EMS-ESP (ems-esp & km200)
EMS (Energy Management System) based equipment from manufacturers like Bosch, Buderus, Nefit, Junkers, Worcester and Sieger.
Current Release
7.0.8
Thomas Petrick
Bosch / Buderus heating systems with km200 / IP-inside and/or ems-esp interface
The adapter supports an interface towards the heating systems from Bosch Group using EMS or EMS+ bus. (Bosch / Buderus / Junkers / Netfit etc).
The adapter can interface towards the heating system using API calls. Supported gateways are:
  • km200, km200 hrv, km100, km50, HMC300 or IP-inside (from Bosch Group)
  • ems-esp gateway (https://github.com/emsesp/EMS-ESP32) with the ESP32 chip. The adapter is tested for the ems-esp gateway with latest stable firmware version Latest dev versions of firmware might not work stable with the ioBroker adapter. Use is on own risk.
    PLEASE BE AWARE OF REGULAR CHANGES OF EMS_ESP FIRMWARE - THE ioBROKER ADAPTER MIGHT NOT WORK WITH !!!
  • New Bosch-Group Cloud-Gateways (MX300 / EasyControl ...) are not supported since they do not support LAN API !
The ioBroker ems-esp adapter can read and write data to both gateways to control all heating components. It can be used either for the original Bosch-Group gateways or the ems-esp or both in parallel. All changed states from own scripts or the object browser does have to set acknowledged = false !!!
German documentation: https://github.com/tp1de/ioBroker.ems-esp/blob/main/doc/ems-esp-ds.pdf
English documentation: https://github.com/tp1de/ioBroker.ems-esp/blob/main/doc/ems-esp-es.pdf
German ioBroker forum: https://forum.iobroker.net/topic/45862/neuer-adapter-ems-esp-f%C3%BCr-bosch-heizungen
  • The adapterversion >= 7.0.0 supports only ems-esp firmware versions >= 7.2.0
  • dependabot updates
7.0.8 (2026-07-05)
  • fixing issues detected by repository checker
7.0.7 (2026-06-29)
7.0.6 (2026-06-20)
  • fixing errors while restarting adapter
7.0.4 (2026-06-20)
  • fixing issue on main
7.0.3 (2026-05-30)
Copyright (c) 2025-2026 Thomas Petrick (tp1de)
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, *OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE."
