Sends Telegram notifications for PV battery status (full, empty, intermediate levels).
Features
- 🔋 Battery Full Notification at 100%
- ⚠️ Battery Empty Notification at 0%
- 📊 Intermediate Levels (20%, 40%, 60%, 80%) with charge level in % and kWh
- 🌙 Night Mode (configurable time, default: 23:00-06:00)
- 🤫 Quiet Mode (configurable time, default: 12:00-15:00)
- 📈 Daily Statistics at configurable time (default: 22:00)
- 📅 Weekly Statistics on configurable weekday
- 📆 Monthly Statistics (optional) on configurable day
- 🌤️ Weather Forecast integration (requires openweathermap adapter)
- ⚡ Recommendations for high production / high consumption
- 📊 Statistics Data from sourceanalytix adapter
Dependencies
The following adapters are required for full functionality:
| Adapter | Description | Required |
| telegram | Sends notifications | ✅ Yes |
| sourceanalytix | Statistics data (consumption, feed-in, grid power) | ✅ Yes |
| daswetter or openweathermap | Weather forecast for recommendations | ❌ Optional |
Configuration
Telegram
| Setting | Description |
| Telegram Instance | E.g. telegram.0 |
| Telegram Users | Comma-separated list of names or IDs, e.g. User1, User2 or -123456789 |
Note: You can add Telegram users both by username (without @) and by Telegram ID (negative for groups/channels).
Data Points
| Setting | Description | Example |
| Battery SOC | SOC value in % | modbus.0.holdingRegisters.40083_Batterie_SOC |
| PV Power | Current power in W | javascript.0.Solar.Sungrow.Leistung |
| Total Production | Production today in kWh | javascript.0.Solar.Sungrow.Gesamtproduktion |
| Feed In | Feed-in today in kWh | sourceanalytix.0...Einspeisung... |
| Consumption | Consumption today in kWh | sourceanalytix.0...Hausverbrauch... |
| Grid Power | Grid power today in kWh | sourceanalytix.0...Netzbezug... |
| Production this Month | Monthly production (kWh) | sourceanalytix.0...Produktion.currentMonth |
| Consumption this Month | Monthly consumption (kWh) | sourceanalytix.0...Verbrauch.currentMonth |
| Feed In this Month | Monthly feed-in (kWh) | sourceanalytix.0...Einspeisung.currentMonth |
| Grid Power this Month | Monthly grid power (kWh) | sourceanalytix.0...Netzbezug.currentMonth |
| Production this Week | Weekly production (kWh) | sourceanalytix.0...Produktion.currentWeek |
| Consumption this Week | Weekly consumption (kWh) | sourceanalytix.0...Verbrauch.currentWeek |
| Feed In this Week | Weekly feed-in (kWh) | sourceanalytix.0...Einspeisung.currentWeek |
| Grid Power this Week | Weekly grid power (kWh) | sourceanalytix.0...Netzbezug.currentWeek |
Weather (Optional)
| Setting | Description | Example (daswetter) | Example (openweathermap) |
| Weather Today | Weather description today | daswetter.0.Day0.forecast.currentSymbol | openweathermap.0.forecast.0.text |
| Temperature Today (°C) | Temperature today | daswetter.0.Day0.forecast.maxTemp | openweathermap.0.forecast.0.temp |
| Weather Tomorrow | Weather description tomorrow | daswetter.0.Day1.forecast.currentSymbol | openweathermap.0.forecast.1.text |
| Temperature Tomorrow (°C) | Temperature tomorrow | daswetter.0.Day1.forecast.maxTemp | openweathermap.0.forecast.1.temp |
Note: The fields Weather Today and Weather Tomorrow can alternatively be used if the weather adapter provides different formats. For best compatibility, we recommend using Weather Text fields.
Battery
| Setting | Description | Default |
| Battery Capacity | Capacity in Wh | 21000 |
| Threshold FULL | SOC for "full" | 100 |
| Threshold EMPTY | SOC for "empty" | 0 |
| Reset FULL below | Reset if SOC < | 95 |
| Reset EMPTY above | Reset if SOC > | 5 |
Intermediate Levels
| Intermediate Levels | Comma-separated SOC levels | 20,40,60,80 |
| Min. Interval FULL | Minutes between notifications | 10 |
| Min. Interval EMPTY | Minutes between notifications | 5 |
| Min. Interval Intermediate | Minutes between notifications | 30 |
| Enable Night Mode | Checkbox for night mode | true |
| Night Mode Start | Start time (Format: HH:MM) | 23:00 |
| Night Mode End | End time (Format: HH:MM) | 06:00 |
| Ignore Night Mode for 0% Battery | Always notify at 0% | true |
| Enable Quiet Mode | Checkbox for quiet mode | false |
| Quiet Mode Start | Start time (Format: HH:MM) | 12:00 |
| Quiet Mode End | End time (Format: HH:MM) | 15:00 |
Statistics
| Daily Statistics Time | Format HH:MM | 22:00 |
| Weekday Weekly Statistics | 0=Mon, 1=Tue, ..., 6=Sun | 0 (Monday) |
| Time Weekly Statistics | Format HH:MM | 10:00 |
| Enable Monthly Statistics | Checkbox for monthly statistics | false |
| Day of Month | 1-31 | 1 (1st of month) |
| Time Monthly Statistics | Format HH:MM | 09:00 |
Examples
Battery Full (100%)
11:45 - 🔋 *Battery FULL* (100%)
⚡ Current Production: 5356 W
🏠 Current Consumption: 1200 W
☀️ Production Today: 12.5 kWh
🔌 Feed-in Today: 8.2 kWh
🌤️ Tomorrow: ☀️ Sunny
🚗 Now ideal for: Electric car, washing machine, dishwasher!
Intermediate (60%)
11:51 - 🔋 Battery at 60% (12.6 kWh) ⬆️
⚡ Production: 5356 W
Daily Statistics (22:00)
22:00 - 📊 *Daily Statistics PV System*
🔋 Current Charge Level: 85%
⚡ Current Energy: 17.9 kWh (21.0 kWh Total)
☀️ Production: 12.5 kWh
🏠 Own Consumption: 8.2 kWh (65.6%)
🔌 Feed-in: 4.3 kWh
⚡ Grid Power: 2.1 kWh
Monthly Statistics (1st of month at 09:00)
09:00 - 📊 *Monthly Statistics PV System*
🔋 Full Cycles This Month: 28
📉 Empty Cycles This Month: 15
☀️ Production: 345.2 kWh
🏠 Own Consumption: 287.5 kWh (83.3%)
🔌 Feed-in: 57.7 kWh
⚡ Grid Power: 23.4 kWh
States
The adapter creates the following states under pv-notifications.0:
Current Statistics
| State | Type | Description |
statistics.fullCyclesToday | number | Full cycles today |
statistics.emptyCyclesToday | number | Empty cycles today |
statistics.maxSOCToday | number | Max SOC today |
statistics.minSOCToday | number | Min SOC today |
statistics.fullCyclesWeek | number | Full cycles this week |
statistics.emptyCyclesWeek | number | Empty cycles this week |
statistics.currentSOC | number | Current SOC |
statistics.currentEnergyKWh | number | Current energy in kWh |
Saved Last Month Data (for Monthly Statistics)
statistics.lastMonthProduction | number | Production last month (kWh) |
statistics.lastMonthConsumption | number | Consumption last month (kWh) |
statistics.lastMonthFeedIn | number | Feed-in last month (kWh) |
statistics.lastMonthGridPower | number | Grid power last month (kWh) |
statistics.lastMonthFullCycles | number | Full cycles last month |
statistics.lastMonthEmptyCycles | number | Empty cycles last month |
Saved Last Week Data (for Weekly Statistics)
statistics.lastWeekProduction | number | Production last week (kWh) |
statistics.lastWeekConsumption | number | Consumption last week (kWh) |
statistics.lastWeekFeedIn | number | Feed-in last week (kWh) |
statistics.lastWeekGridPower | number | Grid power last week (kWh) |
statistics.lastWeekFullCycles | number | Full cycles last week |
statistics.lastWeekEmptyCycles | number | Empty cycles last week |
Note on Monthly and Weekly Statistics
Important: The adapter automatically saves data from last month and last week in the states.
Monthly Statistics
- Monthly statistics are sent on the configured day (default: 1st of month)
- The adapter automatically saves current monthly data before resetting statistics
- Statistics use saved data from
statistics.lastMonth*states - Configuration: Ensure monthly statistics are sent after the last day of the month (e.g. 1st at 09:00)
Weekly Statistics
- Weekly statistics are sent on the configured weekday (default: Monday)
- The adapter automatically saves current weekly data before resetting statistics
statistics.lastWeek*states - Configuration: Set weekday (0=Mon, 1=Tue, ..., 6=Sun)
Configuration Example (openweathermap)
Configure Weather Data Points
If you use the openweathermap adapter, configure the following fields:
Weather Today: openweathermap.0.forecast.0.text
Temperature Today: openweathermap.0.forecast.0.temp
Weather Tomorrow: openweathermap.0.forecast.1.text
Temperature Tomorrow: openweathermap.0.forecast.1.temp
Alternative: Daswetter Adapter
Weather Today: daswetter.0.Day0.forecast.currentSymbol
Temperature Today: daswetter.0.Day0.forecast.maxTemp
Weather Tomorrow: daswetter.0.Day1.forecast.currentSymbol
Temperature Tomorrow: daswetter.0.Day1.forecast.maxTemp
Example Output with Weather
Daily Statistics:
☀️ Production: 45.2 kWh
🏠 Own Consumption: 32.1 kWh (71%)
🔌 Feed-in: 13 kWh
⚡ Grid Power: 2 kWh
🌤️ *Weather Tomorrow:* ☀️ Sunny 22.5°C
☀️ Good PV production expected!
Weekly Statistics:
📊 *Weekly Statistics PV System*
🔋 Full Cycles Last Week: 5
📉 Empty Cycles Last Week: 3
☀️ Production: 312.5 kWh
🏠 Own Consumption: 224.8 kWh (72%)
🔌 Feed-in: 87.7 kWh
⚡ Grid Power: 45.3 kWh
💡 A healthy cycle per day is normal.
🔋 Check battery settings if many cycles.
🔋 Full Cycles Last Month: 28
📉 Empty Cycles Last Month: 15
☀️ Production: 1245.7 kWh
🏠 Own Consumption: 897.3 kWh (72%)
🔌 Feed-in: 348.4 kWh
⚡ Grid Power: 185.2 kWh
Night Mode & Quiet Mode
Night Mode (configurable)
Between 23:00 and 06:00 (configurable), the following notifications are suppressed:
- ❌ Battery FULL (100%)
- ❌ Intermediate Levels (20%, 40%, 60%, 80%)
The following notification is always sent:
- ✅ Battery EMPTY (0%) – if "Ignore night mode for 0% battery" is enabled
Quiet Mode (configurable)
Between 12:00 and 15:00 (configurable), all notifications are suppressed:
- ❌ Battery EMPTY (0%)
Note: Quiet mode suppresses all notifications including 0% battery. Use it for times when you don't want to be disturbed at all (e.g. nap time, meetings).
Author
Alex1808 via LLM: Qwen
1.2.29
- (FIX) Corrupted UTF-8 separator lines in the monthly stats message (showed as question marks in Telegram)
- (FIX) Corrupted Russian translations for "Current charge level" and "Own consumption"
- (FIX) Weather today in daily stats now shows the temperature as "(currently: X°C)" instead of implying a daily value
1.2.28
- (FIX) Migrate i18n to short format ({lang}.json); trim news to 7 entries
1.2.27
- (FIX) CI: update package-lock.json to include all eslint peer dependencies
1.2.26 (2026-08-01)
- (FIX) W5604: add missing i18n keys for sunset stats in 8 languages (es, fr, it, nl, pl, pt, uk, zh-cn)
- (FIX) W6019: move old changelog entries to CHANGELOG_OLD.md
- (FIX) W6021: move License section to end of README
- (FIX) W6030: add 1.2.25 changelog entry to README
1.2.25 (2026-08-01)
- (FIX) Update @iobroker/adapter-core to 3.4.3
- (FIX) Remove old news entry 1.2.18 (max 7 entries allowed)
1.2.24 (2026-03-17)
- (FIX) Added missing uk translations to news entries, fixed prettier formatting in main.js
1.2.23 (2026-03-17)
- (FIX) Statistics section layout: daily time, sunset checkbox and sunset object aligned on one row
1.2.22 (2026-03-17)
- (ADD) Sunset-based daily statistics: optional checkbox to send daily stats at sunset time from a configurable object instead of fixed time
1.2.21 (2026-03-17)
- (FIX) Use extendObject instead of setObjectNotExists for states with unit/role to update existing instances
1.2.20 (2026-03-17)
- (FIX) Remove unused admin files, reduce info logs to debug, English state names with units, channel objects for statistics/info, button read:false, this.setInterval, translate fallback to English
1.2.19 (2026-03-16)
- (FIX) Added v1.2.18 entry to news section in io-package.json
1.2.18 (2026-03-16)
- (FIX) Missing await in onBatterySOCChange, null-check in buildTestMessage, safe intermediateSteps parsing, remove dead code
For older changelog entries see CHANGELOG_OLD.md
Documentation in Other Languages
Copyright (c) 2025-2026 Alex1808 via LLM: Qwen sadam6752@gmail.com
