Schlueter Ditra Heat Thermostat
Floor heating controlled with Ditra Heat Thermostat
Current Release
0.7.4
patricknitsch
🌍 Overview
This adapter integrates Schlüter / OJ Microline OWD5 thermostats into ioBroker via the official cloud APIs.
It is based on the HA Integration from @robbinjanssen. For more informations see the documentation.
Cloud-only — no local gateway, Modbus, or LAN API required.
🚀 How to Start
  1. Install adapter in ioBroker
  2. Open instance configuration
  3. Enter:
SettingDescription
UsernameYour Schlüter/OJ cloud login
PasswordCloud password
API KeyBelow works in most cases
Customer IDFound in thermostat info
Client SW VersionNumeric value from thermostat
Poll IntervalDefault: 60 seconds
  1. Save & start adapter
For API-Key you can try with: f219aab4-9ac0-4343-8422-b72203e2fac9. You can find this Key in Forum: https://community.home-assistant.io/t/mwd5-wifi-thermostat-oj-electronics-microtemp/445601, so it looks like a global Key.
Documentation
🇺🇸 Documentation
🇩🇪 Dokumentation
Compact Architecture Overview
Architecture Badges
Compact Program Structure
flowchart LR
  UI[User / UI] --> IO[ioBroker States]
  IO --> ADP[Adapter]
  ADP -->|read| OWD5[OWD5 Cloud]
  ADP -->|write| OCD5[OCD5 Cloud]
  OCD5 --> TH[Thermostat]
  ADP --> OBJ[Object Tree]
  OBJ --> RO[Read States]
  OBJ --> AP[Apply Controls]
Internal Flow (Mini)
flowchart TB
  READY[onReady] --> LOGIN[Cloud Login]
  LOGIN --> POLL[pollOnce]
  POLL --> UPSERT[Update Objects + States]
  UPSERT --> BACKOFF{All offline?}
  BACKOFF -- yes --> INC[Increase interval up to 1h then 12:00/00:00]
  BACKOFF -- no --> RESET[Reset to base interval]
  INC --> POLL
  RESET --> POLL
  APPLYBTN[Apply Button] --> ROUTER[applyRouter]
  ROUTER --> API[updateThermostat]
📌 Notes
  • Developed and tested with a single thermostat
  • Multi-device environments supported, but feedback welcome
  • (patricknitsch) Add Node.js 26 in test-and-release.yml
0.7.4 (2026-06-05)
  • (copilot) Fixes for Repo Checker
0.7.3 (2026-05-25)
0.7.2 (2026-05-23)
  • (copilot) Add Icons for Notifications
0.7.1 (2026-05-21)
  • (copilot) Modify notification manager to work with instances
  • (copilot) Update Dependencies
0.7.0 (2026-05-14)
  • (claude) Add Notification Manager
Older changelog entries can be found in CHANGELOG_OLD.md.
Copyright (c) 2026 patricknitsch patricknitsch@web.de
