Google Shared Locations 2
Share your location with ioBroker via google maps.
Current Release
0.4.0
Garfonso
google-sharedlocations2 adapter for ioBroker
Share your location with ioBroker via Google Maps. You should create a separate Google account for this purpose, i.e. an account for your ioBroker installation. Do NOT use your personal account.
Configuration
In config, you can enter the credentials of the Google account you created for ioBroker and the adapter will do everything for you. Do NOT enter your personal account data.
Then share your location from your mobile device (and account) with this iobroker-google-account. The adapter will read the shared location and create states in ioBroker for each person sharing their location with the Google account.
You can configure the polling interval. But it will ignore values below 1 minute to avoid being blocked by Google.
If you do not want to enter username & password, this is possible, read below.
Use a cookie
Sometimes there are issues with login. Since the adapter just opens a browser and tries to login (but is more or less "blind", relies on information it already has), this can fail and there is not much I can do. Sometimes you might get a warning about a new login. Sometimes you will have to re-login with a second factor. If you run into such an issue copy a valid Cookie for google.com into the state google-sharedlocations2.0.info.currentCookies from a real browser.
You can even leave username & password empty in the configuration and then the adapter will try to keep that cookie working as good as possible (similar to my fork of the old google-sharedlocations-Adapter) without ever trying to login (but using the browser from time to time to load the whole page, seems to help with staying logged in).
This is not associated with Google in any way. Usage of this adapter might violate Google's Terms of Service. Use at your own risk.
Copyright and trademark of Google are property of Google.
0.4.0 (2026-07-03)
  • (ioBroker-Bot) Adapter requires admin >= 7.8.23 now.
  • (Garfonso) minor fixes and improvements.
  • (Garfonso/Claude) added self heal if wrong chrome version is installed (e.g. after update of puppeteer).
0.3.6 (2026-04-25)
  • (Garfonso) somehow the old improve cookie call does not work anymore (since switch to fetch). Don't see why. -> So we just run the browser once a day.
  • (Garfonso) Login with browser no tries to clear cookies in browser, if normal login does not work.
0.3.5 (2026-04-22)
  • (Garfonso) resize logo.
0.3.4 (2026-04-22)
  • (Garfonso) replaced axios dependency. Tried to make login more robust.
0.3.3 (2026-02-17)
  • (Garfonso) if deleting cookies, also delete cookies in Browser to force login with username & password.
Copyright (c) 2026 Garfonso garfonso@mobo.info
