lowpass-filter adapter for ioBroker
You can filter states of type number according to the filter algorithm of a first-order low-pass filter. e.g. you can filter power values to cut power peeks.
2.6.1 (2026-02-28)
- (BenAhrdt) update dependencies
2.6.0 (2025-10-19)
- (BenAhrdt) update Authentication NPM
- (BenAhrdt) update defDependencie eslint
- (BenAhrdt) update dependencie core
- (BenAhrdt) update dependencie to node >= 20
- (BenAhrdt) update testing to 24.x
2.5.0 (2025-02-18)
- (BenAhrdt) update dependency from admin and js-controller
2.4.1 (2025-01-05)
- (BenAhrdt) copyrigth changed to 2025
2.4.0 (2024-12-04)
- (BenAhrdt) Changed ESLint
2.3.1 (2024-11-26)
- (BenAhrdt) Changed Schema and responsive tags
2.3.0 (2024-08-13)
- (BenAhrdt) Update Dependencies: "js-controller": ">=5.0.19" Check your System before installing new Version
2.2.5 (2024-08-09)
- (BenAhrdt) correct changes for check and service bot
2.2.4 (2024-08-09)
- (BenAhrdt) changes for check and service bot
2.2.3 (2023-11-12)
- (BenAhrdt) input check for node => 16
2.2.2 (2023-11-02)
- (BenAhrdt) correction in jsonconfig schema
2.2.1 (2023-04-26)
- (BenAhrdt) ukrain language added
2.2.0 (2023-04-13)
- (BenAhrdt) added some filtertimes (1s-9s)
2.1.0 (2023-04-06)
- (BenAhrdt) updated to actual dependencies
2.0.8 (2023-02-16)
- (BenAhrdt) limit of decimal places reduced to 8
2.0.7 (2023-02-16)
- (BenAhrdt) limit of decimal places implemented
2.0.6 (2023-01-20)
- (BenAhrdt) inplement the unit of the filtered falue
2.0.5 (2022-06-17) - readme changed
- (BenAhrdt) change some wrong links in readme file
2.0.4 (2022-06-16) - loglevel check deleted
- (BenAhrdt) dont check loglevel before log.debug()
2.0.3 (2022-06-13) - translate io-package
- (BenAhrdt) implement some translations into io-package
2.0.2 (2022-06-13) - adpater type changed
- (BenAhrdt) adapter tpe changed into misc-data
2.0.1 (2022-06-08) - loglevel implemented
- (BenAhrdt) logging just in loglevel mode "debug"
2.0.0 (2022-06-04)
- (BenAhrdt) workflow implemented
1.14.9
- (BenAhrdt) fixed some changes in readme
1.14.8
- (BenAhrdt) implements translation
Copyright (c) 2025-2026 BenAhrdt bsahrdt@gmail.com
