FITBIT adapter for ioBroker
Adapter for fitbit devices This adapter retrieves fitbit data into iobroker. Ported from @GermanBluefox from his fitbit-api (great thx) into the new iobroker template structure and added some new features
Features
- Body, Activities, Food, Sleep are retrieved individually
- Refresh in minutes for continiously retrieving data
- Sleeping records can be loaded 2 times a day to reduce API calls
Known Bugs
- none at the moment
0.5.0 (2023-11-18)
- Maintanance issues
0.4.14 (2023-11-18)
- Fixed some minor bugs
0.4.13 (2023-10-31)
- make heartrate time series working
0.4.12 (2023-10-03)
- changed node dependencies to node 16
0.4.11 (2023-09-26)
- Catch unpresent activity data
0.4.10 (2023-02-17)
- fixed web page for token
0.4.9 (2023-02-14)
- Changed Repo name
0.4.8 (2022-10-09)
- added lowBatteryAlarm
- fixed body records undefined
0.4.7 (2022-09-20)
- Added Devices request and battery status
0.4.6 (2022-08-01)
- Changed the schedule variance also to 2 hours
0.4.5 (2022-06-16)
- bumping version 0.4.5
0.4.4 (2022-06-16)
- fixed minor issues with versions and testing
0.4.3 (2022-06-14)
- fixed lower case iobroker
- moved axios to normal dependency
- changed node.schedule to random schedule with an hour
- prepared for syncing history data will come in the next versions server request to fitbit is pending.
0.4.0 (2022-06-09)
0.3.10 (2022-04-16)
- added Resting Heartrate
0.3.9 (2022-04-16)
- added ActiveMinutes
- added Floors (activities)
0.3.8 (2022-04-09)
- corrected the auth method of the redirection
0.3.7 (2022-03-24)
- changed the auth method. Tested also with Chrome
0.3.1 (2022-03-24)
- changed the auth method. resolved the bug with iframe. Now also chrome is working
0.3.0 (2022-03-22)
- changed logging -> debug for detailed logging
- bug fixes
0.2.5 (2022-02-20)
- add possibility to read sleep records only in the morning and evening to reduce traffic
0.2.4 (2022-02-17)
- changed the auth method (ported from @GermanBluefox fitbit-api)
- added a debug option to reduce the logs
- some minor changes
0.2.3 (2022-02-15)
- added Food: Carbs, Fiber, Sodium
- fixed Water recording
0.2.2 (2022-02-14)
- Bug fixes
0.2.1 (2022-02-14)
- Minor fixes
0.2.0 (2022-02-14)
- renamed repo to fitbit-fitness
0.1.3 (2022-02-07)
- Add: Loggings adapted
- Fix: Changes Refresh Time to minutes
0.1.2 (2022-02-03)
- added Activity Records
- Fixed refresh rate
0.1.1 (2022-02-02)
- Minor Fixes
0.1.0 (2022-01-30)
- Initial version
- ported parts from projekt @GermanBluefox fitbit-api GermanBluefox
- iobroker-community-adapters/iobroker.fitbit-fitness-api
- and adpated and enhanced
- used the new createadapter script to be on the newest adapter standard
- reduced the parallel reading since the web page blocks after some time
- included food and sleep records to be retrieved
Copyright (c) 2023 Chris besterquester@live.at
