Innogy Smarthome
ioBroker Innogy Smarthome
Current Release
1.2.6
Patrick Arns
This adapter is used to connect the Livisi SmartHome devices to ioBroker. You can read more about Livisi here.
Requires Node > 8.x
Please note: For the Authentication process Port 3000 (by default, con be changed in configuration) is needed to be available on the host. Please check that nothing else is using it (e.g. Grafana) This version supports now also the new Livisi Local SmartHome functionality! Please switch to the local version because the Livisi Cloud will be disabled in Q1/2023!
HELP WANTED!
As this project is developed during my spare time, I*m actively looking for help to maintain and extend this lib! If you're willing to help, drop me a line!
1.2.6 (2023-01-27)
  • (Apollon77) Added more states
1.2.5 (2023-01-07)
1.2.4 (2023-01-05)
  • (Apollon77) Added shockDetected states
  • (Apollon77) Handled room enums better for an empty room
1.2.3 (2023-01-04)
  • (Apollon77) Made activeChannel states writable to trigger Alarm
  • (Apollon77) Fixed unit for chargingCurrent
1.2.2 (2023-01-03)
  • (Apollon77) Added missing state definitions (motionDetected, operatingTimeCurrentWeek, operatingTimeLastWeek)
  • (Apollon77) Prevented crash cases reported by Sentry
1.2.1 (2022-12-31)
  • (Apollon77) Optimize Authentication server handling
1.2.0 (2022-12-30)
  • (Apollon77) Changed storage of authentication tokens to allow multiple instances on one host (for instance 0)
1.1.2 (2022-12-29)
  • (Apollon77) Added more missing states for several devices
1.1.1 (2022-12-28)
  • (Apollon77) Added missing ISS2 states
1.1.0 (2022-12-28)
  • (Apollon77) Prevented crash cases when setting values is not successful
  • (Apollon77) Added Sentry for Crash reporting and missing state reporting
1.0.0 (2022-12-24)
  • IMPORTANT: This updates introduces a new object ID level as Channel, so all Object-IDs will change!
  • IMPORTANT: The local SHC Password needs to be re-entered in Admin!
  • (Apollon77) Added support for local connections to SHC Classic/Generation 1
  • (Apollon77) Added lowBattery and isReachable states and Message support to update them
  • (Apollon77) Added option to configure the port for the redirect back server for OAuth with cloud connection (default 3000)
  • (Apollon77) Add more missing states
  • (Apollon77) General updates and optimizations
0.4.7
  • Changed OAuth local auth
0.4.6
  • Added missing states
0.4.5
  • Fixed a naming problem with newly created devices
0.4.3
  • Added min & max for pointTemperature
0.4.2
  • Added debug information for invalid value data
  • Fixed . in device names
  • Fixed crashes caused by invalid point temperatures (< 6 & > 30)
0.4.1
  • Fixed cloud auth, if local auth is activated (blank page)
  • Changed Admin design to be compatible with black & white style
0.4.0
  • Added support for new Local SmartHome (currently in Beta, requires SHC 2 & Firmware >= 8.17 - you can find more info here)
0.3.7
  • Prevent js-controller 3.3 warnings
0.3.6
  • Fixed authorization issues
0.3.5
  • Updated authorization endpoint
  • Added shutter
0.3.4
  • Make Hue bulbs writeable (brightness)
0.3.3
  • Fixed non switchable variables for new installations (missing native ID)
0.3.2
  • Added more Hue properties
0.3.1
  • Added PowerControl
  • Added SHC 2.0 quota states
0.3.0
  • Added support for SHC 2.0 (and API 1.1)
0.2.11
  • Reverted changes from yesterday, as RW states are not correctly maintained by innogy
0.2.10
  • Respecting RW state of Capabilities. Please don't try to write to read only states!
0.2.9
  • Fixed a problem with timer updates updating device states too often. Please update ASAP
0.2.8
  • Fixed a config parsing crash
  • Added a lot of new device descriptors to speed up inital boot
  • Increased request limit from 2 to 6 req/sec
0.2.7
  • Added handler for non local SHC access and 403 responses (outdated mobile access scenarios)
  • Added handler for broken push connection
0.2.6
  • Fixed an exception once the Innogy API closes the status socket connection
0.2.5
  • Implemented throttling changes required by the Innogy API
0.2.4
  • Fixed Travis CI build errors
0.2.3
  • Updated underlying libs
  • Changed update timer from 5 mins to 30 mins + 0-30 mins
0.2.2
  • Fixed reauth problems
  • Fixed initial auth problems
  • Optimized API errors
  • Optimized caching of descriptor files
0.2.1
0.2.0
  • Removed external OAuth2 lib
  • Authorization optimization
0.1.22
  • Fixed initial reauth problem V3
0.1.21
  • Fixed initial reauth problem next try
  • Added Netatmo Wind Sensor
0.1.20
0.1.19
  • Fixed an underlying auth problem
0.1.18
  • Updated innogy lib
  • Updated adapter category
  • Updated adapter tests
0.1.17
0.1.16
  • Fixed a lot of stuff
0.1.11
  • Added Dimmer
0.1.9
  • Added a better reconnect handling for internal websocket connection to the API
  • Better error handling
0.1.8
  • Added a workaround for corrupted API function which causes a problem during reconnection phase
0.1.7
  • Added the ability to detect connection problems with auto reconnect
0.1.6
  • More Innogy API error handling with general reconnect on API error
  • Added connected state (yellow state)
0.1.5
  • Added new device discovery
  • Added auto connect retry for "remote access not allowed"
  • Fixed exception if device was not found
  • Fixed setState for RST OperationMode
0.1.4
  • Fixed Shutter in underlying lib
  • Fixed WebSocket reconnect error in underlying lib
0.1.3
  • Added Shutter
0.1.2
  • Optimized reconnect handling
0.1.1
  • Fixed storing of wrong auth data & handling of wrong auth data
0.1.0
  • Associate rooms with correct values
  • Update underlying lib to handle offline crashes for Innogy API
0.0.11
  • Corrected roles for a lot of devices
0.0.10
  • Corrected rw states for a lot of devices
0.0.9
  • Fixed initialization sequence in underlying lib
  • Fixed bootstrap sequence in underlying lib
  • Fixed token refresh in underlying lib
  • Removed unneeded error messages
0.0.8
  • Improved error output once again
0.0.7
0.0.6
  • Removed no longer needed log errors
  • Added unload method
  • Optimized session refreshing
0.0.5
  • Fixed parsing errors
0.0.4
  • Added Netatmo Weatherstation
0.0.3
  • Added a lot of devices
  • Updated lib to reestablish Websocket connection
  • Added debug event if Websocket connection is lost
0.0.2
  • Added "Virtual" as default location for devices which doesn't have a location
0.0.1
  • Initial commit
The MIT License (MIT)
Copyright (c) 2020-2023 Patrick Arns iobroker@patrick-arns.de
