Hue Sync Box
An adapter to read and control the Philips Hue Sync Box
Current Release
0.3.5
Issi
hue-sync-box adapter for ioBroker
The adapter requires a Node.js version >= 16.x
What is the Philips Hue Sync Box?
The Philips Hue Sync Box is a device that allows you to synchronize the colors and lighting effects of your Philips Hue lights with the screen of your computer screen. This is possible by the Sync Box detecting the colors and light effects of your screen and transmitting them to your Philips Hue luminaires.
What can the adapter do?
The adapter polls the Philips Hue Sync Box API every 15 seconds and updates the data points accordingly. There are some data points that can change the settings of the Sync Box (e.g. the sync on/off switch, switch the HDMI inputs, etc.). Any change to the data points is immediately sent to the Philips Hue Sync Box and triggers an update of the data points. Multiple Philips Hue Sync boxes can be created at the same time.
What is required to use the adapter?
  • Philips Hue Sync Box IP address (IPv4 only)
  • Hue Sync Box token (see below)
How do I add the Philips Hue Sync Box to the adapter?
  1. Open the adapter configuration and click on the button "Add box".
  2. enter a name for the box, the name must be only 1x because it will be used as ID.
  3. Enter the IP address of the box. (IPv4 only) (small hint: when entering the IP address, a dot will be inserted automatically at every 3rd number)
    name_ip_token
  4. Click on the button register box a new window will open, where you can register the box (see below) registration
  5. As soon as the button registration is pressed, the process starts, then you have 30 seconds to press the button on the box and hold it for about 3 seconds until the LED flashes green. (see below) registration
  6. After you release the device key, after a few seconds will be displayed the token and inserted into the field. (see below) token token
  7. Now you can click on the button add and the box will be added, then you just have to click on the button save to save the config. Adapter_GUI
Delete the hue sync box from the adapter
Attention! For the deletion with the options to work, the token must have been created via the registration function of the adapter.
  1. Open the adapter configuration and click on the button "Delete" Trash can icon.
  2. a new window opens with 2 options select the option you want to use. If none of the options is selected, the box will only be deleted from config. (see below)
    • deregister from the box - the box will be deleted from the adapter and the token will be deleted from the box
    • delete object - the box will be deleted from the adapter and the objects will be deleted from the ioBroker delete_box
you can also select both options at the same time then the box is deleted from the adapter and the objects are deleted from the ioBroker and the token is deleted from the box.
0.3.5 (2023-02-06)
  • (xXBJXx) Dependency update
0.3.4 (2023-01-15)
  • (xXBJXx) fixed Sentry error reporting
0.3.3 (2023-01-14)
  • (xXBJXx) fixed a bug
0.3.2 (2023-01-13)
  • (xXBJXx) update dependencies
  • (xXBJXx) Log output extended and improved
  • (xXBJXx) Added data point for the response JSON
  • (xXBJXx) Added data point "Reachable" to check if the box is reachable
0.3.1 (2022-12-20)
  • (xXBJXx) Fixed error message that occurs after a successful registration.
0.3.0 (2022-12-20)
  • (xXBJXx) added delete function for objects and Token
  • (xXBJXx) added funktion for sync the execution.intensity state
0.2.1 (2022-12-17)
  • (xXBJXx) typo corrected in README
  • (xXBJXx) Fixed a bug when sending commands to the box
0.2.0 (2022-12-17)
  • (xXBJXx) Optimization and improvement of the registration process
0.1.0 (2022-12-16)
  • (Issi) First release
Copyright (c) 2022-2023 Issi issi.dev.iobroker@gmail.com
