elv-sup2 adapter for ioBroker
This adapter connects the ELV HQ-Stereo-FM-Testgenerator SUP2 to ioBroker via USB serial port. It allows to retrieve and set certain configuration parameters of the testgenerator among them the RDS text, RDS program name and type. SUP2 updating is not supported. Use the Windows program which is provided by ELV for this purpose.
Configuration
The only configuration parameter is the serial port Id of the port to which the SUP2 is connected. The format should be e.g.: /dev/ttyUSBx on Linux- or COMx on Windows-based ioBroker installations.
0.2.3 (2026-03-04) - 2026H1 maintenance release
- (pdbjjens) Changed: node>=20, js-controller>=7.0.7 and admin>=7.7.22 required
- (pdbjjens) Fixed: update release-script (#434)
0.2.2 (2025-12-15)
- (pdbjjens) Fixed: state roles corrected
0.2.1 (2025-11-27)
- (pdbjjens) Change: Migrate To Trusted Publishing
0.2.0 (2025-08-29) - 2025H2 maintenance release
- (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
- (pdbjjens) Change: Updated to ESLint 9 and serialport 13
- (pdbjjens) Change: Cleanup devDependencies
0.1.1 (2024-11-24) - 2025H1 maintenance release
- (pdbjjens) New: Tested with node.js 22
- (pdbjjens) Fix: Responsive Design tweaks
- (pdbjjens) New: Updated dependencies
Legal Notices
ELV and others are trademarks or registered trademarks of ELV Elektronik AG D-26787 Leer, Germany - https://de.elv.com/
All other trademarks are the property of their respective owners. The authors are in no way endorsed by or affiliated with ELV Elektronik AG, or any associated subsidiaries, logos or trademarks.
Copyright (c) 2026 pdbjjens jjensen@t-online.de
