Open-Meteo Weather Service
"Get local weather, air quality, pollen data and photovoltaic forecast from Open-Meteo.com",
Current Release
3.2.1
H5N1v2
ioBroker.open-meteo-weather
Important information:
Open Meteo Weather and Open Meteo PV Forecast have now been merged into this adapter. Open Meteo PV Forecast is no longer maintained.
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and instructions on disabling error reporting, please refer to the Sentry-Plugin Documentation! Use of Sentry reporting starts with js-controller 3.0.
I use my own Sentry server based on Glitchtip.
The Open-Meteo Weather & PV Forecast Service Adapter for ioBroker.
This adapter provides precise weather data, forecasts, air quality, pollen & Photovoltaic Forecast information powered by Open-Meteo.com. It is free for non-commercial use (under 10,000 daily API calls) and requires no API key registration, making the setup process extremely simple.
Should the adapter encounter issues such as timeouts or server errors, you can check the Open-Meteo Server Status.
Features Weather
  • Current Weather Data: Real-time retrieval of temperature, humidity, air pressure, and wind data.
  • 15-minute forecast with a maximum of 16 datasets for the next 4 hours.
  • Flexible Forecasts: Configurable number of forecast days and hourly resolution.
  • Air Quality & Pollen: Optional data for particulate matter (PM2.5, PM10) as well as various pollen types (alder, birch, grass, etc.).
  • Automatic Cleanup: The adapter automatically cleans up the object structure if forecast periods are shortened or changed in the configuration.
  • Multi-Language Support: Supports 11 languages (including English, German, Polish, Russian, French, Chinese, etc.).
  • Unit System: Seamless switching between Metric (°C, km/h) and Imperial (°F, mph) systems.
  • Multi Location: Add multiple Locations.
  • Night Icons: You can choose between two night icon sets, "Bright" and "Dark". This makes it easier to match the icon to your background.
Wind Direction Icons
In the adapter settings, you can choose between two different visualization styles for the wind direction:
  • Wind direction (where the wind is blowing to): This is the standard setting. The arrow points in the direction the wind is moving. (Example: A north wind shows an arrow pointing South).
  • Wind origin (where the wind is coming from): This style uses icons from the direct_2 subfolder. The arrow indicates the source of the wind. (Example: A north wind shows an arrow pointing North or a specific "origin" icon).
SettingIcon PathBehavior
Wind direction (where the wind is blowing to)/icons/wind_direction_icons/*.pngPoints to destination
Wind origin (where the wind is coming from)/icons/wind_direction_icons/direct_2/*.pngPoints to origin
Air Quality Data
The adapter provides current air quality data and a daily forecast for the upcoming days (configurable for 1, 3, or 6 days).
Efficient Data Processing: While the Open-Meteo API only provides raw hourly data, this adapter intelligently aggregates these values. It automatically calculates the daily maximum for all pollutants and pollen levels. This gives you the most relevant data (peak exposure levels) without bloating your database with hundreds of hourly data points.
Features:
  • Daily Peaks: Get the highest expected value for PM2.5, PM10, Ozone, and various pollen types.
  • Human Readable: Pollen levels are automatically mapped to descriptive categories (e.g., "None", "Low", "Moderate", "High").
  • Smart Cleanup: Objects for forecast days are automatically created or removed based on your settings to keep your object tree clean.
Configuration
After installation, configure the following fields in the instance settings:
  1. Location: Add your Location or a name you want.
  2. Coordinates (Latitude & Longitude): Add your coordinates. You can find them by clicking the 'Find coordinates with OpenStreetMap' button, or leave the fields empty to use the system coordinates.
  3. Time Zone: Set the timezone in the dropdown menu, the default is 'Auto', which automatically adjusts based on your coordinates.
  4. Update Interval: Time interval in minutes (Default: 30 min).
  5. Forecast Days: Number of days for the daily overview (0–16 days).
  6. Hourly Forecast: Enable or disable this option and set the number of hours (e.g., the next 24 hours). For example, hour0 is the current hour, hour1 is the next hour, and so on.
  7. Optional Data: Checkboxes for pollen and air quality data.
  8. Units: Choose between Metric and Imperial.
Weather Widget
This adapter offers two ways to display weather data in your visualization:
1. Built-in Widget (Standard)
Since version 3.1.0, the adapter can automatically generate a pre-configured HTML widget for each location.
How to use:
  1. Enable: Check the "Create Widget" checkbox in the instance settings for your location.
  2. Find State: The adapter will create a state called htmlWidget (under open-meteo-weather.0.yourLocation.htmlWidget).
  3. In VIS/VIS2: * Drag a standard "HTML" widget onto your view.
    • Set the "HTML" property of that widget to the binding of your state: {open-meteo-weather.0.yourLocation.htmlWidget}.
    • Adjust the width and height of the widget container to fit the content.
Customization: You can only adjust basic settings like font sizes, forecast hours and days directly in the adapter configuration.
Best for: Users who want a quick, beautiful, and maintenance-free display.
Note: For optimal display on desktop browsers, do not use additional CSS borders or shadows in the VIS editor settings. The widget comes with its own optimized styling.
2. Advanced Widget Script (Full Customization)
If you want to make deep changes to the design, add your own CSS, or extend the logic:
Icons & Visualization
The adapter provides dynamic icon paths that can be used directly in visualizations such as vis, iQontrol, or Jarvis.
  • Weather Icons: Found under weather.current.icon_url. The adapter automatically distinguishes between day and night (e.g., Sun vs. Moon).
  • Wind Direction: Static paths under wind_direction_icon display a compass arrow corresponding to the degree value (Display direction selectable).
  • Wind Gust Warning: A warning icon is displayed under wind_gust_icon for wind speeds above approx. 39 km/h (Bft 6), featuring levels 0–4.
  • Moon Phases Icons: Moon icons can be found under moon_phase_icon they display the moon phases.
  • Multiple Icons: You can choose between static and animated (by basmilius) icons.
Data Points (Excerpt)
FolderDescription
air.currentAir quality and pollen levels as text and value
air.forecast.dayXDaily air quality forecast for Day X
weather.currentCurrent measurements (Temp, Dew point, Wind, etc.)
weather.forecast.dayXDaily forecast for Day X
weather.forecast.hourly.hourXHourly details per full hour
info.lastUpdate_weatherShows Date and Time from last Weather Update
If you do not need the weather forecasts, leave the location field blank, no states will be entered.
Features PV Forecast (if enabled)
  • Multiple Locations: Support for multiple PV systems/locations, e.g., for East/West orientations.
  • Hourly Forecast: Detailed prediction of power output, temperature, cloud cover, and sunshine duration.
  • Daily Forecast: Summary of expected energy (Wh) for up to 14 days.
  • 15-Minutes Forecast: 15-Minutely forecast for current day, 24 hours.
  • Physical Simulation:
    • Tilt & Azimuth: Irradiance calculation based on panel orientation.
    • PV Module Temperature: Estimation of cell temperature considering ambient temperature, radiation intensity, and wind speed (Faiman model).
    • Sunshine Duration: Conversion of sunshine duration into minutes per hour.
  • Aggregation: Automatic summing of all locations (total forecast) on both a daily, hourly and 15-minutely basis.
  • System Integration: Automatic acquisition of location coordinates from the ioBroker system configuration if not manually set.
  • PV Module Temperature: Estimated PV Module Temperature, based on Faiman model.
Data Points (Objects)
For each configured location, a channel is created with the following data points in:
FolderDescription
pv-forecastFolder for PV-Forecast Data
15 Minutely Forecast (15-min-forecast.0 - 95), (24 Hours of current day), if enabled
Data PointUnitDescription
global_tilted_irradianceWhExpected energy based on installed capacity (kWp).
pv_temperature°CEstimated PV module temperature (Faiman calculation).
temperature_2m°CAir temperature at 2 meters height.
time-Forecast time (HH:mm).
wind_speed_10mkm/hWind speed at 10 meters height.
Info: temperature_2m and wind_spread_10m are needed to calculate the PV module temperature.
Optionally selectable if needed, otherwise the DP are included in the weather.
cloud_cover%Total cloud cover in percent.
sunshine_durationminActual sunshine minutes within this hour.
Daily Forecast (daily-forecast.dayX)
Date-Forecast date (DD.MM.YYYY).
Peak_dayWhExpected total daily yield.
Forecast JSON (location_folder) if enabled
15-min-json_chart-JSON 15-min
hourly-json_chart-JSON hourly
Hourly Forecast (hourly-forecast.hourX)
sum_peak_locations_15_Minutly (0-95) if enabled
sum_locationsWhSum of Locations 15 Minutely
sum_peak_locations_Daily (dayX) if enabled
sum_locationsWhSum of Locations Daily
sum_peak_locations_Hourly (HourX) if enabled
sum_locationsWhSum of Locations Hourly
JSON Datapoints if enabled
sum_peak_15-min-json_chart-Sum of Locations 15 min in JSON
sum_peak_hourly-json_chart-Sum of Locations hourly in JSON
Configuration
Basic Settings
  • Forecast Hours: Timeframe for the hourly view (3 to 48 hours).
  • Forecast Days: Duration of the daily forecast (3 to 14 days).
  • Update Interval: Frequency of data updates (15, 30, 60 minutes or once before Sunrise).
Datapoints Settings
  • Rolling Hours or Fixed Hours: If 'Rolling Hours' is selected, the hourly forecast will always show the next hours starting from the current hour. If 'Fixed Hours' is selected, the hourly forecast will show fixed time intervals (e.g., 00:00-23:00) regardless of the current time.
  • 15-minutes Forecast: If enabled, additional states will be created for a 15-minute forecast (up to 24 hours for the current day). Please note that 15-minute data availability depends on the Open-Meteo API and may vary by location or time.
Locations (Table)
The following values must be defined for each location:
  1. Name: Unique identifier (sanitized for the object ID).
  2. Latitude/Longitude: GPS position (optional: uses system values otherwise).
  3. Tilt: Angle of the modules (0° = flat, 90° = vertical).
  4. Azimuth: Orientation (-180° to 180°, 0° = South, -90° = East, 90° = West).
  5. Power (kWp): Installed peak capacity of the system.
  6. Timezone: Selection of the local timezone (Default: Auto).
Global Options, only adjustable if you have multiple Locations!
  • Total Sum (Daily): Creates the channel sum_peak_locations_Daily, summing the yields of all systems.
  • Total Sum (Hourly): Creates the channel sum_peak_locations_Hourly for the total hourly performance.
  • Total Sum (15-Minutely): Creates the channel sum_peak_locations_15_Minutely for the total 15 Minutes forecast.
Technical Details & Calculation
PV Temperature Model
The adapter uses the Faiman model to estimate the module temperature. This model accounts for wind cooling, which directly impacts efficiency: pvTemp = Ambient Temperature + Irradiance / (25 + 6.84 * Wind Speed).
Update note
After a new adapter update, it is recommended to delete the entire directory tree and let it be recreated.
3.2.1 (2026-09-12)
  • (H5N1v2) add 'diffuse_radiation' to 15 min weather forecast.
  • (H5N1v2) add node.js 26.x testmatrix
  • (H5N1v2) Update dependencies
3.2.0 (2026-09-06)
  • (H5N1v2) Adding configurable 15 minute weather forecast with max. 16 Datasets for the next 4 hours.
3.1.4 (2026-07-18)
  • (@GermanBluefox) upscaled the logo
  • (@GermanBluefox) Updated TS to 6
  • (@GermanBluefox) Corrected image in JsonConfig
  • (H5N1v2) Resize logo to 512x512
  • (pk68) fix: info.lastUpdate_PV_Forecast is no longer updated if all API calls failed or returned empty data.
  • (H5N1v2) fix: PV Forecast sunrise mode now retries automatically after 30 minutes if the API call fails (e.g. HTTP 500 overload). The next day's schedule is only planned after a successful update.
  • (H5N1v2) add open-meteo status link in adapter description and README.
  • (H5N1v2) fix: made OpenStreetMap link clickable in the admin area.
  • (H5N1v2) Update dependencie.
3.1.3 (2026-06-20)
  • (H5N1v2) Fixed an issue with object creation caused by an accidental change.
3.1.2 (2026-06-20)
  • (mcuiobroker) fix: after adapter update, automatically adjust type and role if they have been changed in new versions.
Legal & Copyright
Icons & Images
Animated weather icons by Bas Milius
The static weather and wind direction icons included in this adapter are subject to the creator's copyright.
  • Usage: These icons are licensed for use within ioBroker. Commercial redistribution or use outside of this adapter requires the explicit consent of the author: h5n1@iknox.de.
  • Weather Data: All weather data is provided by Open-Meteo.com. Please review their terms of use for commercial purposes.
This project is licensed under the MIT License - see the LICENSE file for details.
Copyright (c) 2026 H5N1v2 h5n1@iknox.de
