Control Govee devices via local access (no cloud)
To be able to control govee deivce locally, the feature needs to be explicitely turned on in the settings of the govve application settings as described in their documentation As I currently only have the H6051 lamp, this is the only device I can test with.
For Windows Users: Please go to the settings and make sure you choose the correct network interface, otherwise the adapter will not receive any response from Govee Devices.
0.5.0 (2026-09-11)
- add HomeKit-compatible hue and saturation states, and a mired color temperature state
- Adapter requires node.js >= 22.19.0 now
- update dependencies:
@iobroker/testing(6.2.1)- removed the now obsolete npm overrides for
mochasubdependenciesdiffandserialize-javascript
0.4.7 (2026-06-02)
- maintenance refactoring
0.4.6 (2026-05-18)
Adapter requires node.js >= 22 now
Fixed multiple security vulnerabilities in dev dependencies:
- Updated
@iobroker/testingto resolve axios, esbuild, and mocha-related CVEs - Added npm overrides for
mochasubdependencies:diff(^8.0.3) andserialize-javascript(^7.0.5) - All npm audit checks now pass with zero vulnerabilities
- Updated
update dependencies: @types/node (25.5.0), eslint (10.1.0), @alcalzone/release-script (5.1.1), admin (7.6.20)
update dependencies: @alcalzone/release-script (5.2.0), @alcalzone/release-script-plugin-iobroker (5.2.0), @alcalzone/release-script-plugin-license (5.2.0), @alcalzone/release-script-plugin-manual-review (5.2.0), @iobroker/eslint-config (2.3.4), @types/node (25.6.2), eslint (10.3.0), prettier (3.8.3), typescript (6.0.3)
0.4.5 (2025-11-16)
- fix scan mode inconsistency enhance log output behavior
0.4.4 (2025-11-13)
- add option to run auto discovery once on startup, in interval or completly disable it
Older entries are available in CHANGELOG_OLD.md.
Copyright (c) 2025-2026 Børge Grunicke
