Compatible devices
- Gira X1
- Gira Homeserver (recommended firmware >=4.12)
- Gira One Server
Getting started
- Install the iobroker.web adapter and create a new instance
- Configure HTTPS (secure) on that instance and choose the IP address which should be used for external connections
- Choose this web instance in the configuration of the
gira-iotinstance - Configure IP, user name and password of your Gira X1 (or Home Server) in the instance
- Start the instance
0.7.0 (2026-05-05)
- (@klein0r) admin 7.6.20 and js-controller 6.0.11 (or later) are required
- (@klein0r) Updated dependencies
0.6.1 (2025-05-02)
NodeJS >= 20.x and js-controller >= 6 is required
0.5.0 (2024-03-28)
NodeJS >= 18.x and js-controller >= 5 is required
0.4.0 (2023-10-02)
- (klein0r) Added types for remote access (not documented by Gira)
- (klein0r) Added option for custom callback url (e.g. in Docker environments)
0.3.0 (2023-09-13)
- (klein0r) Url preview in instance configuration
- (klein0r) Improved error handling
Copyright (c) 2026 Matthias Kleine info@haus-automatisierung.com
