drag-indicator adapter for ioBroker
Shows the min and max of a selected value (of type number) So you can catch the extreme values of an state in a desired timerange. e.g. you can use it for power or temperature values.
2.6.1 (2026-04-05)
- (BenAhrdt) correct nameing of tab and subscribtion
2.6.0 (2026-04-05)
- (BenAhrdt) implement device Manager
2.5.1 (2026-02-28)
- (BenAhrdt) update dependecies
2.5.0 (2025-10-19)
- (BenAhrdt) update Authorisation NPM
- (BenAhrdt) update testing and eslint
- (BenAhrdt) update dependencie core
- (BenAhrdt) update dependencie to node >= 20
- (BenAhrdt) update testing to 24.x
2.4.0 (2025-02-22)
- (BenAhrdt) update admin adn js-controller dependencies
2.3.0 (2024-12-04)
- (BenAhrdt) update eslint
2.2.1 (2024-11-26)
- (BenAhrdt) update schema and responsive tags
2.2.0 (2024-08-13)
- (BenAhrdt) Update Dependencies: "js-controller": ">=5.0.19" Check your System before installing new Version
2.1.6 (2024-08-09)
- (BenAhrdt) correct changes for check and service bot
2.1.5 (2024-08-09)
- (BenAhrdt) changes for check and service bot
2.1.4 (2023-11-26)
- (BenAhrdt) Add actual value to observed values (observe more times easily possible)
2.1.3 (2023-11-12)
- (BenAhrdt) translation for uk added
2.1.2 (2023-11-12)
- (BenAhrdt) insert check vor node version >= 16
2.1.1 (2023-11-02)
- (BenAhrdt) correction in jsonconfig schema
2.1.0 (2023-04-06)
- (BenAhrdt) depencies updated
2.0.9 (2022-08-27) - release script installed
- (BenAhrdt) updated to release script V3
2.0.8 (2022-08-28) - update new release script
2.0.7 (2022-08-28) - cronjob updated to complex mode
- (BenAhrdt) cronjob wizard removed and complex mode enabled
2.0.6 (2022-06-23) - comments added
- (BenAhrdt) comment some lines for better undestanding
2.0.5 (2022-06-17) - paypal implemented
- (BenAhrdt) implemented paypal and sort readme
2.0.4 (2022-06-16) - loglevel check deleted
- (BenAhrdt) dont check loglevel before log.debug()
2.0.3 (2022-06-13) - adapter type changed
- (BenAhrdt) adapter type changed to misc-data
2.0.2 (2022-06-08) - rewrite additional state with ack true
- (BenAhrdt) write ack = true in case of additional state is subscribed
2.0.1 (2022-06-08) - Bugfix unsubscribe additional value
- (BenAhrdt) Do not unsubscribe additional values with deactivate object
2.0.0 (2022-06-04)
- (BenAhrdt) deploy implemented
1.14.9
- (BenAhrdt) fixed some changes in readme
1.14.8
- (BenAhrdt) change setForeignState to setState to write internal States
1.14.7
- (BenAhrdt) first official version
Copyright (c) 2025-2026 BenAhrdt bsahrdt@gmail.com
