Pirate Weather
Получить данные из пиратской погоды.
Текущий релиз
0.8.0
Разработчик
ticaki
Лицензия
адаптер pirate-weather для ioBroker
Получить данные с сайта Pirate-Weather.
Необходимый API-токен можно получить здесь: https://docs.pirateweather.net/en/latest/ Остальное должно быть понятно. Объяснение значения отдельных точек данных можно найти здесь: https://docs.pirateweather.net/en/latest/API/
Иконки: от icebear (можно использовать бесплатно)
0.8.0 (2025-11-19)
  • (ticaki) added day_night
  • (ticaki) added haze icon fixes #18
0.7.1 (2025-10-16)
  • (ticaki) Improved error logging
0.7.0 (2025-09-30)
  • (ticaki) Added comprehensive astronomy data to daily forecast: twilight times, day/night length, solar noon, moonrise/moonset, and lunar transit
  • (ticaki) Added human-readable time formats (HH:MM:SS) for duration fields
0.6.2 (2025-09-27)
  • (ticaki) more robust fetch usage
0.6.1 (2025-09-26)
  • (ticaki) Use the default icons for mostly-
0.6.0 (2025-09-25)
  • (ticaki) icons from icebear added
0.5.0 (2025-09-24)
  • (ticaki) Code migration from axios to node:fetch
  • (ticaki) Corrected roles for visualisation (lovelance) fixes #19
0.4.1 (2025-09-12)
  • (ticaki) Humidity is now displayed correctly in percent. fixes #15
  • (ticaki) Wind direction text is now translated into the system iobroker language. fixes #16
0.4.0 (2025-08-28)
  • (ticaki) In the CA system of units, precipAccumulation is now output in mm.
  • (ticaki) Use api version 2
0.3.0 (2025-08-25)
  • (ticaki) update deps - inital latest release
  • (ticaki) increase delay by 1.5 seconds
0.2.0 (2025-08-16)
  • (ticaki) Configuration option to enter an interval in minutes. In the event of an error, no accelerated reconnection is used here.
  • (ticaki) Use system language for summaries.
0.1.4 (2025-08-15)
  • (ticaki) Ignore ECONNABORTED error code
  • (ticaki) In the event of an error, new connection attempt in 10 minutes
  • (ticaki) missing % added
  • (ticaki) Startup log message added.
0.1.3 (2025-08-12)
  • (ticaki) BREAKING: cloudCover, precipProbability, humidity and moonPhase are now percentage values
0.1.2 (2025-08-10)
  • (ticaki) update icon
0.1.1 (2025-08-10)
  • (ticaki) First version for the iobroker repository
0.1.0 (2025-08-09)
  • (ticaki) units (us, ca, uk) added
  • (ticaki) beautiful states :)
  • (ticaki) Zero minutes and seconds in the interval.
  • (ticaki) fixed: Language undefined not exist!
0.0.7 (2025-08-09)
  • (ticaki) data removed from enumeration names
Copyright (c) 2025-2026 ticaki github@renopoint.de
