Versions
Adapter for Reading Kostal Piko & Piko BA Data for iOBroker
This adapter allows for reading data from Kostal Piko, Piko BA, and PIKO MP plus inverters. It creates and sequentially updates several states, ensuring that the latest information is always available. The adapter is specifically designed for Kostal Piko BA, 6.0BA, 8.0BA, and 10BA inverters, but it also supports a wide range of other models, including:
- Kostal Piko: 3.0, 4.2, 4.6, 5.5, 7.0, 8.5, 10, 12, 15, 17, 20, and 36.
- Kostal PIKO MP: 1.5, 3.0, 3.6.
- Kostal PIKO MP plus: 1.5-1, 2.0-1, 2.5-1, 3.0-1, 3.0-2, 3.6-1, 3.6-2 and 5.0-2.
We appreciate any feedback on functionality with other inverters. Please send us a note if you test it with additional models.
Configuration
Ensure that your Piko or Piko BA inverter is updated to Kostal UI version 6.11 or higher. To connect to the Kostal Piko (BA / MP plus) inverter, you must configure its IP address in the settings. Optionally, you can adjust the update frequencies for live data, daily statistics, and lifetime statistics. If your hardware supports it, you can also enable the read-out of the four analog values.
Sentry
This adapter uses Sentry libraries to automatically report exceptions and code errors to the developers. For more details and for information on how to disable error reporting, see Sentry-Plugin Documentation!
If you enjoyed this project — or just feeling generous, consider buying me a beer. Cheers! :beers:
7.0.7 (2026-09-12)
- (HombachC) switch to iobroker testing 6.x
- (HombachC) fixed vulnerability
- (HombachC) updated dependencies, axios
- (HombachC) added node 26 tests
- (HombachC) fixed repochecker warnings
7.0.6 (2026-07-27)
- (HombachC) fixed misleading HTTP error 200 log message caused by network interruption during response body reading
- (HombachC) improved connection error handling: added ECONNRESET + ECONNABORTED cases and default fallback for unknown error codes
7.0.5 (2026-07-05)
- (ioBroker-Bot) Adapter requires admin >= 7.8.23 now
- (HombachC) removed chai-based unit test dependencies; modernized test harness to Node.js assert
7.0.4 (2026-06-19)
- (HombachC) fixed adapterchecker warnings
7.0.3 (2026-06-03)
- (HombachC) fixed instanceObject roles
- (HombachC) fixed warnings of adapter checker
Old Changes see CHANGELOG OLD
Copyright (c) 2020-2026 C.Hombach Kostal-Piko-BA@homba.ch
