IoBroker LG TV RS232 adapter is used to control your LG TV via RS232 in conjunction with the Etnernet Gateway.
The list of models and commands is contained in the admin/commands.json file.
Hardware
The driver allows you to connect to the LG TV through the adapter RS232 to Ethernet.
As an RS232 gateway to Ethernet, any Arduino compatible card in which you need to download this code is used. You will also need an Ethernet Shield W5100 or W5500 and an RS232 to TTL converter.
Support
Supported models: LD750 to be...
0.1.1
(instalator) change test
0.1.0
(instalator) support compact mode (instalator) support admin3 (instalator) refactoring
0.0.4
(instalator) fix error
0.0.3
(instalator) alfa
0.0.1
(instalator) initial
The MIT License (MIT)
Copyright (c) 2021 instalator vvvalt@mail.ru
