radar-trap for ioBroker
Documentation
2.2.2 (2024-08-04)
- (Steiger04) Deprecated createState, createChannel, createDevice replaced with setObject and delDevice replaced with delObject
2.2.1 (2024-07-07)
- (Steiger04) Dependencies updated
2.2.0 (2024-05-22)
- (Steiger04) Added counties selection for areas
2.1.3 (2024-05-12)
- (Steiger04) new build run
2.1.2 (2024-05-12)
- (Steiger04) test-and-release.yml changed
2.1.1 (2024-05-12)
2.1.0 (2024-05-12)
- (Steiger04) Some code optimizations
2.0.0 (2024-04-10)
- (Steiger04) !!! No VIS widgets anymore. Continue using v1.3.1 for VIS widgets. Starting from this version, only VIS-2 widgets are supported. !!!
- (Steiger04) Changed Wiki
- (Steiger04) Many optimizations and bug fixes
1.3.1 (2024-02-10)
- (Steiger04) Bug fixes trapInfo for traps
1.3.0 (2024-02-08)
- Steiger04) new states for new and rejected traps
1.2.0 (2024-02-04)
- (Steiger04) Added new state lastUpdated
- (Steiger04) UI optimized
1.1.5 (2024-01-23)
- (Steiger04) createTheme added
1.1.4 (2024-01-22)
- (Steiger04) legacy-peer-deps added
1.1.3 (2024-01-22)
- (Steiger04) Some GUI optimizations
1.1.2 (2024-01-15)
- (Steiger04) Fixed version conflict between react 17 and react 18
1.1.1 (2024-01-14)
- (Steiger04) Fixed legacy-peer-deps
1.1.0 (2024-01-14)
- (Steiger04) Updated on mui5, adapter-react-v5, react 18, react-dom 18
- (Steiger04) Fixed some issues in connection with react 18
1.0.13 (2023-12-23)
- (Steiger04) Circle mode added
1.0.12 (2023-12-19)
1.0.11 (2023-12-19)
- (Steiger04) figbird.js removed
- (Steiger04) Code optimized
- (Steiger04) packages updated
- (Steiger04) DB moved to files folder
1.0.10 (2023-12-02)
- (Steiger04) io-package.json changed (ignoreInVersions)
1.0.9 (2023-11-30)
- (Steiger04) Bugfix for using vis
1.0.8 (2023-11-29)
- (Steiger04) Install vis-widgets only for using vis
- (Steiger04) vis must not be installed for using radar-trap
1.0.7 (2023-09-30)
- (Steiger04) Added features for vis-widgets
- (Steiger04) Added states for counting traps
1.0.6 (2023-09-27)
- (Steiger04) nanoid downgraded to 4.0.2
1.0.5 (2023-09-27)
- (Steiger04) UI optimized and packages updated
1.0.4 (2023-06-17)
- (Steiger04) Added english documentation
1.0.3 (2023-05-18)
- (Steiger04) Changed testmatrix in test-and-release.yml
1.0.2 (2023-05-18)
- (Steiger04) Added documentation
1.0.1 (2023-05-17)
- (Steiger04) initial release
Copyright (c) 2023-2024 Steiger04 steiger04@posteo.de
