Omron FINS
Connect Omron PLCs to ioBroker using the FINS protocol
Current Release
0.1.0
TheBam
Connect Omron CP, CV, CS, CJ, NJ and compatible NX PLCs to ioBroker using the FINS protocol over UDP or TCP.
German documentation: READMEde.md
Configuration
Configure the PLC IP address, FINS port (normally 9600), protocol and polling interval in the responsive adapter administration page. Destination/source node values may remain 0 for automatic addressing unless the PLC network requires explicit FINS routing.
Variables can be entered manually with a unique name, FINS address and data type. Supported examples include CIO0.00 (or legacy CB0:00), W31.00, H0.01, A0.00, D100, timers and counters.
Each variable becomes a writable ioBroker state unless the writable option is disabled. Writes are acknowledged only after the FINS request succeeds.
CX-Programmer symbol table import
Export the symbol table from CX-Programmer as CSV or tab-separated text and paste its contents into the corresponding configuration field. The adapter detects English and German name/address/data-type headers and imports the symbols automatically. Comma, semicolon and tab delimiters are supported. Manual variables override imported symbols with the same name.
Troubleshooting
  • info.connection is only true after a successful PLC response.
  • info.lastError contains the most recent communication or configuration error.
  • Check UDP/TCP port 9600 and the PLC FINS/ETN settings.
  • If automatic node addressing fails, configure DA1 and SA1 explicitly.
0.1.0
  • Updated for Node.js 22/24, js-controller 6 and current adapter-core
  • Replaced the legacy administration page with responsive JSON Config
  • Added UDP/TCP, timeout and FINS node settings
  • Added automatic CX-Programmer CSV/TSV symbol table import
  • Prevented overlapping polls and added reliable connection/error handling
  • Updated tests, linting, release and Dependabot workflows
0.0.2
  • Improved cyclic polling
Copyright (c) 2021-2026 TheBam elektrobam@gmx.de
MIT License. See LICENSE.
