Piratenwetter-Adapter für ioBroker
Daten von Pirate-Weather abrufen.
Das benötigte API-Token erhalten Sie hier: https://docs.pirateweather.net/en/latest/ Der Rest ist selbsterklärend. Die Erläuterung der einzelnen Datenpunkte finden Sie hier: https://docs.pirateweather.net/en/latest/API/
Icons: von icebear (kostenlos nutzbar)
0.8.0 (2025-11-19)
- (ticaki) added day_night
- (ticaki) added haze icon fixes #18
0.7.1 (2025-10-16)
- (ticaki) Improved error logging
0.7.0 (2025-09-30)
- (ticaki) Added comprehensive astronomy data to daily forecast: twilight times, day/night length, solar noon, moonrise/moonset, and lunar transit
- (ticaki) Added human-readable time formats (HH:MM:SS) for duration fields
0.6.2 (2025-09-27)
- (ticaki) more robust fetch usage
0.6.1 (2025-09-26)
- (ticaki) Use the default icons for mostly-
0.6.0 (2025-09-25)
- (ticaki) icons from icebear added
0.5.0 (2025-09-24)
- (ticaki) Code migration from axios to node:fetch
- (ticaki) Corrected roles for visualisation (lovelance) fixes #19
0.4.1 (2025-09-12)
- (ticaki) Humidity is now displayed correctly in percent. fixes #15
- (ticaki) Wind direction text is now translated into the system iobroker language. fixes #16
0.4.0 (2025-08-28)
- (ticaki) In the CA system of units, precipAccumulation is now output in mm.
- (ticaki) Use api version 2
0.3.0 (2025-08-25)
- (ticaki) update deps - inital latest release
- (ticaki) increase delay by 1.5 seconds
0.2.0 (2025-08-16)
- (ticaki) Configuration option to enter an interval in minutes. In the event of an error, no accelerated reconnection is used here.
- (ticaki) Use system language for summaries.
0.1.4 (2025-08-15)
- (ticaki) Ignore ECONNABORTED error code
- (ticaki) In the event of an error, new connection attempt in 10 minutes
- (ticaki) missing % added
- (ticaki) Startup log message added.
0.1.3 (2025-08-12)
- (ticaki) BREAKING: cloudCover, precipProbability, humidity and moonPhase are now percentage values
0.1.2 (2025-08-10)
- (ticaki) update icon
0.1.1 (2025-08-10)
- (ticaki) First version for the iobroker repository
0.1.0 (2025-08-09)
- (ticaki) units (us, ca, uk) added
- (ticaki) beautiful states :)
- (ticaki) Zero minutes and seconds in the interval.
- (ticaki) fixed: Language undefined not exist!
0.0.7 (2025-08-09)
- (ticaki) data removed from enumeration names
Copyright (c) 2025-2026 ticaki github@renopoint.de
