEY is 123123 from the bot. As this is still in beta testing, the activation can take up to 2 minutes.
  • The Signal message from the bot will contain the API key needed to send messages using the API.
  • You can now use the API KEY in the ioBroker configuration.
Example: Example
Usage
There are two possibilities to send a messages: ATENTION! It has been noticed that when sending multiple messages within one second, CallMeBot locks a user for 15 minutes. Therefore, it should be ensured that only one message is sent per second.
  • via signal-cmb.0.sendMessage. Just write some text into this state and the message will be sent to default number, that was configured in settings dialog.
  • via message from javascript adapter:
sendTo('signal-cmb.0', 'send', {
    text: 'My message',
    phone: '+491234567890' // optional, if empty the message will be sent to the default configured number
Blockly
Emojies
To send Emojies, you must add some 'Codes' to your Message. You can find all available codes here: https://www.callmebot.com/uncategorized/list-of-urlencoded-unicode-emoticons-emojis/
Available Emojies
The following Emojies are official supported from CallMeBot:
CodeEmojie
%F0%9F%98%80grinning
%F0%9F%98%83grinning big eyes
%F0%9F%98%84grinning smiling eyes
%F0%9F%98%81beaming smiling eyes
%F0%9F%98%86grinning squirting face
%F0%9F%98%85grinning sewat
%F0%9F%A4%A3rolling on the floor laughhing
%F0%9F%A4%A3face with tears of joy
%F0%9F%98%82slightly smiling face
%F0%9F%99%82upside down face
%F0%9F%98%89winking face
%F0%9F%98%8Asmiling face with smiling eyes
%F0%9F%98%87smiling face with halo
Use Emojies
To use an Emojie, you have to insert the code of the Emojie to your text, what you want to send.
Insert Emojie
The signal-cmb adapter URLencode this code and you see in your Signal Messenger on you phone the Emojie.
Emojie Signal Messenger
0.3.1 (28.12.22)
  • (derAlff) Updated 'package.json' to use a minimal version of NodeJS
  • (derAlff) Updated description to configure CallMeBot in 'index_m.html'
  • (derAlff) Updated configuration text with the GUID problem in README
0.2.3 (08.12.22)
  • (derAlff) Added support for 'encoded newline' in string
  • (derAlff) Updated README
0.2.2 (07.12.22)
  • (derAlff) Version change for NPM
0.2.1 (07.12.22)
0.2.0 (07.12.22)
  • (derAlff) Added support for Emojies
  • (derAlff) Added informations about emojies in README
  • (derAlff) Replaced phone number in README/Configuration with link to actual phone number on CallMeBot website
0.1.7 (16.02.22)
0.1.6 (2022-01-22)
  • (derAlff) Released on npm
  • (derAlff) Updated README.md
  • (derAlff) Translated desc in io-package.json
  • (derAlff) Changed connectionType to cloud
  • (derAlff) Changed native part
0.1.5 (2022-01-22)
  • (derAlff) Fixed Blockly issue
0.1.4 (2022-01-22)
  • (derAlff) Updated io-package.json and package.json.
  • (derAlff) Added "messagebox": true to io-package.json.
  • (derAlff) Changed phonenumber in admin page.
0.1.3 (2022-01-21)
  • (derAlff) Updated README.md, io-package.json and package.json
0.1.0
  • (derAlff) Release tested and running version 0.1.0
0.0.1 (2022-01-21)
  • (derAlff) Initial release.
ToDo
  • Add a Phonebook
  • Add multiple users (phone numbers and API-Keys)
Copyright (c) 2022 derAlff derAlff@gmail.com
